Testing OTAs (CA3280s specifically)
devinw1
Post by devinw1 » Mon Sep 24, 2018 1:41 pm
So I've ordered some CA3280s from a few ebay suppliers with decent feedback, but I know it can be a minefield. Unfortunately, as many of you know, sourcing these OTAs is becoming more and more difficult. You can buy them from Rochester Electronics if you want to pay $23 a pop and $250 minimum order. Ouch.
Anyway, I'm wondering if anyone has a simple test circuit handy that I can make to verify if these chips are good or DOA before I use them? Any help is much appreciated!
cygmu
Post by cygmu » Mon Sep 24, 2018 2:22 pm
Here’s what I’ve done in the past. Don’t know if it’s foolproof.
From the datasheet:
https://www.intersil.com/content/dam/in ... 3280-a.pdf
I use the Figure 6 circuit, replace the 68k resistor with a 33k and a pot, ground one input, put a signal in the other one and make sure it comes out the other end and varies in amplitude as I twist the pot.
From about 15 ICs I found one that didn’t work in this configuration and got a refund on it from the eBay seller.
devinw1
Post by devinw1 » Mon Sep 24, 2018 2:54 pm
cygmu wrote:Here’s what I’ve done in the past. Don’t know if it’s foolproof.
From the datasheet:
Awesome, that is super helpful!
What do you use for the differential signal? (i have a feeling you're going to tell me I need a function generator.. :D)
cygmu
Post by cygmu » Mon Sep 24, 2018 3:10 pm
I just grounded one input and sent a single-ended signal through the other, from an oscillator.
devinw1
Post by devinw1 » Mon Sep 24, 2018 3:31 pm
Nice. Thanks man. I will do this!
I have 10 of these chips coming from 1 vendor, and 5 from another. Both Chinese. We shall see what I get!
loki
CA3080 Tester
Post by loki » Mon Sep 24, 2018 7:51 pm
This may be of interest to you.
cygmu
Post by cygmu » Tue Sep 25, 2018 4:31 am
That's an interesting circuit.
I guess you are testing for more than just "does this thing work at all?" which is the main question with an eBay 3280 these days. Are you testing the ability to null the offset?
I would also like to understand the role of the FETs in the current sources. I don't think I've seen that configuration before and am keen to learn!
devinw1
Re: CA3080 Tester
Post by devinw1 » Tue Sep 25, 2018 10:42 am
loki wrote:This may be of interest to you.
Oh wow that's great! Thank you!
And cygmu, isn't that JFET just a buffer?
cygmu
Re: CA3080 Tester
Post by cygmu » Tue Sep 25, 2018 11:23 am
devinw1 wrote: And cygmu, isn't that JFET just a buffer?
I’m not sure. It looks more like a resistor to me. I wonder if it’s there to limit the current or something.
guest
Post by guest » Tue Sep 25, 2018 12:55 pm
i think it helps stiffen up those current sources. in particular for the fixed current source driving the integration capacitor on the oscillator. since Vgs doesnt change much as Id isnt changing, it holds Vce fixed on the current source output transistor. this greatly reduces Ic variations that occur when Vce changes, and therefore makes a better current source. with the variable current source driving the OTA, the variation in Vgs is much smaller than the variation in Vce would have been, so it still helps.
openmusiclabs.com
Reese P. Dubin
Post by Reese P. Dubin » Tue Sep 25, 2018 2:18 pm
I always just swap them into one of my Fritz Threeler VCFs. If it works they are good.
Probably not so helpful
devinw1
Post by devinw1 » Tue Sep 25, 2018 3:50 pm
Reese P. Dubin wrote:I always just swap them into one of my Fritz Threeler VCFs. If it works they are good.
Hey, i mean it works as a "go/no go" test if you happen to have one of those!
fuzzbass
Post by fuzzbass » Tue Sep 25, 2018 4:12 pm
I got a bit hung up on this before. I realized I had a Fritz Threeler filter using two CA2380. I don't know if swapping them into that filter is a thorough test, but it would certainly ID fakes.
Wired for weird
loki
Post by loki » Tue Sep 25, 2018 4:19 pm
The change in Ic as the collector - base voltage changes is caused by the Early effect. The current sources are cascoded with FETs to minimize this. There is a nice description of the Early effect on Wikipedia.
The behavior of the CA3080 as the bias current is swept can be quite varied. I spent 3 weeks in 1975 studying what happens. I had about 50 or 60 3080s. The best of them would give an almost straight line when the offset is nulled. Some would give a parabola and some a polynomial. This is caused by the mismatch in the current mirrors in the part. The PNP current mirrors are made with lateral PNPs and their characteristics suck. Download the datasheet and look at the internal schematic.
