Making D-2000 moar distorted like D-1000
A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, infradead, metasonix
metasonix
Tube Pioneer
Post by metasonix » Wed Feb 20, 2019 11:34 pm
Because people keep asking.
You have to take the D-2000 front panel and rear enclosure off to get at the circuit board.
On the far right of the board is the output 3AU6 pentode. Near it at the far-right upper edge is a 2.7k resistor. Try shorting that resistor out and see if you like that distortion. If not enough, there's a 220k resistor right next to the 3AU6 tube; try adding a 47k resistor in parallel with it. That should be a LOT of distortion.
You should be able to do this if you have done simple repairs or circuit-bending before. It is VERY difficult to damage anything in that part of the circuit.
Please DO NOT ASK ME TO MOD YOUR MACHINE this month, please. I am very very very busy right now. Swamped and overloaded. I beg you.
Here's a pic to help you.
xthrasherx
Post by xthrasherx » Thu Feb 21, 2019 7:55 am
:sb:
Probably going to try this over the weekend. Swamped and overloaded would make great track name too :lol:
"While we scream and perish, History licks a finger and turns the page.”
― Thomas Ligotti
Instagram::YouTube::SoundCloud
metasonix
Tube Pioneer
Post by metasonix » Fri Feb 22, 2019 10:07 pm
Note to anyone trying this:
I'm preparing to order a new batch of D-2000 boards. Idea was to remove the little used OUTPUT MUTE CV jack and replace it with a switch to select clean or distorted.
So if a D-2k owner tries this, please report back on the best distortion scheme you found. And we'll add it to future production.
luchog
Crazy Pony
Post by luchog » Sun Feb 24, 2019 3:56 pm
metasonix wrote:I'm preparing to order a new batch of D-2000 boards. Idea was to remove the little used OUTPUT MUTE CV jack and replace it with a switch to select clean or distorted.
Since it's essentially just changing resistor values, what about using a pot instead of a switch, so the distortion level can be adjusted?
metasonix
Tube Pioneer
Post by metasonix » Sun Feb 24, 2019 4:59 pm
luchog wrote:Since it's essentially just changing resistor values, what about using a pot instead of a switch, so the distortion level can be adjusted?
Which resistor? Cathode or anode? One will give "better results" meaning WORSE results. Need to know that.
xthrasherx
Post by xthrasherx » Sun Feb 24, 2019 5:57 pm
Personally I was wondering if that would work for the 2k7 resistor you suggested as the first mod point. Originally I was going to try a switch, but I like the idea of being able to dial it in a little bit.
― Thomas Ligotti
chvad
Post by chvad » Sun Feb 24, 2019 11:29 pm
metasonix wrote:Note to anyone trying this:
Will you make an announcement when those units with the changes ship out?
metasonix
Tube Pioneer
Post by metasonix » Tue Mar 05, 2019 5:07 am
chvad wrote:Will you make an announcement when those units with the changes ship out?
Of course. Boards have been revised to add a pot to adjust the distortion. They are on order and I will post a demo video when one is ready. (Assuming you can hear it...)
Return to “Metasonix”
