Any More Demos of The Hellfire?
A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, infradead, metasonix
killmesara
Post by killmesara » Mon Jan 08, 2018 7:32 am
Im looking for demos of the Metasonix Hellfire in use with as many sources, or signals being sent to it as possible. I picked one of them up from a now defunct industrial band for $10!!!!! It works and Im only scratching the surface of what it can do with audio signals im sending to it. I haven't seen many demos online except a bandcamp link https://daikonshield.bandcamp.com/album ... e-vultures link from Daikon Shield I found in the forums here that make the thing sound like the TITS.
I know they are out of production and the Schematics are available online but I want to see how crazy this thing can get when its paired with gear I might not have right now, but may buy just to run it into this thing.
Yes Powder
Powder that makes you say "Yes"
Post by Yes Powder » Tue Jan 09, 2018 12:05 am
Wait, you picked up a TS-21 for $10!?
:cat1:
Pics or it didn't happen!
ritchiedrums
Post by ritchiedrums » Tue Jan 09, 2018 3:55 pm
$10?????
metasonix
Tube Pioneer
Post by metasonix » Tue Jan 09, 2018 5:17 pm
We made a demo CD back in 2000, I cannot remember if any copies exist and don't remember where the original files went.
$10 is major stupidity--or a warning. Chances are it was "modified" by someone who didn't know what he was doing, that's the usual reason for selling a TS for $10. If it works okay you're very lucky. Usually working TSes sell for $300-600.
killmesara
Post by killmesara » Thu Jan 11, 2018 9:42 am
Yes Powder wrote:Wait, you picked up a TS-21 for $10!?
:cat1:
I will post pics as soon as I get it back in its chassis. Going through it, testing tubes and caps, the power cord was ripped off so I need to replace that and the front faceplate was spray painted with camoflague stencils like "Zero Cool's" laptop from hackers.
metasonix
Tube Pioneer
Post by metasonix » Fri Jan 12, 2018 11:21 pm
killmesara wrote:and the front faceplate was spray painted with camoflague stencils like "Zero Cool's" laptop from hackers.
Now I've heard everything.....
synchromesh
Post by synchromesh » Sat Jan 20, 2018 4:48 pm
*Definitely* pics! :sb: Both "before" and "after"...
A while ago I bought valves for all the circuits on Ken Stone's site - and one day I'll build them all! (Or at least the TS-21, TS-22 and TS-23.)
Post by Kent » Sat Jan 20, 2018 6:01 pm
metasonix wrote:We made a demo CD back in 2000, I cannot remember if any copies exist and don't remember where the original files went.
Actually, much much more!
bcomnes
Post by bcomnes » Sat Jan 20, 2018 11:23 pm
umm here is a ts-21 clone sample all by itself
http://soundcloud.com/baghead/ts21-alone
Be sure to use stereo headphones the TS21 is mono in and stereo out, the secret sauce is the dual plate tube that sends the audio between the the two plates, each with its own channel all the while beating the shit out of the wave form
and this is the clone built I built based on Eric's schematic
TS21 clone
and then there is this Norcal Noisefest set where the TS21 is a key player although not the only thing going on. see this, of I reach for the purple backed box to my right, that's the TS21 doing its thing..
Too Loud?
Too Bad
bcomnes
Post by bcomnes » Sat Jan 20, 2018 11:29 pm
oh and FWIW , I think there were only 22 or so TS-21s ever built so you got a pretty rare piece......
and FYI Tumor Refilled Halo is an anagram of Hellfire Modulator
Too Loud?
Too Bad
Moog$FooL$
Broke Dick Dog
Post by Moog$FooL$ » Wed Mar 14, 2018 6:43 pm
so.... u say "based" on. does this mean, loosely?? or an exact copy of that schematic??
did u have any particular issues with the build?? was it fairly straight fwd.?
d.
