BUILD THREAD: 266-style PCBs
- janvanvolt
janvanvolt wrote:Okay, 1nf soldered in. Everything as it should be - except the quatization. So another working Source of Uncertainty done :-)
So i'm now waiting for the frontpanel and the correction mods for 12V correct quantizing.
To fix quantizer on 12v version, change R46 (on board 2) from 68.1k to 46.4k.
Edit: Also you'd want to change R59 (on board 2) from 60.1k to 75k
I don't have the euro version, so I can't try this out, but I think it should work.
Someone try it out.
-Mike
E.A.S Miss ten series PCBs-----
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
MISS 10/20 LFO/NOISE/S&H,
MISS 20 MINDREADER PCB/POTs.
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
I got my Buchla version mostly up and running, but I'm getting nothing out of the noise source and S&H. I think I may have a bad noise chip, power and ground seem to be getting to the right pins. Also what is to be expected out of the "noisy triangle"? I'm just getting a steady triangle on the scope.
I suspect the triggers from the DIY topp 281 end outs are not good enough to trigger the S&H. Are there resistors I can change for this? My system is only DIY, so I need a little more forgiveness with what the S&H will accept for triggers/gates.
Also I need to upgrade my power supply, the LED's seem to be effecting the pitch of my VCO's.
Sorry for the confusion but are we good to go now on the Eurorack version? What changes need to be done etc? Or are we still waiting on confirmation from Roman? Can someone kindly clarify this for me, reading previous posts would indicate that the 12v version is not working yet pending some alterations, am I correct in this?
Thanks for that. The FRV is giving me something, but it's not very "fluctuating". It just behaves like an LFO and will seemingly lock up at some settings.Luka wrote:(editing post for clarity)
the frv works a bit different to the qrv and srv in that it uses the noise and the 555 for the clock and crazyness. if the noise isnt working i dont think much else will.
the qrv and srv need to be triggered to get an event whereas the frv just runs
The QRV and SRV behave as expected.
I ordered a new noise chip, we'll see if that does it.
Anyone on the S&H triggers? The end outs on the 281 trigger the QRV and SRV, but I get nothing from the S&H.
- janvanvolt
Can anyone verify whether Switchcraft 112AX jacks as per the group buy happening on this list will fit the 5U/MOTM PCBs?
These jacks have solder terminals rather than PCB pins, but Roman's PCBs are clearly intended to accommodate a lug rather than a pin!
I've asked the same question on the group order thread, so apologies for the cross-posting.
Alternatively, does anyone have a UK source for a reasonable (in terms of cost and quality) alternative socket?
Unfortunately, the shipping cost of the Bridechamber sockets plus the likelihood of customs charges makes them a less than economic alternative.
My local supplier, ESR. has some dirt cheap sockets, but the quality is shite...
- ringstone
- antipodean experimentalist
I'd be grateful if you could verify for me that you didn't install these components:janvanvolt wrote:Hi Roman,
did all the changes to R46 and R59 and it seems now everything is correct.
How can i actually verify ? My assumptions are based on various youtube videos comparing against the behavior and results..
D12, D13, IC15, IC14, L4, L3, R44, C14, C41, C40
as well as doing the changes to R46 and R59?
Blair
Question was answered yesterday on the group-buy thread. Go to this page, almost to the bottom. Yes, they fit. Sorry, I don't have an alternate source for you in UK, but I'm sure someone will.jaidee wrote:Can anyone verify whether Switchcraft 112AX jacks as per the group buy happening on this list will fit the 5U/MOTM PCBs?
<marv>
Here you go:marvkaye wrote:Question was answered yesterday on the group-buy thread. Go to this page, almost to the bottom. Yes, they fit. Sorry, I don't have an alternate source for you in UK, but I'm sure someone will.jaidee wrote:Can anyone verify whether Switchcraft 112AX jacks as per the group buy happening on this list will fit the 5U/MOTM PCBs?
<marv>
http://www.rapidonline.com/Cables-Conne ... et-20-1430
A little on what those changes do...
When when looking at the original schematics I saw the reference voltage to the comparators needed to be -5.6v. The voltage divider obtains it reference via a voltage divider hooked between the - rail and ground. Obviously when you change the rail voltage, your reference voltage will be off! When powered from 12v the reference voltage lowers to -4.488. Not gonna work right. With a little simple maths we find the value for R46 needs to be lowered to around 46.4k. (more precisely 46.491k, but the more common value of 46.4k gives -5.606v, still pretty good.)
The next change needed to be changed to bring range of the input back up.
With the quantization knob all the way up, you wouldn't get the full range out of the knob. R59 sets the gain of the quantization input mixer. Because we've lowered the voltage feeding the QRV pot (from +15 rail to +12v), you wont get the full 0 to -6v range you need out of the op-amp output to feed the comparators. So changing R59 to to 75k, gives you the -.5 x gain you need to scale the voltage correctly.
There could be more changes I'm overlooking, but at least these two parts should be changed.
-Mike
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
MISS 10/20/50 VCO,
MISS 10/20 VCF/A,
- janvanvolt
I just followed the instructions for the 15V build, e.g. no PCB cuts,ringstone wrote:I'd be grateful if you could verify for me that you didn't install these components:janvanvolt wrote:Hi Roman,
Blair
some jumpers and R46 and R59 changed. Just got the panel today. Module is now fully finished and working here :-)
- ringstone
Thank you! That reduces the BOM cost by about $15 I thinkjanvanvolt wrote:I just followed the instructions for the 15V build, e.g. no PCB cuts,ringstone wrote:I'd be grateful if you could verify for me that you didn't install these components:janvanvolt wrote:Hi Roman,
Blair
Blair
- numbertalk
- Hunnert Buck
So for correct 12v Eurorack to function we actually need to follow the 15 v (eurorack) installation instructions omitting D12, D13, IC15, IC14, L4, L3, R44, C14, C41, C40
And changing R46 to a 46.4k resistor on Board 2,
also changing R59 to a 75K Resistor again on Board 2.
No traces need to be cut.
Can somebody confirm this for me and Roman if possible can you update the build documents.
Thanks very much in advance.
8_)
8_)
- msprigings
- Veteran Wiggler
