RC1 radiostar (bluetooth to gate/cv module) update
Support and discussion for soundmachines products.
Moderators: Kent, soundmachines
soundmachines
Post by soundmachines » Fri Aug 31, 2012 4:12 am
Dear All,
just to give some more informations on the module.
The panel design is this:
It will be probably a 24hp module, brushed steel panel.
Main feat:
-16CV OUT (8 * 5V, also V/Hz, and 8* -10 to +10V)
-8 GATES OUT
-Bluetooth 2.0 interface (Android, Windows, Linux, wtf...)
-Bluetooth 4.0 interface (iOS)
-Direct interface between your device and your modular. No PC's.
-LIVE MODE and SEQ MODE distributed among the various outputs. (SEQ mode is synchable to other modular equipment for tight timing).
Some of the updates are:
-It will support OSC over BT (either SPP and Low Energy application profile, to have on board either Android (or WIN, or what else...) and iOS).
(we will keep also another 'lighter' protocol, just to save bytes..)
-It will have the choice (hardware) to choose between 5V and hotter 12V gates output
-It will have an expansion connector, to connect other 'medium' in the future.
And finally, this is the initial UI design of the app (for now we are testing it on a NEXUS phone, but it will support ANY Android 4.0 tablet or handset.
iOS app is also under construction.
Some quick notes on the functionalities.The screenshot relates just to the LIVE features, there is a whole another world related to the SEQUENCER features, that could be mixed between the 16CV's and 8 GATEs).
-The actual screenshot is the most simple, 8 gates button (momentary) on the bottom of the screen, to trigger everything you want (from envelopes, to drums, to loopers...), and 8 CV sliders EACH one of which has it's own record/play buttons...
YES, press the R button and the movements will be recorded until you press the P button, when the RC1 starts looping the CV until you stop it.
-Have a look at the tabs on the top of the screen. We have (among many others) the possibility to pop up a chromatic keyboard with pitchbend and mod wheels (a fuc*ing tiny cv keyboard, maybe also polyophonic, that is :)) OR an X-Y pad with GATE signal related to z-axis accelerometer 'bumps'.
-The app will comprise lot of things but NOT everything. We will disclose the protocol and the OSC address space to have others write apps and augment the object that could relate to your modular.
YOU LIKE?
Matos
Modular masturbator
Post by Matos » Fri Aug 31, 2012 4:36 am
I love. :hyper: :love:
How much and when?
mono-poly
Le Cheff
Post by mono-poly » Fri Aug 31, 2012 6:47 am
:love: Want!
The farad is the captain of my print.
http://www.mono-poly.nl
http://www.noodlebar.org
WTB blue lantern purple vco
numan7
the most autistic amongst us
Post by numan7 » Mon Nov 19, 2012 1:59 am
:eyes:
any updates on this?
cheers
"all the clouds turn to words. all the words float in sequence. no one knows what they mean. everyone just ignores them..."
soundmachines
Post by soundmachines » Fri Nov 23, 2012 4:09 am
Hi to everyone, we were very busy in many other projects (spesonline.com acts in a lot of markets!!!) but we have some juicy advancements here.
In a couple of weeks we will have two protos of the RC1 to start testing some firmware. The product *is* complex and we tried to avoid another PCB. We managed to squeeze everythig in 28 HP, instead of the 24 that we talked about. Please have a look at its new 'face' (it's just a drawing):
Other than that we made lots of improvements in the Android base app and we started porting it to iOS.
I think that it will be LOTS of fun.
We also defined two expansions, one MIDI input and one Ethernet input (OSC). The product will be field-upgradable with a microSD card.
Hope this is a good update!
:bacon:
soundmachines
Post by soundmachines » Fri Nov 23, 2012 7:05 am
The website is on line!
There are some new exciting modules and some descriptions!
Please come to have a look and leave your comments.
The site is not yet fully operational (no shop yet!) and under construction!
http://www.sound-machines.it/
:banana:
whitewulfe
Chaos beckons, I heed the call
Post by whitewulfe » Fri Nov 23, 2012 8:04 am
Any word on the posible 5U version you had mentioned several months ago? ^_^
soundmachines
Post by soundmachines » Wed Dec 12, 2012 6:17 am
whitewulfe wrote:Any word on the posible 5U version you had mentioned several months ago? ^_^
We did not succeed in designing a single PCB (we thought of putting jack AND connectors on the same footprint but nope...) for the two versions.
At this point, when the RC1 is up to work (I should receive protos by the end of this week!) I will call for interest in the 5U version and manage a run of "wired" panels.
