Gaging interest in a tool to screw on thonkiconn round nuts
devinw1
Post by devinw1 » Fri Jul 26, 2019 3:23 pm
I kind of want to design a nice little machined tool that will tighten the round jack nuts easily without scraching them because nobody sells anything decent. Exploding Garage had a need little 3D printed thing but it's perpetually out of stock.
If I came out with something that would sell for maybe ...30$?? How many people would be into that?
You can tell me my idea sucks and suggest another tool too, that would be fine. I'm just tired of tightening the damn things with my wire nippers. :bang:
diophantine
Post by diophantine » Fri Jul 26, 2019 7:21 pm
Are these the round nuts with the exposed slots on both sides?
If so, you can get a tool at Mouser that works. I think it is 382-0006, but I am not 100% certain. Around $8. You do have to file down the protrusions that fit into those slots, though, as there's some burrs on the driver, and there can be some on the nuts.
I'd owned it for years, thought it sucked, and started using a small screwdriver to turn the nut on just one side. Then f'd up a panel pretty bad doing that, and then revisited the nut driver. After filing the edges/corners down a bit, it seems to work fine.
Joe.
Wired for sound
Post by Joe. » Fri Jul 26, 2019 8:08 pm
You used to be able to buy these from Thonk, they were cheap and made pretty well. Perhaps email them and see about another run?
devinw1
Post by devinw1 » Fri Jul 26, 2019 8:15 pm
Joe, that is almost EXACTLY what I had envisioned drawing up. WTF why would they cancel that lol. Ok I will contact Thonk. Thanks man.
Diophantine I'm talking about the knurl nuts with spanner slots on one side that thonk sells. Tho if there are other styles of hex-less jack nuts it would be cool to have a tool that would work on all of them (if that's possible)
Revok
Post by Revok » Fri Jul 26, 2019 8:23 pm
Befaco has a tool for their new nuts. It looks like it only works with their nuts though. https://shop.befaco.org/bananuts/1044-b ... -tool.html
devinw1
Post by devinw1 » Fri Jul 26, 2019 10:13 pm
Those nuts are bananas too, not 3.5mm which I speak of.
Nice looking though
Post by JohnLRice » Fri Jul 26, 2019 10:42 pm
devinw1 wrote:Those nuts are bananas too, not 3.5mm which I speak of.
Nice looking though
Actually they aren't for banana jacks, they are for 3.5mm jacks. Read carefully, I was reading it as "banana" at first too! :eek: :doh: :hihi:
They are BANAnuts. And their tool is under $10:
https://www.thonk.co.uk/shop/bananuts/
selfdestroyer
Post by selfdestroyer » Sat Jul 27, 2019 1:39 am
That PEG looks great with them!
My DIY / Music Blog They Remain Silent
devinw1
Post by devinw1 » Sat Jul 27, 2019 1:51 pm
Oh weird. Odd name choice on Befaco's part haha! Those do look cool.
Seems like that tool might work on the thonk nuts too then, although pity it doesn't have a centering peg like the discontinued thonk tool!
Jaytee
Post by Jaytee » Sat Jul 27, 2019 2:04 pm
I 3D printed myself a tool. It’s not a perfect fit but it works and when it wears out (which it’ll do fairly quickly because of the aforementioned poor fit), I’ll tweak the model/print settings and print a new one. Eventually I’ll nail it and get the dimensions just right.
All that to say, it’ll take a looong time before I print enough of them to hit the $30 mark ;)
Post by JohnLRice » Sat Jul 27, 2019 2:44 pm
I had a thought that is probably easier said than done and you are on your own if you hurt yourself trying but:
Take a jack and saw off the threaded part
Screw the threaded section into a nut so that the threads are flush with the bottom of the nut
Place the threads/nut in an old frying pan and heat up on the stove, so it's just barely hot enough to melt plastic
Take an appropriately large plastic knob, like one off of a 5U system (if I find a knob missing on my gear I WILL find you! :mad: :hihi: ) and press it hard into the hot screw nut :eek:
Note that it might be hard to get the metal peices out of the knob, especially after it cools? Maybe instead of sawing off the threads and using the frying pan maybe just using vice grip pliers etc hold the jack from the bottom and heat it with a small torch or flame?
