[Available now!] Original Haible String-Filter re-run 2016
nordlead
Post by nordlead » Tue Feb 23, 2016 7:48 am
As I've received a number of questions regarding the availability of the Haible String Filter pcbs, I'm contemplating to do a re-run of the original String Filter board if there is enough interest (similar to the re-run of the Vocoder pcb).
That means a new production based on the original files (= no changes at all), made in Germany as the original boards.
Jürgen's original String Filter page / demos/ docs
Price is expected to be EUR 27 per pcb.
(Please note that you need 2 pcbs for a 40 band filter.)
UPDATE: The (new) String Filter pcbs as well as some
other original Haible "vintage" boards (new old stock) are now available here.
Random*Source: Serge, JHaible & more ... (also on facebook.com/randomsource)
(please contact me through email rather than pm: rc at randomsource . net - thanks!)
PWM
Post by PWM » Tue Feb 23, 2016 10:45 am
Check. Count me in for sure! :party:
a100user
All the gear, no idea!
Post by a100user » Tue Feb 23, 2016 12:59 pm
Great suggestion Ralf, I'll take one.
I'm looking for nothing at this moment in time
megaohm
Post by megaohm » Tue Feb 23, 2016 4:38 pm
Coolest filter bank ever!!!!
:goo:
Did you know you can ping these with triggers?
I added a group of gyrator EQ circuits when I built a couple of these (similar to the "Performer" EQ section of JH's rack build).
Extra input and atten for feedback style patches, too.
High settings of Res can result in a reverb-like effect.
Yes, I love this JH design!
Do it!
Do it!
:hyper:
I would buy at least one set.
:guinness:
www.MegaOhmAudio.com
Will work for pistachios
pirx
Post by pirx » Tue Feb 23, 2016 7:47 pm
Great news! Definitely, I am in for two sets.
apoisontree
Post by apoisontree » Wed Feb 24, 2016 1:56 am
I'm in for one set. I hope you'll do the Triple Chorus soon, as well.
PWM
Post by PWM » Wed Feb 24, 2016 5:37 am
apoisontree wrote:I'm in for one set. I hope you'll do the Triple Chorus soon, as well.
Triple chorus is available here:
http://randomsource.net/haible/vintage
Joe.
Wired for sound
Post by Joe. » Wed Feb 24, 2016 5:45 am
I don't expect to get the sound of real string instruments (this needs some physical modeling of the bow/string system at least!) , but I want to gain some "organic" quality for otherwise electronic sounds.
I wonder what this filter will sound like, paired with MI. Rings :woah:
Isaiah
Post by Isaiah » Wed Feb 24, 2016 6:37 am
I'm interested in a pair of PCBs but probably won't have the cash until the end of March or end of April.
raph36
Post by raph36 » Wed Feb 24, 2016 6:49 am
wow, count me in for two!
apoisontree
Post by apoisontree » Wed Feb 24, 2016 8:06 am
I know, but I want a new run, with tested and supported boards.
rvlt
Post by rvlt » Wed Feb 24, 2016 2:00 pm
Great, I'd definitely take one set.
yan6
Post by yan6 » Wed Feb 24, 2016 3:45 pm
I think I'm in for two
spneca
Post by spneca » Wed Feb 24, 2016 6:24 pm
Why not? I'm in for a set. Anyone planning on making panels?
PWM
Post by PWM » Thu Feb 25, 2016 12:24 am
spneca wrote:Why not? I'm in for a set. Anyone planning on making panels?
Euro? Yup! :)
But I think the PCB's are going to be quit large..
LektroiD
Post by LektroiD » Thu Feb 25, 2016 2:52 am
The original boards have been tested working. I've just built one, no problems whatsoever.
PK808370
Post by PK808370 » Thu Feb 25, 2016 5:21 am
I would like a set (2 boards, 1 complete filter).
"Are you pondering what I'm pondering"
"I think so, Brain, but what if the chicken won't wear the nylons?"
"There must be some way to get this much money, without running for congress."
Rhea
Post by Rhea » Thu Feb 25, 2016 5:42 am
I'm in for a pair of boards.
PWM
Post by PWM » Thu Feb 25, 2016 8:44 am
Euro? Yup! :)
Or is R*S supplying panels?
jhulk
Post by jhulk » Thu Feb 25, 2016 4:58 pm
triple chorus is very easy no problems
the string filter is easy also even with the sliders and separate outs all the information is there
its just needs a big panel space
LektroiD
Post by LektroiD » Fri Feb 26, 2016 12:39 pm
Since the string filter needs such a large panel space and 2 PCBs are required, would it be better to have the new run on a single PCB?
nordlead
Post by nordlead » Thu Mar 03, 2016 5:51 am
LektroiD wrote:Since the string filter needs such a large panel space and 2 PCBs are required, would it be better to have the new run on a single PCB?
I'm a bit on the fence here - a new redesign of the boards will take much more time and testing (and I'm already drowning in work), while a re-run of the original boards would mean they'd be available in about 2-3 weeks ...
so I'll probably start with a re-run and keep the idea of a redesign for later ...
apoisontree
Post by apoisontree » Fri Mar 04, 2016 10:52 am
If I understand correctly JH's schematics the Performer EQ and Cello/Viola/Violin Filters are not part of these 2 boards, so the panel will be pretty simple : 5 pots, 4 toggle switches, 4 jacks (unless you want to go down the 40-slider road... :deadbanana: ).
thermionicjunky
Thyratron Genius
Post by thermionicjunky » Fri Mar 04, 2016 11:03 am
apoisontree wrote:If I understand correctly JH's schematics the Performer EQ and Cello/Viola/Violin Filters are not part of these 2 boards, so the panel will be pretty simple : 5 pots, 4 toggle switches, 4 jacks (unless you want to go down the 40-slider road... :deadbanana: ).
4 pots (input, res, cv, spread). And for those who didn't follow the E-M thread, the spread control is incorrect in the schematic, but correct in the wiring diagram.
nordlead
Post by nordlead » Mon Mar 21, 2016 12:14 pm
A batch of String filter boards should get here tomorrow. :party:
Will post details as soon as they get here ...