:tu:
i use to drink & smoke.
that fat cat had to go..... wasn't even mine.
xthrasherx
Post by xthrasherx » Wed Mar 14, 2018 7:23 pm
Indeed :deadbanana:
"While we scream and perish, History licks a finger and turns the page.”
― Thomas Ligotti
Instagram::YouTube::SoundCloud
Post by Kent » Thu Mar 15, 2018 3:22 am
bcomnes
Post by bcomnes » Thu Mar 15, 2018 6:48 pm
Well Eric provided the schematic. I built it in an old bench tester chassis as exactly as I could using terminal strips and point to point wiring. If I did it again I wold have used a slightly bigger chassis as it is a bit tight in there.
It wasn't hard but then I'm not a beginner. Also today I'm not sure you can get 2AMP versions of the power transformers, although I'm guessing that 1 AMPs might be enough.
After building it I had to get an hour of Eric's bench time to get it all working correctly. He gave me an F for soldering skills - sigh - but he did like the colors.
The schematic is here TS-21 Schematic
Eric suggested I eliminate the Range switch as not being all that useful.
Too Loud?
Too Bad
Yes Powder
Post by Yes Powder » Fri Mar 16, 2018 3:00 am
What if you tried to run two 1A transformers in parallel?
metasonix
Tube Pioneer
Post by metasonix » Fri Mar 16, 2018 4:42 pm
Yes Powder wrote:What if you tried to run two 1A transformers in parallel?
Don't do that. Please. 2-amp trans are readily available. PM me if you can't find them.
Moog$FooL$
Broke Dick Dog
Post by Moog$FooL$ » Fri Mar 16, 2018 5:59 pm
hey. thatnx for the reply & info.
perhaps i'll look into a build of some sort.
bcomnes
Post by bcomnes » Fri Mar 16, 2018 6:47 pm
Eric's two tranny solution for a power supply yields a low voltage (6 volts) high current heater voltage from one half of T1 and the other half goes to T2 which reverses the 6 volts back to higher plate voltages in an elegant, compact and great solution eliminating the need for expensive, heavy big all in one power transformers like those found in many guitar amps.....
For a DIY TS-21 clone saga see this http://www.subatomicglue.com/helll0g/
It's basically a multi-year journal of his attempt to build a beautiful clone, not sure if he ever finished it....humble brag, I was the Dorkbot presenter in Chicago he referred to.
Cosmetically it was way cool [/img]
Too Loud?
Too Bad
Moog$FooL$
Broke Dick Dog
Post by Moog$FooL$ » Sun Mar 18, 2018 7:24 pm
hey. thanx for the link.
wow! he really went all in on the panel. :eek:
metasonix
Tube Pioneer
Post by metasonix » Mon Mar 19, 2018 6:34 pm
bcomnes wrote:For a DIY TS-21 clone saga see this http://www.subatomicglue.com/helll0g/
Offered to help him make it work--never heard back. :despair:
xthrasherx
Post by xthrasherx » Thu Mar 22, 2018 1:33 pm
This arrived
:yay:
― Thomas Ligotti
Robscorch
Post by Robscorch » Mon Apr 02, 2018 1:16 pm
Can't say I'm not jealous... beautiful piece of kit. :goo:
metasonix
Tube Pioneer
Post by metasonix » Mon Apr 02, 2018 3:51 pm
xthrasherx wrote:This arrived
:yay:
HANG ONTO IT. We aren't going to reissue it and only 38 were made.
xthrasherx
Post by xthrasherx » Mon Apr 02, 2018 4:10 pm
This lovely device is going nowhere. Wish I could find the TS-22 as well :omg:
For now I'm enjoying running anything I can through the TS-21 and have the D-2000 next on the "big ticket" item list.
― Thomas Ligotti
xthrasherx
Post by xthrasherx » Wed Feb 13, 2019 11:07 pm
Thought I’d share a little tune I was working on today. The primary sound source was the TS-21. The R56 and R57 also make an appearance.
― Thomas Ligotti
Return to “Metasonix”
