OMG WOW AND THANKS
Moderators: Kent, grantrichter, carygrace
hpsounds
the french icelander
Post by hpsounds » Thu Aug 30, 2012 1:45 pm
:wiard:
:wow: :clap: :loves:
You deserve it Mike !
Hédi K.
jeannot
Ghost Beach
Post by jeannot » Thu Aug 30, 2012 1:53 pm
Congrats Mike! Gorgeous system!
miditerranean
Post by miditerranean » Thu Aug 30, 2012 2:53 pm
Really really nice, Mike! Be sure to take some pics of it by the BugBrand too :hail:
carygrace
If I had two dead rats, I'd give you one
Post by carygrace » Sat Sep 01, 2012 6:16 am
Babaluma wrote:Was it also designed by the Telomere dude (Chris MacDonald)? His label is also called Evenfall, and I love his music.
Yes, as I understand it, Chris MacDonald took the project to Grant to finish the design.
el clon
Post by el clon » Sun Sep 02, 2012 3:55 pm
beautiful. :sb:
that case is so luxurious... it reminds me of James Bond for some reason,
like Sean Connery should be rocking that thing. or maybe Goldfinger...
jdkee
Post by jdkee » Sun Sep 18, 2016 9:59 pm
Resurrecting an old thread but I wanted to add just how visually beautiful the modules and the case look. It looks like a beautiful instantiation of technology as art, not utilitarian but an artistic endeavor in and of itself. This system is a one-of-a-kind instrument.
Mike, how does it sound to you when you use it? It looks fairly comprehensive, do you add in external modulation or sound sources? Any advice for someone starting out with a 6 module Wiard system in 2016?
Best,
Justin
Graham Hinton
Post by Graham Hinton » Mon Sep 19, 2016 5:50 am
jdkee wrote: Mike, how does it sound to you when you use it? It looks fairly comprehensive, do you add in external modulation or sound sources?
He didn't use it, he sold it.
The system now resides in Darkest Avalon where I had to rebuild the power and grounding to make it conform to safety standards and to be usable with other instruments.
Don't waste money on a custom case before you know what you are doing and what you really need. You will change your mind, the only variable is how soon. Often this is before the case is even finished.
jdkee
Post by jdkee » Sat Oct 01, 2016 10:02 pm
Wow, that is a visually beautiful system. I imagine it sounds amazing. Enjoy.
I agree about the custom cases. I have about a dozen modules now and have worked up some handmade wooden rack ears just to hold the racked modules. My woodworking skills are nowhere near Goikes skills but they work.
Graham, would you make a switchmix/modmix module in 6U format? I'm not sure if there is sufficient demand to justify tooling in the 6U format as opposed to euro. Just curious.
eef
Cardiganed Beardy
Post by eef » Wed Oct 05, 2016 6:03 pm
Alternatively, pick a custom case as early as possible, so you get a small case, so you fill it quickly, so you don't waste time researching new modules, and instead get on with working with what you have.
:hide:
Return to “Wiard”
