Random Source's TKB
chrisdermo
Post by chrisdermo » Fri Aug 31, 2018 3:04 pm
MATSmile wrote:
chrisdermo wrote:Really interested to hear at least a ballpark price point on the banana version mounted in its own case with internal power supply - could be exactly what i've been looking for to use with the :bugbrand:. Does anyone know off hand what the voltage range is on the outputs? Is it 0-5v?
I've been using my Serge TKB with Bugs and it works just fine.
Yep I use a meng qi voltage memory with mine which is 0-5v so no worries from me there! Would certainly need to commit to saving for a long time to get one though....... the upcoming bug modules will probably tease me away from doing that for a while! I do see this as a sequencing workstation powerhouse type thing though without much need for supporting modules. I am in dire need of a clock divider before getting another sequencer that's for sure.
What power supply will it need to the inlet fonik? 9v/12v/15v? Dc/ac? What mA rating?
WTB / WTTF: Bugbrand PRC2B, DD3, PRC4, ENV1
Current Bugs frame:
https://www.modulargrid.net/f/racks/view/580413
fonik
Post by fonik » Mon Sep 03, 2018 1:00 am
chrisdermo wrote:What power supply will it need to the inlet fonik? 9v/12v/15v? Dc/ac? What mA rating?
there is a small DC/DC converter on the TKB PCB. the one in the prototype uses 24V DC, because this is the same input voltage we use for the 4U boats with internal PSU. the idea is to use one power brick for several boats.
As a side note: I will do some experiments with a lower input and a wallwart (which would not provide an earth connection, though) to see how that pans out.
additionally there is the classic MTA156 header on the PCB to allow a classic Serge power scheme.
the TKB itself needs just 20mA on the positive rail and almost nothing on the negative.
Big Boss at fonitronik.de
Tech Buddy at Random*Source/Serge
fonik
Post by fonik » Mon Sep 03, 2018 1:01 am
chocolatyshatner wrote:Looks great! Are there plans for a DIY option for bananas or minijacks?
we are not decided on wether offer a DIY version or not.
auxren
Post by auxren » Thu Nov 01, 2018 3:04 pm
Any updates?
fonik
Post by fonik » Thu Nov 01, 2018 4:25 pm
PCBs are in the making and should arrive soon.
Front panels are in.
jamb
Post by jamb » Mon Nov 12, 2018 9:41 pm
Will there be a banana version?
fonik
Post by fonik » Tue Nov 13, 2018 12:28 am
Of course. The PCB accepts both 3.5mm and banana sockets.
FatRocky
Post by FatRocky » Tue Nov 13, 2018 7:40 pm
5th generation is comming .. Is this new TKB part of it ?
fonik
Post by fonik » Wed Nov 14, 2018 9:24 am
FatRocky wrote:5th generation is comming .. Is this new TKB part of it ?
Depends on how you define "5th gen". It is the classic TKB but with quite a few essential improvements.
jamb
Post by jamb » Wed Nov 14, 2018 10:13 am
Is there a list at all or do you anticipate these to be readily available once orders open?
fonik
Post by fonik » Wed Nov 14, 2018 10:46 am
No list yet.
Front panels are in already, and a first small batch of PCBs will be ready soon - then we go from there.
breadman
Post by breadman » Fri Nov 16, 2018 10:45 am
Can't wait for the TKB. Worth taking the time to get it right! (Also hope R*S elects to make it DIY-able)
Need a synth built? Get in touch!
email: jschnvr@gmail.com
IG: @jackssynthbazaar
fonik
Post by fonik » Mon Nov 19, 2018 12:12 pm
The first small batch of assembled PCBs are in. So more to come soon.
jamb
Post by jamb » Mon Jan 21, 2019 7:10 pm
any updates on when these will be available and for how much?
fonik
Post by fonik » Tue Jan 22, 2019 12:42 am
Thank you for asking :D
One of our preferred customers got one for a field test and we wanted to iron out a few things. We have a small run that should be available in a few weeks or even earlier. The price will be in the 1500 + VAT ballpark, but this is just a guess.
FatRocky
Post by FatRocky » Fri Mar 01, 2019 4:04 pm
may i ask when the new pcb´s are going to be available?
:tu:
FatRocky
Post by FatRocky » Thu Mar 07, 2019 4:18 pm
FatRocky wrote:may i ask when the new pcb´s are going to be available?
:tu:
:despair: no answer... ok then : What kind of improvement are we expecting from the new revision? any mod ( quantizer switch or something) ? optional playing mode?
Please let us know so that i can wait for it instead of getting one of those secondhand sts or other brand that are recently around
:tu:
fonik
Post by fonik » Fri Mar 08, 2019 11:04 am
A first batch had some errors that we had to iron out. A new batch will be ordered.
Again, front panels and coated touch strips are in already.
FatRocky
Post by FatRocky » Fri Mar 08, 2019 11:25 am
fonik wrote:A first batch had some errors that we had to iron out. A new batch will be ordered.
Thanks for the info . I´ll be looking forward for the new pcb´s
:tu:
Triglav
Post by Triglav » Sun Mar 17, 2019 4:33 pm
Also hoping for a DIY version.
FatRocky
Post by FatRocky » Mon Mar 18, 2019 10:43 am
If the R*S TKB is placed in the middle of a R*S XL BOAT , which 4x4 modules would you place at the sides ? 8-)
there´s space for one at each side. Would it be a SEQ8 and a Carnivore, two DUSG´s ? or something that R*S haven´t released yet in 4x4 format and that could be DIYed? what would it be?
:tu:
jersupereq
Post by jersupereq » Mon Mar 18, 2019 2:54 pm
FatRocky wrote:If the R*S TKB is placed in the middle of a R*S XL BOAT , which 4x4 modules would you place at the sides ? 8-)
there´s space for one at each side. Would it be a SEQ8 and a Carnivore, two DUSG´s ? or something that R*S haven´t release yet in 4x4 format and that could be DIYed? what would it be?
:tu:
My top 3 choices would be Quantizer, Dual Slope Generator(or carnivore) or the Pulse Divider/Logic
wavecircle
Big Audio Sodomite
Post by wavecircle » Mon Mar 18, 2019 4:14 pm
:tu:
Divide and Compare is an awesome function block for sequencing, Carnivore would be a good choice for clocking/voltage processing as would and DUSG.
If DIYing and you already have clocks covered, I'd maybe have a look at the 8 channel Clee Quantiser.
Instagram: https://www.instagram.com/thezyg/ (lots of Serge)
[s]http://bit.ly/2Mekran[/s]
Ciat Lonbarde stuff from many moons ago: http://soundcloud.com/polska-kliknij-muzyka
syncretism
Morbidly self-aware and liking it
Post by syncretism » Mon Mar 18, 2019 4:30 pm
+1 to both of those.
Divide and Compare is essential, IMHO, but then it's a toss-up between (Carnivore or DUSG) and the CLee Quantizer. If the R*S TKB has a limited quantizer included, then that might skew you toward some CV generators. Not an easy choice, here.
FatRocky
Post by FatRocky » Mon Mar 18, 2019 6:34 pm
Damn, now how i wish to know which are 4x4 modules that R*S are planning next! :hmm:
