i've had some fun trying to interpret the pcb and wondered if anyone else would like to join in. i haven't used the rollz5 or roolz gewei, so i don't know what exactly each section is and can only pick out components by a/b'ing it with the cocoquantus pcb.
here's the labrolz:
going right to left: the right-most side is the 5 channel stereo mixer. it's unclear to me whether these are node-style or 1/4" inputs. i'm assuming nodes, since peter said that there are 7 1/4" inputs on the front of the instrument.
i believe the row of 10 circles are nodes, but can't tell if they're ins or outs.
then, top to bottom, there are a series of four node/ pot combinations (five or six nodes to one pot) with the fifth one at the bottom have either two pots to the five nodes or one pot with an extra pot for ???. no clue what this could be, but the count doesn't seem to match the roolz gewi.
the following sections are flipped and mirrored: four pots, seven nodes, one DPDT switch. i think this may be 2 out of the 4 center sections of the roolz gewei.
center: six nodes, four pots. could be based on the right and left edges of the roolz gewei.
potential other 2/4 center sections of roolz gewei, identical to previous ones.
four pots, nine nodes, two ??? things (circles with thin circle and satellites around them), and one DPDT switch. can't match this pattern to anything.
left-most side: deerhorn? decoration?
what do you guys think? i know a few of you have greater experience with his circuits. i'm wondering what the small banks of 4x4 dots are, along with those two little circular satellites on the left side.
