[BUILD] Magpie Dodeca / Dubldeca MIDI to Pulse/Gate/CV/.
Neutron7
Oldschool bleeper
Post by Neutron7 » Mon Sep 11, 2017 5:59 pm
This will be for people building the 6 hp 12 output teensy based eurorack MIDI module.
Thiis module was built as a "quick and dirty" way to get 12 outputs from MIDI in a small module,
for CV it relies on very fast PWM (over 300khz) when the PWM is only using the 7 bits that MIDI CCs send, and filtering, you can also do triggers, velocity scaled triggers, gates, and velocity scaled gates.
with a bit of coding you could have built in self generated LFOs, envelopes, etc if you wanted say, octatrack style control LFOs and your sequencer does not have that feature,
there is one 12 bit DAC, using the built in teensy DAC output which can be used as a 1v/octave note output, but it is not meant as a high performance midi to 1v/octave midi voice. (probably ok for bass :))
it might also be a nice start for learning teensy coding, as the sketches are fairly basic. (though you have a whole teensy to work with so...)
it has been found that you can also use this with usbMIDI, and Steven Noreyko has even gotten MIDI clock to work from USB. (we are updating the code for usbMIDI)
[note, USB MIDI will not pass from master to slave modules, it is using the raw midi pulses from the opto isolator, there might be a fairly easy fix for this though with just one wire kludge][/img]
here is the module page at magpie:
https://magpie-modular.myshopify.com/co ... ldeca-pcbs
here is the github with example code for 2c dodeca (dubldeca) made for octatrack.
https://github.com/MagpieModular/Dodeca
here are some other examples (not all fully working) I made while testing.
https://github.com/jakplugg/neutron-sou ... a_MIDI_OUT
nevetsokyeron
Post by nevetsokyeron » Mon Sep 11, 2017 7:58 pm
Quick notes:
The DUBLdeca uses 2 complete Dodeca units - this means two sets of everything under the hood (pcb + parts*) - with ONE Dubldeca panel.
This also means you need two euro power connectors. Or you can make a single power cable with two power connectors (pic below).
Not sure if the BOM is updated yet but try to get 5mm wide 47uF electrolytic caps. The early bom had 6.5 or something and they were kinda hard to squeeze in there. I ended up re-ordering and getting some of 667-ECA-1VM470I from Mouser
(*actually you only end up using ONE stereo jack for the MIDI input)
GaryInHuaHin
Post by GaryInHuaHin » Fri Sep 15, 2017 6:32 am
Could you explicate the wiring of the stereo jack for MIDI In? I think there's only 2 ways to do it, but I'd rather do it right the first time....
Initially having trouble compiling the code. It chokes whenever it hits a line to point to a handler, such as:
MIDI.setHandleNoteOn(HandleNoteOn);
It kicks back
'class MIDI_Class' has no member named 'setHandleNoteOn'
I'm using midi.h from PJRC. Is there something I should know?
nevetsokyeron
Post by nevetsokyeron » Fri Sep 15, 2017 5:37 pm
GaryInHuaHin wrote:Could you explicate the wiring of the stereo jack for MIDI In? I think there's only 2 ways to do it, but I'd rather do it right the first time....
The side (ground) pin goes toward the 3rd hole in the pcb. BUT - you don't need to connect the ground pin.
GaryInHuaHin wrote:Initially having trouble compiling the code. It chokes whenever it hits a line to point to a handler, such as:
It kicks back
Check to see if you have a "MIDI" library folder in the Arduino Libraries folder (in your user directory ~/Arduino->Libraries). If so - take it out. The PJRC/teensyduino stuff is installed deep into the Ardunio application directory. Note - the "MIDI_Library" is OK and should not conflict.
There's some issues with a couple different versions of midi.h installed in different places.
GaryInHuaHin
Post by GaryInHuaHin » Fri Sep 15, 2017 9:25 pm
Thanks. Actually, it's the external wiring I'm aftert, ie which pin of a 5-pin MIDI goes to the tip?