The +-15V power supply rails are not a problem!
krunkleKick
Post by krunkleKick » Mon Jan 21, 2013 2:16 pm
This is going to be epic. You should think about a standalone version!
People would lap this up!
madcap
Cactophile
Post by madcap » Fri Apr 19, 2013 10:31 pm
position sensing keys would be sweet. Like animoog but bigger.
Can't wait
soundmachines
Post by soundmachines » Sat Apr 20, 2013 1:18 am
madcap wrote:position sensing keys would be sweet. Like animoog but bigger.
Can't wait
You mean this?
Producing 150 of those right now, along with 100 robotto...
soundmachines
we play synthesizers !
soundmachines
Post by soundmachines » Sat Apr 20, 2013 1:21 am
Can't wait
Also, the RC1 is under completion, we are coding the 'startup' application for iPad (the Android one is OK) and we are writing the 16 tracks sequencer core!!!
When the first step is done we will release and sell the product, then you can upgrade it with a microSD card!
Davide
soundmachines
krunkleKick
Post by krunkleKick » Fri May 03, 2013 6:59 am
:yay:
Looking forward to seeing this!
soundmachines wrote: Also, the RC1 is under completion, we are coding the 'startup' application for iPad (the Android one is OK) and we are writing the 16 tracks sequencer core!!!
Davide
soundmachines
Post by soundmachines » Sun May 05, 2013 7:39 am
krunkleKick wrote::yay:
Davide
is coming is coming......
check back on our website soon!!!!
Cheers, Davide
soundmachines
djthopa
Post by djthopa » Mon Jul 08, 2013 6:24 pm
Ciao! :hail:
soundmachines
Post by soundmachines » Mon Jul 08, 2013 6:34 pm
djthopa wrote:Ciao! :hail:
Ciao!
(ps love your avatar!)
soundmachines
djthopa
Post by djthopa » Mon Jul 08, 2013 6:37 pm
Hi, i cant believe i have missed your modules, very interesting to say the least. Can the radio star produce chords? I mean 3 oscillators getting different tunings? Could the sequencer do this?
Graccie
soundmachines
Post by soundmachines » Mon Jul 08, 2013 6:42 pm
djthopa wrote:Hi, i cant believe i have missed your modules, very interesting to say the least. Can the radio star produce chords? I mean 3 oscillators getting different tunings? Could the sequencer do this?
Graccie
Please have a look at this videos!
http://www.sound-machines.it/?page_id=35
also, some other posts on muff!!!
ciao!
soundmachines
alamandra
Post by alamandra » Fri Sep 19, 2014 12:45 pm
Hey, I'm wondering if you have tested the radiostar on a kindle fire hd, that's if it would even work on it, it is an android device but I don't think it's quite the same as normal android o.s.
I'll volunteer my device for testing purposes if you can't get hold of one, if it's something you ever intend to test the rc1 with that is.
Shiney metal module shirt
bkbirge
Post by bkbirge » Fri Dec 05, 2014 9:32 pm
Is this out? I see it being offered on ebay by at least one dealer but the homepage still says not released.
Modular & Dork Rock:
https://bkbirge.bandcamp.com/
Racks:
https://www.modulargrid.net/e/racks/view/88730
https://www.modulargrid.net/e/racks/view/89177
https://www.modulargrid.net/e/racks/view/379579
"The person who says it cannot be done should not interrupt the person doing it." ~ Puck, 1903
soundmachines
Post by soundmachines » Tue Dec 09, 2014 8:24 am
YEAH! bot the product and the iOS app are available!
We have to update the site's pages!!!!!!!!
soundmachines
bkbirge
Post by bkbirge » Tue Dec 09, 2014 10:04 am
IOS only right now? When will other platforms be ready?
Racks:
bezier
Post by bezier » Wed Dec 17, 2014 3:21 pm
soundmachines wrote:YEAH! bot the product and the iOS app are available!
Where can i find it on the app store?
soundmachines
Post by soundmachines » Thu Dec 18, 2014 5:07 am
Tue app is named RC1, just search this or soundmachines.
There is ah Android all that currently supports just the live modes. Soon Wiki be published. Probably to have it complete we will need another couple of months.... Or we can handle the source code to a fellow wiggler coder along with a free RC1.... :)
soundmachines
timmmofa
Post by timmmofa » Thu Mar 19, 2015 4:17 pm
is there already information on osc? i would LOVE to hook this up to max/msp and go wild ....
Return to “soundmachines”
