A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, metasonix
metasonix
- Tube Pioneer
Post
by metasonix » Thu Oct 24, 2013 12:40 am
Just starting to build them.
No, they are not on our website yet. Sorry.
No, we don't have sample sounds yet. Sorry. If you are really desperate to hear it, come to the Robotspeak demo day this Saturday afternoon. We plan to show one in a demo system, and also deliver a couple of finished pieces to Robotspeak for sale.
The R-56 is 28HP wide and needs 300 mA from +-12v. The panel is an engraved plain-anodized aluminum one with black infill.
Limited issue, was planning to do 50 pieces.
More soon.
theabsent
Post
by theabsent » Thu Oct 24, 2013 1:09 am
Waiting for the sounds
Villarceau
- Wiggling with Experience
Post
by Villarceau » Thu Oct 24, 2013 3:55 am
Wow. Will a few of these be distributed to Europe too?
Mat
- Common Wiggler
Post
by Mat » Thu Oct 24, 2013 11:45 am
"Limited issue"
en ingles
- Learning to Wiggle
Post
by en ingles » Thu Oct 24, 2013 12:06 pm
Does the "Drive Signal Invert" switch just passively switch the polarity of the signal fed to the reverb input coil; effectively switching the black & red wires of the input coil back and forth (as with a DPDT switch)?
Khyber Pass
- The Tank Abbot of home recording
Post
by Khyber Pass » Thu Oct 24, 2013 1:20 pm
Holy smokes. Really looking forward to hearing some sounds from that thing.
metasonix
- Tube Pioneer
Post
by metasonix » Thu Oct 24, 2013 3:22 pm
en ingles wrote:Does the "Drive Signal Invert" switch just passively switch the polarity of the signal fed to the reverb input coil; effectively switching the black & red wires of the input coil back and forth (as with a DPDT switch)?
Yes. An external spring tank, if used, will not be affected by the switch, so the transient will tend to cancel out and you get a "Hot Springs" type of effect.
rechner7
- Common Wiggler
Post
by rechner7 » Fri Oct 25, 2013 1:51 pm
hey eric, the module looks really hot
. do you already have rough price tag for it? where on earth is the yellowish metasonix paint?
edit: i found the answer to my question
"i just wonder if its possible to remove the blue tank and touch the springs?" here
numan7
- the most autistic amongst us
Post
by numan7 » Fri Oct 25, 2013 2:57 pm
i sure hope that i'm paying attention, and have the $499, on the day these go on sale (and probably sell out w/in 10 minutes... here's to hoping that a less limited edition of R-56 will eventually be offered in standard yellow trade dress, i guess)!
cheers
"the ordinary will ignore whatever they cannot explain as if nothing ever happened. and everything remains the same again..."
numan7
Post
by numan7 » Fri Oct 25, 2013 3:09 pm
More soon.
2 of those would just look soooooooo visually nice in the
blue curvy case (or its matching skiff) scheduled to arrive here next month!
must pay attention...
cheers
cheers
Smokey
- Ultra Wiggler
Post
by Smokey » Fri Oct 25, 2013 5:18 pm
Holy tubes batman!
This would be amazing to pair with my S-1000 and D-1000. I’d probably try to write an album using just those three items.
I don’t have any Eurorack equipment though… would the Doepfer Mini-Case work? It seems like it would fit but the Mini-Case is rated at 200mA while the R-56 is rated at 300mA. This maybe a dumb question but not having a Eurorack, I haven’t really have to pay much attention to power ratings.
Any other suggestions for a standalone case/power for just this module?
Great Job Eric, it looks fantastic.
FatRocky
- Super Deluxe Wiggler
Post
by FatRocky » Fri Oct 25, 2013 11:02 pm
They look great, I can't wait
I need two!
FatRocky on Sat Oct 26, 2013 10:01 am, edited 1 time in total.
Smokey
- Ultra Wiggler
Post
by Smokey » Sun Oct 27, 2013 1:44 pm
Sweet, thanks for the link. My first introduction to Euro may hopefully be this sweet ass-nasty 'verb.
askthedust
Post
by askthedust » Sun Oct 27, 2013 5:21 pm
Not sure it will handle the 850 or so mA when you turn it on.
darcmorcel
- Common Wiggler
Post
by darcmorcel » Mon Oct 28, 2013 3:59 am
Oops, you're right, didn't see that at first
metasonix
- Tube Pioneer
Post
by metasonix » Mon Oct 28, 2013 6:41 pm
askthedust wrote:Not sure it will handle the 850 or so mA when you turn it on.
It should work, assuming it is not using switching supplies. (Which I assume it doesn't, from looking at photos and specs.)
The Doepfer mini-case should also work, although you will need a larger AC-AC adapter to run it than the stock adapter, which is very small.
Castratii
Post
by Castratii » Thu Oct 31, 2013 4:21 am
Wow. This I have to hear. Please send at least one to Australia!
a scanner darkly
Post
by a scanner darkly » Sat Nov 02, 2013 1:02 pm
So if powering it from something like Pittsburgh Cell 90 which has the following specs:
power: 850ma linear supply
12vac 2.0a ac power adapter
how much out of that could be safely allocated to other modules taking the 850 initial spike into account? If Doepfer mini case and cell 48 are okay does it mean that the power supply should be able to handle that initial spike as long as after that everything is within the limit? And would there be any danger to other modules during that initial spike?
Smokey
- Ultra Wiggler
Post
by Smokey » Sun Nov 03, 2013 10:11 am
These may be starting to trickle out there...
Was checking Perfect Circuit's website and to my surprise they had a R-56 in stock. I bought it and the listing changed to "out of stock".
So either I just made a pre-order or they actually had a unit in stock for me.
a scanner darkly
Post
by a scanner darkly » Sun Nov 03, 2013 12:29 pm
I grabbed one from Robotspeak, decided to check all the distributors yesterday morning and was lucky to get the last one they had. AH page is also up but not sure if they're gone already or haven't been listed yet.
causticlogic
- Location: atop Unknown Kadath seeking the Ultimate Gate
Post
by causticlogic » Sun Nov 03, 2013 12:44 pm
The AH entry has been up for over a week already. To my knowledge it has never said anything was "in stock".
RealDudes wrote:there's only one window in my padded cell and all I can see is a hallway
looks like there's blood on the floor again
Bumply wrote:I just want to leave work right now and listen to a nice triangle wave.
