The Metasonix RK5 Dual Lowpass Gate has arrived
A place to discuss the brutal yellow evil we all love so much.
Moderators: Kent, infradead, metasonix
snakejaw
Post by snakejaw » Sun Oct 22, 2017 10:45 pm
EPTC
Post by EPTC » Mon Oct 23, 2017 10:07 pm
Since part of our remit is to explore an electronic-music history that didn’t actually happen, one inevitable product would have been a lowpass gate.
Loving the RK series.
So this is an LPG without a vactrol? Can't wait to work with this.
metasonix
Tube Pioneer
Post by metasonix » Tue Oct 24, 2017 7:39 pm
EPTC wrote:So this is an LPG without a vactrol?
LPG=vactrols, tubes or not.
ritchiedrums
Post by ritchiedrums » Wed Nov 01, 2017 10:03 am
:sb: :sb: :sb: :agonizer:
snakejaw
Post by snakejaw » Fri Nov 10, 2017 10:51 am
EPTC
Post by EPTC » Fri Dec 01, 2017 9:34 pm
Good joy here - I was bummed to see Big City sell out so quickly (but happy for Eric) - Analogue Haven just got a batch in, grabbed one immediately.
http://www.analoguehaven.com/metasonix/rk5/
numan7
the most autistic amongst us
Post by numan7 » Thu Dec 07, 2017 2:37 am
:party: rk-5 sounds so-ooooooooooo exquisite - possibly my favorite sounding module, metasonix or otherwise, yet! :hail:
:agonizer: here are some of the ways i've been patching mine during the first few days i've had it:
1st patch: trigger output from clock divider into to rk-5 ch-1 cv-input. rk-5 ch-1 output into main mixer.
result: silence.
2nd patch: same as 1st patch, but with rk-5 ch-1 output split via stackcable so that it is also multed into rk-5 ch-1 input.
result: clicky, rubbery 'buchla bongo'-like sound.
3rd patch: same as 1st patch, but with rk-5 ch-1 output multed into a vca with adjustable offset bias, cv attenuation and exp/lin response. AD eg patched to vca cv in. clock divider output pinging rk-5 cv-input is multed to AD eg trigger input. vca output is patched to rk-5 input.
result: similar to 2nd patch, especially at short attack and decay, but louder and with some control over pitch. depending on vca bias, cv atten and response settings, rk-5 ouput can cut off to silence at short eg attack and decay. at higher vca bias setting and linear response, rk-5 starts to self-oscillate (and can get rather loud). with vca response somewhere between exp and linear and bias about halfway up (etc.) i am able to get a very nice snare drum sound with the rk-5 adding just the right amount of crunchy noise on top of the bongo ringing vactrol tone to make it fairly convincing (a bit of spring reverb helps here too).
4th patch: similar to 3rd patch, but with OR-mix output from AD envelope and LFO-mode function patched to vca cv-input.
result: when the LFO function, set to short attack and long decay and mixed at least 40% proportion with the envelope, goes through the 2nd half of its cycle the snare drum sound mutates into space-invader bleeping/blooping for a couple of seconds (LFO is running at approx 0.25 hz here).
5th patch: similar to 4th patch, but with rk-5 ch-1 output multed into an audio submixer and mixed with zig-zag waveform output of a vco. audio submixer output patched into vca input. smooth rapidly fluctuating random voltage generator output patched to scale quantizer input. scale quantizer output patched to vco 1v/oct input.
result: :loves: exactly how i like my instruments to sound! depending on submixer and vca settings i can get such a beautiful - buchla-esque but different - plucked-string melody going on at the same time as rk-5's internally generated snare drum sound. when i increase LFO mix-amount and decay time to the range where bleeps and bloops were occuring in the 4th patch, in this case the rk-5 instead appears to try to follow the vco's pitch after a slight lag and lowered a few steps - like some crazy-ass pll - it actually sounds like i might be hearing some alternation between 4ths and 5ths and occasional 3rds going on (i'll have to slow things down and listen more closely to convince myself i'm not tripping later).
cheers
(*other modules used in the above descriptions were: intellijel uscale, uvca-ii, quadra+expander, dubmix, rubicon and springray + makenoise maths and wiard-wogglebug + mutable instruments frames + plan-b heisenberg generator +tsyklon labs chaos divider -- i'm really looking forward to patching rk-5 with other metasonix once i get my yellow-case power issues sorted out)
"knowledge has to be organized so it can be taught, and it has to be reduced to information so it can be organized do you follow that? in other words this leads you to assume that organization is an inherent property of knowledge itself, and that disorder and chaos are simply irrelevant forces that threaten it from outside. in fact it's exactly the opposite. order is simply a thin, perilous condition we try to impose on the basic reality of chaos..." --william gaddis
snakejaw
Post by snakejaw » Fri Dec 08, 2017 10:45 am
Love to hear some examples!
