[IN STOCK] Eurorack: Discrete State-Variable VCF v1.4
negativspace
Manhattan Analog
Post by negativspace » Wed Apr 16, 2014 6:41 pm
There is a long and helpful thread on the filter itself HERE. I'll re-post the critical stuff:
This filter started life as the SVF design (based on the J. Haible discrete 2040 gain cell) which Scott Stites posted over at electro-music in April. I'd been wanting to work with another filter for a while and this one looked interesting, so I started playing with it. I lopped off the audio input section and grafted on the CP3 mixer (moar transistors!) Eventually I made a few other changes - I got it self-oscillating, added a 1v/oct CV input with scale trim, and did some work in the resonance circuit - and the end result of all of that is the filter heard here:
http://soundcloud.com/negativspace/discrete-svf-test-01
Ignore the photo in the Soundcloud clip, that's a different project using the same circuit. The panel for this one is 14hp, and depth is in the ~40mm range with the two PCBs stacked parallel to the panel. I'll get better photos of the panel and update this post ASAP.
Scott has given his blessing on both a DIY run and a retail release of this filter - so with my deepest thanks to him for the lion's share of this circuit I declare game on.
Last edited by negativspace on Tue May 26, 2015 11:01 pm, edited 13 times in total.
negativspace
Manhattan Analog
Post by negativspace » Wed Apr 16, 2014 6:42 pm
Prices
Eurorack Panel + Bare PCB set: $45/ea
Bare Filter PCB: $20/ea
Shipping: $3/USA, $10/Canada, $15/Overseas
The Paypal address for payment is jcoates42@gmail.com
BOM
Resistors
[1] 1M R45
[1] 390k R13* (* = change to alter signal level from mixer to filter section. Suggested range is ~270-470k.)
[1] 240k R33
[2] 200k R36,R41
[1] 180k R19
[1] 110k R47
[5] 100k R15,R17,R38,R39,R40
[1] 62k R42
[1] 47k R10
[1] 39k R16
[4] 22k R1,R2,R3,R35
[3] 15k R5,R7,R43
[7] 10k R18,R27,R28,R29,R30,R31,R32
[3] 6.8k R8,R14,R46
[3] 1k R21,R22,R44
[2] 560R R9,R11
[3] 470R R20,R34,R37
[1] 240R R48
[4] 220R R23,R24,R25,R26
[1] 200R R6
[2] 100R R4,R12
Capacitors
[1] 3.3nF Film, C5
[1] 2.7nF Film, C13
[2] 1nF Polystyrene/Polypropylene *main timing caps in VCF
[2] 10-100uF Electrolytic *power decoupling caps, value noncritical
[3] 220pF MLCC, C7,C11,C12
[1] 150pF MLCC, C6
[5] 10uF Electrolytic, Q8,Q9,Q10 = audio path. The other two are for decoupling the +5 and -6V rails.
[2] 0.1uF MLCC
Transistors/Diodes
[11] 2N3904/Other NPN [PN100A] Q1,Q4,Q5,Q8,Q9,Q10,Q11,Q14,Q15,Q16,Q19
[2] 2N3904 Q17,Q18
[6] 2N3906/Other PNP [PN5138] Q2,Q3,Q6,Q7,Q12,Q13
[2] 1N4001
ICs/Sockets
[3] TL072 *or other standard pinout dual opamp.
[1] LM337LZ, TO-92
[1] LM78L05 *silkscreen on v1.2 PCB is reversed; TO-92
[3] 8P DIP socket (optional)
MISC
[1] 20k Trimpot (v/oct)
[1] 2k Trimpot (-6V)
[1] 100r Trimpot (null)
[2] Ferrite Bead
[1] 16P Header (power)
[2] 12P Header + socket (board to board interconnections)
[4] 7/16" Nylon standoff + 3/4" #4-40 screw + hex nut set. (Use 12mm standoff if metric)
Panel Controls
[3] A20-25k Pots (lugs) - audio inputs
[4] B100k Pots (pins) - CV inputs, cutoff frequency
[1] B10k pot (pins) - notch balance
[1] B10k Dual-ganged Pot (pins/lugs - BYOC, Banzai, or Small Bear) - resonance
[12] 3.5mm Jack (Erthenvar-style preferred, 16PJ138 in a pinch)
[6] 1900H or clone
[1] Davies 1913BW
[1] Davies 1910CS
Surface Mount Parts:
[2] 0.1uF 0805 ceramic, install on back of main PCB
[2] 0.1uF 0805 ceramic, control board
[2] 22pF 0805 ceramic, control board
[4] 47k resistor, 0805, control board
[2] 330R resistor, 0805, control board
[1] TL072, SOIC, control board
Instructions for trimming
the -6V and null trimpots:
No cables in the module. No inputs, no outputs. Use the test points on the board.