This might be a big waste of time so, YMMV . . . .
devinw1
Post by devinw1 » Fri Aug 30, 2019 12:03 pm
Welp, ended up whipping this up from an old nut driver on the mill at work this morning. Does the trick!
Image[/img]
Post by JohnLRice » Fri Aug 30, 2019 12:29 pm
devinw1 wrote:Welp, ended up whipping this up from an old nut driver on the mill at work this morning. Does the trick!
Image[/img]
:tu:
roglok
Post by roglok » Fri Aug 30, 2019 2:15 pm
just leaving this here ftr:
viewtopic.php?t=114781
devinw1
Post by devinw1 » Fri Aug 30, 2019 2:59 pm
Hah, damn. I'm assuming if Raf still had those tools though, he would have em up on the MSW site? That thread is hella old.
I'll ask him.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Aug 30, 2019 4:39 pm
the erthenvar nut driver is in fact a six sided nut driver that has been machined on the tip. the six sided section is still in there.
Monobass
thonk.co.uk
Post by Monobass » Fri Sep 06, 2019 7:34 am
devinw1 wrote:Joe, that is almost EXACTLY what I had envisioned drawing up. WTF why would they cancel that lol. Ok I will contact Thonk. Thanks man.
We didn't cancel them, spent ages trying to restock but the guy who made them didn't want to make any more. There weren't for Thonkiconn sized nuts though.
We are working with someone else to create a solution, the exploding shed sets are nice too.
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
devinw1
Post by devinw1 » Fri Sep 06, 2019 1:08 pm
Gotcha!
joem
Post by joem » Fri Sep 06, 2019 4:40 pm
The Exploding Shed ones are nice. I have zero regrets about getting it.
grenert
Post by grenert » Sun Sep 08, 2019 12:29 pm
joem wrote:The Exploding Shed ones are nice. I have zero regrets about getting it.
They don't seem to ship to the United States. Anywhere else to buy them?
wendallsan
Post by wendallsan » Mon Sep 09, 2019 11:27 am
diophantine wrote:Are these the round nuts with the exposed slots on both sides?
I had picked one of these up, and they work so-so "out of the box". The tool kept slipping, but still tightened up the knurled nuts better than by hand and more safely to the faceplate's paint job than using pliers. I hadn't considered what wasn't working, as the dimensions seem right all the way around (inner diameter, outer diameter, position of the protrusion tabs, diameter of the inner protrusion that sits inside the jack, etc). After reading your post I pulled out the magnifier and took a hard look at what was going on, and sure enough, as you say, the tabs on the tool are just a hair too wide to fit in the slots on the knurled nuts. About 5 seconds with a dremel tool shaved off enough of these tabs to fit perfectly, taking this from a "better than nothing" tool to a "perfect for the job" tool. Many thanks for posting this! I highly recommend this to any Mouser shoppers willing to take a few seconds to grind down those tabs a bit. Here's a direct link for anyone too lazy to use the site's search:
https://www.mouser.com/ProductDetail/382-0006
Currently building or troubleshooting a Barton Bytewise Operator + Expander, NLC 1058 Triple Sloths v2, Fonitronic PS3100 Triple Vactrol Resonator, Befaco BF-22 Sallen Key Filter, and Befaco A*B+C. Planning a big build of Nonlinear modules for Fall of 2020!
paperCUT
Post by paperCUT » Mon Sep 09, 2019 3:57 pm
Agreed, I've had one last me 6 months with no signs of weakness. Highly recommended.
joem
Post by joem » Wed Sep 11, 2019 9:16 pm
They don't seem to ship to the US, but I emailed them and they were happy enough to do so. Shipping was surprisingly cheap, though I can't remember exactly what it was.
Altitude909
Post by Altitude909 » Wed Sep 11, 2019 10:37 pm
The befaco one is exactly how I did my 10mm one, simply take a tube 8mm in diameter, knurl one side, machine the keys on one end
Harrisfun
Post by Harrisfun » Thu Sep 12, 2019 6:54 am
Believe Befaco already makes something for this