EPTC
Post by EPTC » Fri Dec 08, 2017 3:14 pm
Here's some. I got one just this week and can totally agree with numan7, there's thousands of sounds, bongos, bumps, in this thing. Good VCA functions, too.
Really lovely rubber band twang. Can't wait to work with it more.
https://soundcloud.com/eptc/metasonix-lpg
captjrab
Post by captjrab » Sun Jan 21, 2018 1:07 pm
Just scored this module from Robot Speak. Been looking into another LPG and saw this and ccould not resist the :goo: .
Hooked it up with PEG. Patched channel one out into channel 2 in and am messing with different clock ryhthms. Sounds amazing. Very expressive.
thedevilstone
Post by thedevilstone » Mon Mar 05, 2018 2:38 pm
Just snatched one. Looking forward to adding it to my Metasonix rig.
Thanks numan7 for the patch ideas and EPTC for the sounds.
I’ll play with mine and post what I find out here.
If you guys have any other experiences with the RK5 you wanna share, I’d appreciate it.
Cheers.
FatRocky
Post by FatRocky » Tue Apr 03, 2018 4:19 pm
:confused:
Sookilala
Post by Sookilala » Thu Jul 19, 2018 8:20 pm
Hi all,
I recently bought RK5 and have a question for any other owners out there
So i noticed some significant difference between channel 1 & 2, like 6 - 8 dbFS when recorded in my DAW and compared
I contacted schneidersladen and was told as per the manual (which i did read :) ) its most likely the tubes that there is no way to match the channels. I was directed to buy some tubes or send the module back to swapped.
Im in Australia so i bought a bunch of 17JK8 tubes to try rather than send it back. After getting almost identical results with the 3 sets of tubes i tried i feel there maybe something up with the unit. Im in communication with schneidersladen(who are great :) ), but i just wanted to ask anyone else that owns an RK5, is this how your module behaves?
Channel 2 on my RK5 does not fully open feeding it +5v from maths (as compared to channel 1 which fully opens from the same source), and again this behaviour is the same across 3 sets of tubes. The unit isnt power starved as im doing this testing in a case with adequate power and no other modules connected to the board
Below are the results of testing the output of the module
Tube A
RK5 Ch1 = -6.4dB FS
RK5 Ch2 = - 13.2dB FS
Tube B
RK5 Ch1 = -6.4dB FS
RK5 Ch2 = - 14.4dB FS
Tube C
Rk5 Ch1 = -6.5dB FS
Rk5 Ch2 = - 12.5.2dB FS
As a control recorded and measured the volume of the square wave straight into my DAW bypassing the RK5
Control Square wave = -5.1dB FS
If anyone has any thoughts or experiences im interested to know
I really love the RK5, or at least channel 1 :)
metasonix
Tube Pioneer
Post by metasonix » Sat Jul 21, 2018 10:37 pm
This is probably a bad vactrol. PM or email me directly for repair.
Sookilala
Post by Sookilala » Sun Jul 22, 2018 6:20 pm
Thanks for the response :)
electricanada
Post by electricanada » Thu Apr 11, 2019 7:44 pm
I recently acquired an RK-5, but have yet to get it to do anything other than Buchla bongos (not that there's anything wrong with that).
WTF does the tube add to the vactrol ping party? (Not complaining; just wondering.) How can I get some Metasonix insanity out of it?
FatRocky
Post by FatRocky » Thu Apr 11, 2019 7:59 pm
electricanada wrote:I recently acquired an RK-5, but have yet to get it to do anything other than Buchla bongos (not that there's anything wrong with that).
Have you seen this?
and this?
electricanada
Post by electricanada » Fri Apr 12, 2019 7:19 pm
Have you seen this?
and this?
Thanks for the links. I was going to try some feedback patches last night, but my wife wanted a foot rub. Maybe I'll be able to try them tonight. I am determined to make this thing squeal and beg for mercy.
electricanada
Post by electricanada » Sat Apr 13, 2019 6:58 pm
I ran some Pittsburgh Generator FM insanity into the RK5, and then fed the RK5 out back into the external FM in on the Generator. With some Maths envelopes I was able to get some super gnarly percussion sounds. I don't know how much of that was the Generator and how much was the RK5 though.
I'm fiddling with the rack this evening, but as soon as I get it fine-tuned I want to try feeding RK5 audio out back into itself.
metasonix
Tube Pioneer
Post by metasonix » Fri Apr 19, 2019 6:34 pm
electricanada wrote:I'm fiddling with the rack this evening, but as soon as I get it fine-tuned I want to try feeding RK5 audio out back into itself.
you can try but the RK6 has that built-in
Return to “Metasonix”