1) The grounded test pad is over by the lower screw hole on the left-hand side of the PCB.
2) Adjust -6V trimpot until the test point "-6V" reads -6.00V. This test point is down by the LM337. Once you set this, for fuck's sake leave that trimpot alone!
3) Measure the test point labelled "-". This incorrectly corresponds to the jack labelled 'mix +' on the front panel. It should read somewhere between 55 and 110mV, give or take. The null trimpot won't effect this measurement, so just note the voltage. It may bounce around a bit. Just... ballpark it.
4) Measure the test point labelled "+". The null trimpot will effect this voltage so you now have two choices:
4a) Recall the voltage from Step 6 and adjust the null trim until the voltage at TP "+" reads the inverse.
4b) Forget Step 6 and adjust the null trim until the voltage at TP "+" is ~0.00V.
5) You're done with the mixer.
PCB v1.2
- note reversed power regulators & resistor lead jumper in bottom left corner. Not necessary on v1.4 PCBs:
Image Image
Method for connecting the audio input pots - use the same technique for dual-ganged pots with lugs if you're going that route:
Here is a photo guide for the surface-mount section on v1.4 boards:
Here is the pinout diagram for the headers, if you're wiring them up the old-fashioned way:
Last edited by negativspace on Mon Apr 11, 2016 4:20 pm, edited 17 times in total.
negativspace
Manhattan Analog
Schematic, sans SMT section:
Image[/quote]
Last edited by negativspace on Fri Oct 23, 2015 5:13 pm, edited 141 times in total.
sammy123
Post by sammy123 » Wed Apr 16, 2014 9:09 pm
Full set with panel please.
lintfresh
Post by lintfresh » Wed Apr 16, 2014 9:12 pm
In for one set! Been waiting eagerly for this one.
spneca
Post by spneca » Wed Apr 16, 2014 9:13 pm
One full set, please.
qp
Post by qp » Wed Apr 16, 2014 9:47 pm
Add me for 1 set + Panel!
dropmotif
Post by dropmotif » Wed Apr 16, 2014 9:48 pm
One PCB set for me. No panel.
rosch
roadkill
Post by rosch » Wed Apr 16, 2014 9:54 pm
1 full set pcb+panel for me please!
3M-10
Post by 3M-10 » Wed Apr 16, 2014 9:58 pm
Please put me down for 2 full sets of PCB's + Panels.
thanks!
sduck
experimental use of gravity
Post by sduck » Wed Apr 16, 2014 9:59 pm
negativspace wrote:BOM
Resistors:
[0] 100k
Now this is my kind of BOM!
skyshaver
Post by skyshaver » Wed Apr 16, 2014 10:02 pm
I am interested in a pcb and panel set.
lodsb
Post by lodsb » Wed Apr 16, 2014 10:19 pm
I am interested as well, 2x (pcbs + panel) please!
thetwlo
Post by thetwlo » Wed Apr 16, 2014 10:23 pm
2 sets: PCBs + Panel, please.
Beautiful work! Thanks!!!!
Barcode
Post by Barcode » Wed Apr 16, 2014 11:05 pm
One PCB set for me. No panel needed. I've been waiting for this one for a while now. :tu:
mikecameron
Thread Killer
Post by mikecameron » Wed Apr 16, 2014 11:09 pm
I'm in for one.
mDang
Post by mDang » Wed Apr 16, 2014 11:47 pm
Sound great ! And it can do stereo :)
One full set for me please !
Analogeeks
Rigo
Chief Spam Killer
Post by Rigo » Wed Apr 16, 2014 11:54 pm
One full set for me please ... makes my backlog happy :hihi:
regenbot
Post by regenbot » Wed Apr 16, 2014 11:59 pm
one set for me :tu:
qfactor
Post by qfactor » Thu Apr 17, 2014 12:31 am
Me too, negativspace!
I set (pcb/panel) for me!
mcop
Post by mcop » Thu Apr 17, 2014 12:32 am
I'm in for a pcb & panel set
apophis93
Post by apophis93 » Thu Apr 17, 2014 12:34 am
Take my money already! :hyper:
one set.
- Daniel
mxmxmx
Post by mxmxmx » Thu Apr 17, 2014 12:42 am
1 x pcbs + panel, please.
negativspace
Manhattan Analog
Post by negativspace » Thu Apr 17, 2014 12:49 am
mxmxmx wrote:1 x pcbs + panel, please.
Finally I can ship your CP3. It's still sitting here with a note "Wait for SVVCF" :hihi: :deadbanana:
Monobass
thonk.co.uk
Post by Monobass » Thu Apr 17, 2014 12:50 am
1 PCB + panel please
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
