5823 Noise Sorcerer/Voltage Controlled Annihilator
MUFF WIGGLER Forum Index -> Zerosum Inertia
Author 5823 Noise Sorcerer/Voltage Controlled Annihilator
Yes Powder
Can we talk about these? Nobody is, and I'd really like to.
The 5823 Noise Sorcerer is an amazingly fun (if not always predictable) noise source. Great for hi-hat sounds; just run it though an LPG and you're golden! Adds a lovely haze to raw waveforms run through it. Can do weird things when you hold a magnet up to it. Different behaviors between 5823A and various makes of 5823/Z900T tubes.
And dat plasma glow!
Also the Voltage Controlled Annihilator! Nasty pulse distortion/waveshaper from which you can coax a very unstable suboctave. (I've also found you can get it to behave more like a regular VCA by running audio to the CV in and vice-versa but why would you want to do a thing like that? whistlin')
Here's a track in which I get some subtle use out of it in order to restore attack transients to audio coming from a Montreal Assembly Goodbye24, which is a very lo-fi pitch/delay effect.
[s]http://soundcloud.com/everyonediesscreaming/tangles[/s]
EPTC
That's a truly awesome track man.
