ring mod stompbox
ring mod stompbox
friend of mine was looking to build a stompbox ringmod..she was borrowing a frequency analyzer from somebody and had to return it
she asked me if was aware of any kits or anything to build a ring mod
any tips?
any tips?
as a stompbox? then you would need an internal oscillator, i guess?
what about the MFOS ringmod? it is AD633 based, a classic ringmod. however you wold need to accomodate the input impedance to match guitar levels, i guess. and the PCB may be a little bit on the large side for a stomp box?
anyways: MFOS RingMod (AD633)
Funny you should ask this. I just finished up a small board layout for a ring-mod last night. It uses an LM13700, and is roughly based on the one in the datasheet, and this one here: http://experimentalistsanonymous.com/di ... %20mod.pdf which is a modified version of the one from the datasheet. It's extremely simple, and should work off of a variety of voltages. (though it would need a bipolar supply)
I'm working on a way to use the second half of the LM13700 so it doesn't get wasted though, so a rev 2 is in the works now. (possibly some form of additional CV input or internal oscillator) I'd be happy to share my schematic/board layout for the rev1 if you'd like.
i did one for a friend
half passive one (transformers and diodes)
and a negistor as oscillator one input, and a transistor preamp as the second input for guitar. and a buffer at the output
FX & Modules / http://www.touellskouarn.fr
distortion/tone control?J3RK wrote:I'm working on a way to use the second half of the LM13700 so it doesn't get wasted though
the most important track you'll ever make is the next
https://soundcloud.com/doom_asylum
https://soundcloud.com/wade_blazer
That might be fun. I hadn't thought of that really. I was thinking about either an additional CV function, since the OTA is well suited to this, an internal oscillator, or trying to mimmick the low-noise (distortion cancelling) that is in the FadeX design.RealDudes wrote:distortion/tone control?J3RK wrote:I'm working on a way to use the second half of the LM13700 so it doesn't get wasted though
Adding a bit of distortion or color might be more fun though, and would be something new for me. I typically do everything I can to clean up a signal.
yea thatd be coolJ3RK wrote:Funny you should ask this. I just finished up a small board layout for a ring-mod last night. It uses an LM13700, and is roughly based on the one in the datasheet, and this one here: http://experimentalistsanonymous.com/di ... %20mod.pdf which is a modified version of the one from the datasheet. It's extremely simple, and should work off of a variety of voltages. (though it would need a bipolar supply)
internal oscillator is going to be a must for a box..she was using a ring mod for vocals..my suggestion to her was to build a paia balanced mod, preamp, vca, and really simple diy vco and a plague bearer or something for a tiny little vocal processor but i dunno how invested she is into doing all that
I believe a triangle-wave linear VCO would be extremely easy to build with the other half of the LM13700. (looking at the datasheet, half of the LM13700, an op amp, a cap or two, and some resistors.)vmgas wrote:yea thatd be coolJ3RK wrote:Funny you should ask this. I just finished up a small board layout for a ring-mod last night. It uses an LM13700, and is roughly based on the one in the datasheet, and this one here: http://experimentalistsanonymous.com/di ... %20mod.pdf which is a modified version of the one from the datasheet. It's extremely simple, and should work off of a variety of voltages. (though it would need a bipolar supply)
I have a little bit of work to do tonight, but I'll try to add this if I get a few minutes. Otherwise, I'll post what I have anyway. It would be fairly trivial for anyone to take the tri-portion of the VCO in the data sheet, and hack it in.
http://www.synthrotek.com/store/passive ... 09123bcc3d
The optical theremin as oscillator source might be a really interesting if it's for live use.
Another thing might be cool is making a feedback loop to go into the oscillator in.
Or you could wire up two cheap speakers on to the top and bottom of a wah style pedal and as you pressed down on the pedal they would create a feedback loop.
- monstrinho
Re: ring mod stompbox
There'a a kit here:vmgas wrote:friend of mine was looking to build a stompbox ringmod..she was borrowing a frequency analyzer from somebody and had to return it
any tips?
http://www.delptronics.com/ringmodulator.php
and here:
http://www.paia.com/proddetail.asp?prod=CA-9&cat=14