This might be standard now, but that hasn't always been the case. :hmm:
It kicks back
When I don't have that folder (PJRC's MIDI directory) in ~/Arduino->Libraries, I get ''MIDI' was not declared in this scope' error at MIDI.begin. This was my original problem.
Dueling midi.h's I suppose.... :fencing:
nevetsokyeron
Post by nevetsokyeron » Sat Sep 16, 2017 12:12 pm
MIDI stereo jack is wired Arturia, Novation style:
4 - Tip
2 - Sleeve
5 - Ring
MIDI Libraries:
Get this one https://github.com/FortySevenEffects/ar ... di_library
and then take out ~/Arduino->Libraries->MIDI
Which will leave you with ~/Arduino->Libraries->MIDI_Library instead.
On MacOS, the PJRC stuff is actually buried in the Arduino application bundle at Arduino.app->Contents->Java->hardware->teensy->avr->libraries->MIDI
GaryInHuaHin
Post by GaryInHuaHin » Sat Sep 16, 2017 10:30 pm
Thanks for the explicit info on the MIDI connection. That does the job!
nevetsokyeron wrote:MIDI Libraries:
Still no joy on compilation. Oddly, I've moved from PC to Mac but have a similar result. error log below. The Libraries Manager shows 47Effects midi lib installed (which I assume is the one in Documents>Arduino>Libraries) but is seemingly ignored in favor of the PJRC library.
I've tried removing one library or the other. The error ('MIDI not declared in this scope') remains the same.
:hmm:
Thanks again for help.
/dubldecca_left.ino.cpp.o"
dubldecca_left: In function 'void setup()':
dubldecca_left:66: error: 'MIDI' was not declared in this scope
MIDI.begin(MIDI_CHANNEL_OMNI);
dubldecca_left: In function 'void loop()':
dubldecca_left:81: error: 'MIDI' was not declared in this scope
MIDI.read();
Multiple libraries were found for "MIDI.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/MIDI
Not used: /Users/garyhall/Documents/Arduino/libraries/MIDI_Library
Using library MIDI at version 4.3.1 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/MIDI
nevetsokyeron
Post by nevetsokyeron » Sat Sep 16, 2017 11:49 pm
Trying to test this on another computer from my existing Arduino install...
I did the following:
1) remove the MIDI folder from ~/Documents/Arduino/libraries/
2) use the Arduino application library manager to install the 47Effects midi library*
3) re-install teensyduino**
* this is at the menu path Sketch->Include Library->Manage Libraries...
and then search for MIDI
EDIT - there may be something going on here with versions of Arduino and Teensyduino. The above worked for me with Arduino 1.8.1 and Teensyduino 1.35
Right out of the box, Arduino 1.8.4 and Teensyduino 1.39 (both the current versions) end up with the compile error you experienced above. Something apparently changed with MIDI in Teensyduino 1.37 and later...
EDIT #2 (And FIX - if you have used Teensyduino 1.39)
add this code to your sketch just below #include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
For reference here's older versions:
https://www.pjrc.com/teensy/td_135/Teen ... nstall.dmg
https://www.arduino.cc/download_handler ... macosx.zip
Also - for anyone else playing along in the home game - You must always quit and relaunch the Arduino application when you change anything with Libraries.
GaryInHuaHin
Post by GaryInHuaHin » Sun Sep 17, 2017 2:46 am
Yay! That did it! :banana: :banana:
Really glad we could recreate it and track it down.
Now to build.... :) :party:
n82558
Post by n82558 » Sat Feb 03, 2018 3:25 pm
I'm trying to compile the firmware and having some trouble at the moment. On the Github for the Dodeca project, each the left and right folders have 3 .ino files. Do I need to upload all 3 to each teensy or just dubldecca_left.ino and dubldecca_right.ino?
