100uH Ferrite beads
Noodle Twister
100uH Ferrite beads
Post by Noodle Twister » Sun Sep 15, 2019 3:31 pm
I need to source some ferrite beads.
However the BOM simply states 100uH
Can anyone tell me would these be ok ?
Ferrite Bead Axial RFI Inductor Dia 3.6mm 7 Amp Murata -BL01RN1-A62
Datasheet BL01RN1-A62
guest
Post by guest » Sun Sep 15, 2019 8:50 pm
100uH is quite large for a ferrite bead. usually they are more like 100nH, although the datasheets typically only list an impedance at a certain frequency (eg 100ohms @ 10MHz). 100uH is more of an inductor size. is this for the powersupply input filtering? what sort of package does it require (what does the pcb layout look like)?
openmusiclabs.com
Noodle Twister
Post by Noodle Twister » Sun Sep 15, 2019 9:12 pm
I found some documents with a tiny bit more information
It says 'R0125W' under package. Then quantity 2. Then 100uH under designation.
They are quite large in the assembly guide pictures but do appear to be ferrite beads.
https://www.ericasynths.lv/shop/diy/diy ... diy-swamp/
Documents are at the link above. :help:
Noodle Twister
Post by Noodle Twister » Sun Sep 15, 2019 9:23 pm
guest wrote:100uH is quite large for a ferrite bead. usually they are more like 100nH, although the datasheets typically only list an impedance at a certain frequency (eg 100ohms @ 10MHz). 100uH is more of an inductor size. is this for the powersupply input filtering? what sort of package does it require (what does the pcb layout look like)?
It looks like it may be involved in power supply filtering in this snippet of the schematic. Designators L1 and L2 for the pcb values are also marked 100uH
guest
Post by guest » Sun Sep 15, 2019 9:41 pm
ok, that ferrite bead you linked will work. its about the same size as the one in the picture, and is about as large as you can reasonably expect from a ferrite (~1uH). i have no idea why the schematic and BOM say 100uH, but it wont really matter in this application.
openmusiclabs.com
Noodle Twister
Post by Noodle Twister » Sun Sep 15, 2019 9:47 pm
Thanks very much for clearing that up guest. Much appreciated. :banana:
ixtern
Post by ixtern » Mon Sep 16, 2019 12:53 am
Maybe they (Erica Synths) were thinking of axial inductors like this one:
https://www.tme.eu/pl/en/details/dla100 ... ferrocore/#
They are small but have 11 Ohm resistance and small max current what is unacceptable for me. There are ones with lower resistance, but have bigger sizes.
I am always using in Erica Synths modules (have a few) standard ferrite beads instead.
Noodle Twister
Post by Noodle Twister » Mon Sep 16, 2019 12:04 pm
Hi ixtern, the erica modules you have , have standard ferrite beads in ?
ixtern
Post by ixtern » Mon Sep 16, 2019 2:02 pm
Noodle Twister wrote:Hi ixtern, the erica modules you have , have standard ferrite beads in ?
I am always buying PCB+Panels sets only. And yes, I have populated them with standard ferrite beads.
Noodle Twister
Post by Noodle Twister » Mon Sep 16, 2019 8:09 pm
Ah ok, thanks for sharing ixtern. Good to know.
