Does anyone sell 3.5mm TRS to dual 3.5mm TS y cables?
esotericmetal
Post by esotericmetal » Wed Aug 30, 2017 9:32 am
The only ones i've seen have dual 1/4" ts connectors. I'm thinking I may just have to buy one of them and solder my own connectors on.
I need them to connect my qunexus cv outs to eurorack which uses two 3.5mm trs jacks to output 4 cv signals. Seems like the only off the shelf options are the cv connection kit from KMI, which i'm not interested in as it comes with cables i don't need/already have and is kinda overpriced in general.
flashheart
Post by flashheart » Wed Aug 30, 2017 9:35 am
Seen splitters on Ebay, not seen cables like that though.
I'm not buying a maths though, not my idea of fun...
DMR
Post by DMR » Wed Aug 30, 2017 10:53 am
chysn
Post by chysn » Wed Aug 30, 2017 10:56 am
I faced the same issue when I got a QuNexus. I looked everywhere for ones like the KMI kit has, without luck. I bought two of of the Hosa YMM-261 breakout cables referenced above ^^^ and then I just finish it off with regular Eurorack patch cables. That does the trick, and it isn't thirty $$$ bucks, and you can use any patch cables you have lying about.
Current Rack: https://www.modulargrid.net/e/racks/view/354385
Hemisphere Suite: https://github.com/Chysn/O_C-HemisphereSuite/wiki
"Man must shape his tools lest they shape him." --Arthur Miller
erstlaub
Post by erstlaub » Wed Aug 30, 2017 11:24 am
I've had a few solutions over the years for my BSP to Pam's sync cable but none off the shelf.
I had a spare TRRS AV cable lying around from a media player or projector or something, using a scope or a meter I discovered which 2 of the 3 phono jacks gave me run and clock signals and just used phono to 3.5mm jack adapters for a bit.
I ended up with a TRS cable with no end on it so soldered a couple of 1/4" jack sockets to it and mounted it all in a little case that I used with 1/4" to 3.5mm adapters plugged in.
I more recently found a few spare 3.5mm jacks and cut out the faffing around and soldered them right to the cable instead of via the sockets. It's much tidier and easier to use.
joem
Post by joem » Wed Aug 30, 2017 4:16 pm
When I needed one a few months ago, I went with the Hosa adapter mentioned above. Works fine.
jsco
Post by jsco » Wed Aug 30, 2017 7:34 pm
thanks, you reminded me that i needed to order a pair of these! (for patching into the stereo input channels on panmix.)
the elektron audio/cv split cable kit works for this job if you have one, but it's like five times the cost.
shamann
_
Post by shamann » Wed Aug 30, 2017 8:33 pm
More expensive than the Hosa splitter, but there's also these:
https://www.harpooncables.com/blank-rwr ... ts-y-cable
macs4music
Post by macs4music » Thu Aug 31, 2017 3:32 am
Maplin here in the U.K. Do them; I think you have Radio Shack over the water?
Neil
Started with an Atari 1040STe, at least the timing was good....
macs4music
Post by macs4music » Thu Aug 31, 2017 3:39 am
Here's the maplin link if anyone needs it:
https://www.maplin.co.uk/p/maplin-35mm- ... pter-a71xc
I use two of them with my Qunexus and they work really well.
Neil
kay_k
Post by kay_k » Thu Aug 31, 2017 4:19 am
I had the same stupid problem when using the din-sync out of the Arturia Beatstep Pro to clock Pamela's Workout and Metroplis.
I use something like this now with standard RCA-3.5mmTRS-cables:
http://www.ebay.de/itm/2x-Cinch-Klinke- ... SwOVpXZZWK
I also use this to mult it before I split it:
http://www.ebay.de/itm/Hub-Splitter-Ste ... SwHJhXNBnP