I've followed the steps in this thread but I'm trying to just upload the dubldecca_left.ino file at the moment but I keep getting the following error message:
/Users/xxxx/Documents/Arduino/left.ino/left.ino.ino: In function 'void setup()':
/Users/xxxx/Documents/Arduino/left.ino/left.ino.ino:67:24: error: 'HandleNoteOn' was not declared in this scope
MIDI.setHandleNoteOn(HandleNoteOn); // Put only the name of the function
/Users/xxxx/Documents/Arduino/left.ino/left.ino.ino:68:31: error: 'HandleControlChange' was not declared in this scope
MIDI.setHandleControlChange(HandleControlChange);
/Users/xxxx/Documents/Arduino/left.ino/left.ino.ino:69:25: error: 'HandleNoteOff' was not declared in this scope
MIDI.setHandleNoteOff(HandleNoteOff);
Error compiling for board Teensy 3.2 / 3.1.
n82558
Post by n82558 » Sat Feb 03, 2018 10:16 pm
Ok SO that was actually an easy fix, I just had to have all 3 .ino files in the same directory. Both teensy's are programmed now, the startup sequence runs without issue, but the module still doesn't seem to respond to midi at all. Does the ground on the stereo jack really not have to be soldered? Is there a schematic for this anywhere? It would be helpful to figure out what may not be working.
:help:
cannonball swandive
Post by cannonball swandive » Sat Feb 10, 2018 9:57 am
Can anyone point me to substitutes for my build as mouser is out of stock
660-RK73H2ATTD2002F
581-0805YA471KAT2A
660-RK73H2ATTD2002F
n82558
Post by n82558 » Sun Feb 11, 2018 5:44 pm
https://www.mouser.com/ProductDetail/66 ... 2ATTE2002F
https://www.mouser.com/ProductDetail/581-0603YA471KAT2A
These are the replacements I used for those two parts ( you have the resistor in there twice)
jmsiener
Post by jmsiener » Mon Apr 30, 2018 3:58 pm
n82558 wrote:Ok SO that was actually an easy fix, I just had to have all 3 .ino files in the same directory. Both teensy's are programmed now, the startup sequence runs without issue, but the module still doesn't seem to respond to midi at all. Does the ground on the stereo jack really not have to be soldered? Is there a schematic for this anywhere? It would be helpful to figure out what may not be working.
:help:
Kind of in the same boat man. I've gotten the usbMIDI stuff working but still no dice on the dinplug. At this point I've checked continuity between every teensy pin and the other side of the boad as well as continuity between the jack and where they connect to the 220R and 1n4148. When looking at the side of the board where diode is I've got the line to the left going with the line that was on the PCB. I've tried the recent IDE and teensyduino 1.41 and now everything is uploading without any CREATE_MIDI_INSTANCE stuff; just the examples are straight uploading. At this point the only thing I feel like I haven't done is flip that diode around. Feeling like captain dumbass right here.
chailight
Post by chailight » Wed May 09, 2018 8:25 pm
Am about to start on a dubldeca build. Before ordering all the parts, I wanted to check if using a Teensy 3.2 in place of a 3.1 is ok? I know 3.2 is intended as a drop in replacement for a 3.1, but wondered about whether the change in function to pin 1 (analog out instead of reset) makes any difference in this case.
gwpt
Post by gwpt » Sat Jun 02, 2018 6:41 pm
chailight wrote:Am about to start on a dubldeca build. Before ordering all the parts, I wanted to check if using a Teensy 3.2 in place of a 3.1 is ok? I know 3.2 is intended as a drop in replacement for a 3.1, but wondered about whether the change in function to pin 1 (analog out instead of reset) makes any difference in this case.
