RK5 test
A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, infradead, metasonix
Mat
RK5 test
Post by Mat » Fri Jul 06, 2018 2:37 pm
Malas vibras producer
http://soundcloud.com/mareaboba
Moog$FooL$
Broke Dick Dog
Post by Moog$FooL$ » Fri Jul 06, 2018 2:50 pm
thanx Mat.
can u give us a small description of what u patched there??
i use to drink & smoke.
that fat cat had to go..... wasn't even mine.
Mat
Post by Mat » Fri Jul 06, 2018 3:00 pm
Moog$FooL$ wrote:thanx Mat.
S2000 and D2000 audio out to RK5 CH1, CH2 inputs
Cirklon sends CVs to RK5 CV In CH1,CH2
RK5 two outputs go to a Mixer Module
Mixer Module to Bass Amp
RK5 fits very nicely with D2000 and a good combo with S and D 2000.
metasonix
Tube Pioneer
Post by metasonix » Sun Jul 08, 2018 3:18 am
:sb: and ignore the stupid FB comments about "fart noises". NO ONE farts with more brutal power than Metasonix.
Mat
Post by Mat » Sun Jul 08, 2018 9:31 am
metasonix wrote::sb: and ignore the stupid FB comments about "fart noises". NO ONE farts with more brutal power than Metasonix.
:omg:
Sallad
Post by Sallad » Thu Nov 15, 2018 5:32 am
Nice with the RK-5 mounted in the D-2000! How do you power it? Not from the D-2000 supply?
metasonix
Tube Pioneer
Post by metasonix » Tue Nov 20, 2018 12:42 am
Sallad wrote:Nice with the RK-5 mounted in the D-2000! How do you power it? Not from the D-2000 supply?
Of course from the D-2000. Why not?
EPTC
Post by EPTC » Tue Nov 20, 2018 1:24 pm
The RK5 needs about 200mA at peak power on, right? Would the RK6 work in the D2000 power ribbon as well?
metasonix
Tube Pioneer
Post by metasonix » Mon Nov 26, 2018 10:58 pm
Yes if the power brick can put out enough current. Make sure it's a 5 amp brick.
Sallad
Post by Sallad » Thu Nov 29, 2018 7:32 am
Thank you for answering!
So I can use the 16-pin Euro power cable behind the panel of the D-2000 and that would be enough for the RK5 (and not cause any problems with the D-2000 performance)? I thought the RK needed -12v as well and that the D-2000 only gives out +12...
Would be super if ok to do so!
metasonix
Tube Pioneer
Post by metasonix » Thu Nov 29, 2018 10:58 pm
Sallad wrote:So I can use the 16-pin Euro power cable behind the panel of the D-2000 and that would be enough for the RK5 (and not cause any problems with the D-2000 performance)? I thought the RK needed -12v as well and that the D-2000 only gives out +12...
I think you are misunderstanding the manual. The D-2000 provides +12 and -4.5 volts. RK5 should work.
Sallad
Post by Sallad » Fri Nov 30, 2018 3:15 am
Ok, thanks for clarifying! I will get a RK5 soon as possible then ;)
Return to “Metasonix”
