MIDI to trigger DIY eurorack module
Picard
Post by Picard » Thu Sep 12, 2019 9:56 am
For live performance I need to sync the eurorack to a master MIDI clock. To make trigger pulses available for 16th, 8th, 4th, half, and full notes I built a small straight forward module based on a Atmega328. It is just listening to the MIDI clock messages (0xF8) and counting 16th notes internally.
It was important to also evaluate the MIDI START message (0xFA) to reset the internal 16th counter to sync all triggers to the start of a bar.
Look at this:
Picard
Post by Picard » Thu Sep 12, 2019 1:30 pm
The firmware is Arduino-based and uses event handlers for the clock messages.
micros() is used to get trigger puls widths of 10 ms.
Code: Select all
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE&#40;&#41;;
static const unsigned b&#91;&#93; = &#123;PD3, PD2, PD4, PD5, PD6&#125;;
static const byte m&#91;&#93; = &#123;96, 48, 24, 12, 6&#125;;
byte a&#91;&#93; = &#123;0, 0, 0, 0, 0&#125;;
unsigned long t&#91;&#93; = &#123;0, 0, 0, 0, 0&#125;;
byte c = 96;
byte i;
void handleClock&#40;void&#41;
&#123;
  for &#40;i = 0; i <= 4; i++&#41;
    if &#40;&#40;c % m&#91;i&#93;&#41; == 0&#41; &#123;
      digitalWrite&#40;b&#91;i&#93;, HIGH&#41;;
      a&#91;i&#93; = 1;
      t&#91;i&#93; = micros&#40;&#41;;
    &#125;
  c--;
  if &#40;c == 0&#41; c = 96;
&#125;
void handleStart&#40;void&#41;
&#123;
  c = 96;
&#125;
void handleContinue&#40;void&#41;
&#123;
&#125;
void handleStop&#40;void&#41;
&#123;
&#125;
void setup&#40;&#41;
&#123;
  for &#40;i = 0; i <= 4; i++&#41; pinMode&#40;b&#91;i&#93;, OUTPUT&#41;;
  MIDI.setHandleClock&#40;handleClock&#41;;
  MIDI.setHandleStart&#40;handleStart&#41;;
  MIDI.setHandleContinue&#40;handleContinue&#41;;
  MIDI.setHandleStop&#40;handleStop&#41;;
  MIDI.begin&#40;MIDI_CHANNEL_OMNI&#41;;
  MIDI.turnThruOff&#40;&#41;;
&#125;
void loop&#40;&#41;
&#123;
  MIDI.read&#40;&#41;;
    if &#40;a&#91;i&#93; == 1&#41;
      if &#40;&#40;micros&#40;&#41; - t&#91;i&#93;&#41; > 10000&#41; &#123;
        digitalWrite&#40;b&#91;i&#93;, LOW&#41;;
        a&#91;i&#93; = 0;
      &#125;
&#125;
Bjarne
Post by Bjarne » Thu Sep 12, 2019 1:51 pm
Thanks for sharing! This looks like a nice schematic for breadboarding a minimalistic midi to drum trigger gadget as well.
aabbcc
Post by aabbcc » Fri Sep 13, 2019 4:05 pm
Looks awesome! Any chance the code code be modified to support accent/velocity changes over midi?
devinw1
Post by devinw1 » Fri Sep 13, 2019 9:30 pm
Nice! Simple but effective! :tu:
cackland
Post by cackland » Fri Sep 13, 2019 11:13 pm
aabbcc wrote:Looks awesome! Any chance the code code be modified to support accent/velocity changes over midi?
Yes, this is easily done.