The early synthesizer manufacturers who used 3080s all knew that they had to test them. When I went to work for 360 Systems in 1977 Bob Easton told me about a batch of 10,000 parts that had circulated among all the manufacturers on the west coast and that the yield of usable parts was zero. These were parts that passed the factory tests and met the specs in the datasheet.
indigoid
Post by indigoid » Tue Sep 25, 2018 7:05 pm
loki wrote:The early synthesizer manufacturers who used 3080s all knew that they had to test them. When I went to work for 360 Systems in 1977 Bob Easton told me about a batch of 10,000 parts that had circulated among all the manufacturers on the west coast and that the yield of usable parts was zero. These were parts that passed the factory tests and met the specs in the datasheet.
this variability should then also be present in LM13700, yes?
Zap him again! ZAP THE SONOFABITCH AGAIN!
oldenjon
Post by oldenjon » Tue Sep 25, 2018 7:06 pm
Just wait for the AS3280 to be released?
"We all dance by ourselves, that's why we only play electronic music"
http://synthscalledbeasts.tumblr.com/
cygmu
Post by cygmu » Wed Sep 26, 2018 12:46 am
loki wrote:The change in Ic as the collector - base voltage changes is caused by the Early effect. The current sources are cascoded with FETs to minimize this. There is a nice description of the Early effect on Wikipedia.
Thanks -- that is really helpful and interesting.
devinw1
Post by devinw1 » Wed Sep 26, 2018 10:47 am
loki wrote: The early synthesizer manufacturers who used 3080s all knew that they had to test them. When I went to work for 360 Systems in 1977 Bob Easton told me about a batch of 10,000 parts that had circulated among all the manufacturers on the west coast and that the yield of usable parts was zero. These were parts that passed the factory tests and met the specs in the datasheet.
What was the application you are referring to?
For example, the Odyssey uses the 3080 for the VCA. I've personally swapped in several different batches of TO can versions and DIP versions and they all worked fine as a VCA. I realize that's not a huge sample set, but I didn't know the 3080s were so spotty. Or do you mean for more demanding applications ?
devinw1
Post by devinw1 » Wed Sep 26, 2018 10:51 am
oldenjon wrote:Just wait for the AS3280 to be released?
Didn't realize this was happening... Good news for OTA fans I suppose. Seems to be very limited info on the web about it, but it seems it is happening. Sweet!
devinw1
Post by devinw1 » Thu Oct 25, 2018 11:11 am
Update: I have breadboarded a nice little test setup which is as follows:
When used with a function generator you get something like this (yellow is output, blue is input). I have a pot to adjust the voltage on the op-amp circuit so you can vary the gain. (Triangle wave is sorta clipped because it's just at maxing out on 9V battery signal amplitude):
Using this test setup, I am as follows for success:
-Ebay seller "Consolodated Electronics" (Dayton, OH): Bought 5 chips, all work perfect
-Synthcube.com: Bought 2 chips, 1 works perfect, 1 is dead! Dead one just has a -DC voltage on the output
-Ebay seller "Joytrin Electronics" (China): Bought 4 chips, all fakes. Has a "power" pin shorted to ground. Emits magic smoke.
-Ebay seller "cole-0520" (China): Bought 4 chips, all fakes, Output is DC.
I am going to make a PCB with a ZIF socket and a switch to test both halves of the OTA and get it made soon. If anyone is interested in something like this, let me know. I hope this is helpful for some!
dougt
Post by dougt » Thu Oct 25, 2018 9:31 pm
devinw1 wrote: -Ebay seller "Joytrin Electronics" (China): Bought 4 chips, all fakes. Has a "power" pin shorted to ground. Emits magic smoke.
See the clue there?
widdly
Post by widdly » Thu Oct 25, 2018 10:48 pm
I've got a bunch I found in a surplus electronics store in Singapore.
I test them in this circuit..
http://www.noniandjim.com/Jim/archives/ca3280_12.html
If someone desperately needs some, I don't mind trading for interesting PCB's. PM me.
devinw1
Post by devinw1 » Fri Oct 26, 2018 10:18 am
See the clue there?
Haha yeah they seem to have the monopoly on faking chips! I think as a general rule if an IC or other item is fairly desirable, and no longer in production, and stocks are dwindling (this of course being the case for our beloved CA3280s), be VERY wary of buying these items from China.
alfa
Post by alfa » Fri Dec 28, 2018 9:20 am
Just to note:
AS3280 ( CA3280) in production:
http://www.alfarzpp.lv/eng/sc/application.php
Datasheet:
http://www.alfarzpp.lv/eng/sc/AS3280.php
Evaluation samples demonstration:
Borogove
Post by Borogove » Fri Dec 28, 2018 3:59 pm
Hey, alfa, the link to the 3394 datasheet is broken.