Did you ever get confirmation of this? I am about to build one too and have the same question... thx
smidirin
Post by smidirin » Sun Jun 03, 2018 6:02 pm
teensy 3.2 is fine. module is great :sb:
jmsiener
Post by jmsiener » Mon Jun 25, 2018 1:04 pm
Forgot got to give a status update here on my build, Facebook group be working way faster. Got everything sorted; had a bat54 and not a bat54s. Got the right diode and everything worked. Got the code sorted on my dodeca for a mono voice, clock out, and 8 drum trigs - my MPC1k and me couldn’t be more pleased.
synthetek
Post by synthetek » Mon Jun 25, 2018 10:02 pm
There is an error in the build doc it says 7x .01 uf Bypass instead of .1uf (it does say .1uf in the picture). There are also 5 10uf smd Electrolytic Capacitors in the BOM that aren't needed?
squarewavesurfer
Post by squarewavesurfer » Wed Feb 13, 2019 5:06 pm
I was following the build guide and came to the teensy pin and socket soldering section. I don't understand why we want all these headers and sockets when they don't match the pcbs. I see some of it says install into the orgone accumulator. It does have a note about laziness for using the orgone's picture but I would have hoped they knew that the pins required on the teensy for the orgone were the same as for the dodeca.
There are no 3pin holes on the pcb immediately next to where the long side of the teensy goes and yet the build guide is saying to solder a 3 pin header onto the teensy. Is the 3 pin header not needed for the dodeca and this is only for the orgone?
As for the surface mount 14pin header for the teensy, it looks like the pcb only has holes for 4 of those pins. Do I snip the rest off?
Also, the BOM has these shallow 7pin sockets instead of the deep sockets that are listed in the BOM for the 4pin and 5pin sockets.
Has anyone come across this?
synthetek
Post by synthetek » Wed Feb 13, 2019 6:14 pm
The 3 pin header is for the orgone you can leave it off. On the surface mount 14pin header the extra pins aren't used but you leave them on to make the header more stable on the PCB.
squarewavesurfer
Post by squarewavesurfer » Fri Feb 15, 2019 2:23 pm
The BOM has 5 Aluminum Electrolytic Capacitors - SMD 25volts 10uF 20% that serve no purpose (no pads for smd electrolytic caps anywhere on the pcb).
synthetek
Post by synthetek » Fri Feb 15, 2019 5:04 pm
squarewavesurfer wrote:The BOM has 5 Aluminum Electrolytic Capacitors - SMD 25volts 10uF 20% that serve no purpose (no pads for smd electrolytic caps anywhere on the pcb).
The aren't needed , its a mistake in the bom
7 Bypass caps in Purple on page 11 of the Build Guide are 0.1 uf, NOT 0.01 uf
The build guide is wrong and there should NOT be a wired connection between the two MIDI connections (2 pin).
Ground on Stereo (MIDI Input) Jack should NOT be connected.
squarewavesurfer
Post by squarewavesurfer » Fri Feb 15, 2019 6:14 pm
Thanks for the corrections!! I have the ground connected so i will snip that before i go any further. I read the comments about the bypass caps so that went without issue. Mouser shorted me 3 ferrite beads so i will be waiting a few days to complete this build.
One thing i wasn't 100% sure about was the orientation of the MB1S. The pcb screen print has the IC notch to the right but my MB1S doesn't have a dot, notch or line on either side. It does have a + and - sign on either side so i figured the + (pin 1 according to the datasheet) should be on the right. Is this correct?
Also, a note about optional use of trimmers confused me.
  • "TRIMMERS
    If you decided on trimmers, then solder them now, where there are no trimmers, then you need
    to solder a jumper (a bit of component lead wire you just cut off the capacitors is fine)
    the trimmers are for these outputs:
    R49 > out2 (DAC)
    R50 > out6
    R51> out 10
    The jumpers go between the square pad and the middle one."
The BOM had 3 trimmers per pcb so that's what i used. I don't see any information on how use them to calibrate out 2, 6, and 10.
synthetek
Post by synthetek » Fri Feb 15, 2019 8:17 pm
Not sure about the trimmers. The one I built was for someone else and everything seemed to work ok so we never did anything with the trimmers.
