Preamp for processing sounds.
Moderators: Kent, grantrichter, carygrace
wavecircle
Big Audio Sodomite
Post by wavecircle » Tue Sep 20, 2011 4:09 pm
I tried playing with the envelope follower on the VCO and WFC today but my ipod puts out a puny signal. What do folks use? I just need gain for processing external sounds. I am sure my Machinedrum will be loud enough, as will anything coming out of my MOTU 828.
Something small, cheap and effective please!
Instagram: https://www.instagram.com/thezyg/ (lots of Serge)
[s]http://bit.ly/2Mekran[/s]
Ciat Lonbarde stuff from many moons ago: http://soundcloud.com/polska-kliknij-muzyka
Illiac
Post by Illiac » Tue Sep 20, 2011 4:14 pm
wavecircle
Big Audio Sodomite
Post by wavecircle » Tue Sep 20, 2011 4:20 pm
Eurorack is no good to me at the moment.
Does anyone have the ART stuff? They do a basic but well specced 1in 1out preamp for £32.
http://www.artproaudio.com/products.asp ... =1&type=79
Illiac
Post by Illiac » Tue Sep 20, 2011 4:29 pm
:doh: sorry
tIB
Stainer!
Post by tIB » Tue Sep 20, 2011 4:31 pm
how much gain do you need? would a headphone amp like this do it?
Hi5
Post by Hi5 » Tue Sep 20, 2011 4:37 pm
mxr microamp pedal is easy and simple.
it is even endorsed by Rex for use with Serge!
wavecircle
Big Audio Sodomite
Post by wavecircle » Tue Sep 20, 2011 4:37 pm
I honestly don't know how much gain I would need, hence asking on the Wiard board.
I did have the same problem in Eurorack though. ipod signals are very quiet once they step into modulars. It don't mind if it goes a little overboard and distorts. The ART stuff looks good.
Hi5
Post by Hi5 » Tue Sep 20, 2011 5:02 pm
ART gear is pretty bad and will color things a bit but since you are not coming from low mic levels they may not be as problematic.
iPods are at line level so you will need only about 10x gain or so at max.
Reptil
In space no one can hear you wiggle
Post by Reptil » Tue Nov 01, 2011 7:49 am
Illiac wrote:Circuit Abbey Gozinta :tu:
http://postmodular.co.uk/circuit-abbey/gozinta
in the post on it's way to here
:tu:
A Dingleberry Monstrosity
eat the kids first
Post by A Dingleberry Monstrosity » Tue Nov 01, 2011 1:33 pm
SHERMAN!!!!!!!!
kragg
MXR Micro Amp Advice
Post by kragg » Fri Aug 24, 2012 6:04 am
Hi5 wrote:mxr microamp pedal is easy and simple.
Hi, i'm bringing this topic back from the dead if you don't mind.
When used on synths, will the MXR Micro Amp color the sound or give it some "punch/edge", or will it be transparent in any circonstances ?
Than kyou in advance
Post by Babaluma » Fri Aug 24, 2012 7:53 am
the ipod is outputting a headphone signal. radial probably make a great headphone out to line level adaptor thingy (possibly with gain).
Tubeampguy
Post by Tubeampguy » Sat Apr 26, 2014 11:44 pm
In the FRAC world we use the Blacet I/O modules.
http://www.blacet.com/IO.html
Also Bugbrand used to make the DD3 VCA/Drive Module This module was offered in Banana or 3.5mm.
http://www.bugbrand.co.uk/index.php?mai ... ucts_id=66
:tu::blacet: :tu:
rico loverde
Post by rico loverde » Sat Apr 26, 2014 11:52 pm
I've thought about the Mattson Modular preamp/envelope follower. I actually have one in a euro panel right now and they work great. It can run off the same power as the Wiard. I was gonna put one behind a blank Wiard panel I had made at FPD
http://www.mattsonminimodular.com/shop/ ... 8f5d81006d
works for Darkplace Manufacturing
Post by JohnLRice » Sun Apr 27, 2014 12:48 am
Maybe consider the discontinued Shure FP11? Built like a tank, tons of gain, limiter, battery powered, 3.5mm input and BELT CLIP!!!! :eek: :goo: :goo: :goo: :goo: :goo:
http://cdn.shure.com/user_guide/upload/ ... p11_ug.pdf
Check eBay, right now there is a new old stock one for $110 and some beat up ones from $40 to $75.
I think it may be on the noisy side (I haven't used it in a while) and there is no phantom power so dynamic mics only.
Return to “Wiard”
