Getting back into yellow
A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, metasonix
joey
Post by joey » Tue Sep 04, 2018 2:34 pm
Hey everyone!
It's been a while, but I can't take it anymore. I need Metasonix back in my life. Being out of the game for a while has left me a bit unaware of what's going on.
Out of all the yellow I had, I miss the S1000, TM7, and R53 the most.
Are any of the new RKs or pedals close to those circuits?
The S2000 seems pretty different from the S1000, is it using thyratrons?
I see there is a pulser RK, how would you say it compares to the R53 or TM1? is there one you would consider best of the three? I had a TM1 and R53 as well but cant remember which I liked more tbh
Any input is appreciated, thanks :)
Yes Powder
Powder that makes you say "Yes"
Re: Getting back into yellow
Post by Yes Powder » Tue Sep 04, 2018 5:53 pm
joey wrote:Out of all the yellow I had, I miss the S1000, TM7, and R53 the most.
The RK3 is basically the same circuit as the R53, although it doesn't have the dedicated Pulser In. I think at one point Eric said he considered the Pulser In to be kind of useless anyways
As for the others, not really. There isn't a thyratron oscillator in the RK series (yet), nor is there a filter like the S1000/R52 or anything that uses BN6s like the TM7.
You might want to check out the RK2 and RK6, though. The RK2 is a VCA with a feedback control and inverse out that might be able to get you close to the nastiness of the TM7, and the RK6 is a new lowpass filter that's nothing like any of Eric's previous designs.
Nope, no thyratrons. It's more like two high-gain R54s being run into each other. It'll give you some nasty sub-bassy sounds if you want them, but also cleans up more easily.
ritchiedrums
Post by ritchiedrums » Tue Sep 04, 2018 7:37 pm
I honestly think you would be happy starting now with one of each of the
RK modules
maybe 2 RK4 modules :metasonix:
EPTC
Post by EPTC » Tue Sep 04, 2018 10:40 pm
Welcome back to Sonixtown!
RK3 is a more rattling R53, so I'd suggest that.
RK2 is amazingly fun. This video should convince you on it.
Bandcamp | Website
This week's show is about electrical safety from 1965:
joey
Post by joey » Wed Sep 05, 2018 5:42 am
cool, thanks for all the pointers guys!
now another question -
I currently have three cases -
two enclave/elite with make noise power
and one custom case with intellijel power
all have meanwell switching supplies
will these power at least one RK?
I'm due for a new case anyway so I've been thinking of a doepfer anyway,
but I'd definitely like to pick up an RK first before the case
Yes Powder
Post by Yes Powder » Wed Sep 05, 2018 11:42 am
Can't say for sure since I only use Doepfer power, but the RK5 and RK6 are supposed to be able to work even with a lot of supplies that can't power other RKs.
snakejaw
Post by snakejaw » Wed Sep 05, 2018 1:00 pm
http://www.metasonix.com/index.php/support
"Intellijel currently has a 30-watt and an 80-watt supply. The 80-watt unit should be able to handle at least three R/RK modules. Please don't try the 30-watt model."
https://intellijel.com/shop/cases/104hp ... ance-case/
"Available with either the high spec TPS80W (TPS80W MAX in the 104 hp version) power supply capable of powering up to 20 (MAX: 28) modules with +12 V output at 3000 mA, -12 V output at 3000 mA and +5 V output at 1500 mA..."
The official power requirements for all Metasonix modules are listed in their respective manuals. When calculating power requirements, be sure to use the values required at start up. Some Metasonix module require more power at start up. For example, the R-56 requires 800~850 mA when first powered up and then 300mA after it's warmed up. So, you'd need to reserve +850 mA for the R-56.
gringostar
Post by gringostar » Wed Sep 05, 2018 1:35 pm
Couple of questions regarding power needed.
First of all, my understanding is that with a switching power supply you need to budget for the max power requirements while a liner power supply you don't. (This is why the old doepfer PSU2 could run 5 modules). I'm a bit fuzzy on how it works but the new PSU3 supply is technically a switching supply however the +12v and -12v act like a liner supply due to how it's put together and why it's conservatively rated so you can treat it as such.
Second, and this is what I'm really not clear on, is the warm up power requirement just for the +12v rail or is it for both the +12v and -12v rails?
EPTC
Post by EPTC » Wed Sep 05, 2018 8:48 pm
You mention the power supplies but not the available mA in each case. What other modules are included for the accumulated draw?
In terms of estimating, it's always best to allocate more than needed. I'd guess about 400-500 mA for each RK module (which would cover the startup needed for the tubes) except for around 200 mA each for the newer RK5 and RK6.
Bandcamp | Website
Yes Powder
Post by Yes Powder » Thu Sep 06, 2018 10:46 am
gringostar wrote:Second, and this is what I'm really not clear on, is the warm up power requirement just for the +12v rail or is it for both the +12v and -12v rails?
Both for the R-series (except for the R55 which takes it from the +5v) and just +12 for the RK series
gringostar
Post by gringostar » Thu Sep 06, 2018 10:56 am
So the R-56 is from both the +12 and -12 then?
Yes Powder
Post by Yes Powder » Thu Sep 06, 2018 11:30 am
gringostar wrote: the R-56 is from both the +12 and -12 then?
Correct.
Return to “Metasonix”
