Ca3280e replacement in T.N.A.
deepblackjoe@gmail.com
Post by deepblackjoe@gmail.com » Sat Dec 12, 2020 10:33 pm
Hello everyone. I'm collecting all the things to put together a Tellun Neural Agonizer, and assume a few of you have taken this one on, Do I need to use only the e variant in this, or is the reissue 3280 a drop in replacement? There are also many precision opamps in all the input amplifiers, 7 each of op275 and mx1013, am I missing out by using all tl072 for these? Thanx ahead of time
devinw1
Re: Ca3280e replacement in T.N.A.
Post by devinw1 » Sat Dec 12, 2020 11:15 pm
Short of finding old ones which are not so common, your only choice is the AS3280 Alfa repop. It should work just fine for you though. The original had a CA3289a And a CA3280ae, the only difference is their rated temperature range.
Post by deepblackjoe@gmail.com » Sun Dec 13, 2020 4:17 am
Although I'm sure it gets real hott in the Agonizer sometimes, I'll take my chances with the a variant. Thanks
