3rd oscillator module or 2nd dual Envelator module to system
Moderators: Kent, infradead, carygrace, grantrichter
thesnow
Post by thesnow » Sat Dec 13, 2014 12:10 am
If you had a system with one of each module (CVCO WC SEQ WB DE DM BF) excluding an Omni filter and you were going to add 1 more module to your system to make it 8 modules which would you choose a 3rd oscillator module (CVCO or WC) or a 2nd dual Envelator module?
sabasan
Post by sabasan » Sun Dec 14, 2014 11:33 am
if you don't care about a full adsr I will go for a vco
thesnow
Post by thesnow » Sun Dec 14, 2014 2:54 pm
sabasan wrote:if you don't care about a full adsr I will go for a vco
Well 1 dual Envelator would give me a full adsr if I wanted it but I'm just trying to think which would be more interesting as an 8th module more envelope generators or a 3rd oscillator module.
plord
Wacky for Wiard Wiggler
Post by plord » Sun Dec 14, 2014 3:24 pm
Osc for sure. WFC if you can find one, so you can have a different ROM, or go for the MARF functions. But an extra CVCO gets you all kinds of fun also: an LFO, a clock source that can do double/half time jumps via SEQ fiddling, or you can do SIN on SIN FM over a drone coming from your WFC....
slow_riot
Post by slow_riot » Sun Dec 14, 2014 3:33 pm
Did someone say Sine?
I'm still not happy with it though!
@ thesnow... don't you need to keep the ones you have to get to 8? :)
thesnow
Post by thesnow » Sun Dec 14, 2014 4:44 pm
Haha :D I know, it must be annoying seeing me put by system up on bst all the time then change my mind, the thing is if someone was interested in buying my system the money would go such a long way right now that I might sell it but if I can get over this hump then I would like to eventually go for a horizontal 8 module system in a nice wooden case. I've played on a 200e, a 200 briefly, never played a serge, and the wiard is my favorite system that I've played.
slow_riot
Post by slow_riot » Sun Dec 14, 2014 6:45 pm
Here's a thing I learned the hard way.... synths are easy to sell when they are in production... people end up taking it for granted that they will always be around. Notice how many big Wiard systems went up when Wessex Analogue came onto the scene... Boutique gear is kept aflame by one person's passion... sure they might be around when you want the modules back, they also may not be.
drumsofd00m
Post by drumsofd00m » Tue Dec 16, 2014 8:07 am
Actually you can patch two ADSRs with one Dual Envelator, two VCO modules (CVCO or WFC) and one additional CV mixer (i.e. Mixolator or external). The AR parts won't be voltage controlled, but can be jumpered (or switched, if the VCO has that nifty little mod in the VOL pot) between linear and exponential.
It totally depends on each user's style of music which module config is best for them. If you go for 8, I'd recommend said Omni Filter instead of excluding it. Can serve as a filter, phaser or VCO with a lot more I/Os and options than most, if not any other VCF module.
Return to “Wiard”
