Harvestman: Double Andore Available at AH
Digital Audio Electronics - discussion & support.
Moderators: Kent, governor blacksnake, solidox
Post by ignatius » Tue Dec 14, 2010 9:58 pm
update: AH link.
http://www.analoguehaven.com/theharvest ... bleandore/
saw this on matrixsynth
http://matrixsynth.blogspot.com/2010/12 ... ndore.html
also upcoming per his site:
- model r1983 polivoks vco
- "devil core" 7HP DSP effects [2010]
afterwards: homicide censor, double andore, high-resolution granular processor, guitar pedals
qu.one
hypnotic and sanctified
Post by qu.one » Tue Dec 14, 2010 10:23 pm
The VCO and DSP and pedal stuff has been up for a while - but this double EG as piqued me bloody interest.
Qu.One Instagram
Qu.One Bandcamp
Qu.One on YouTube Music
Oldstench
Post by Oldstench » Tue Dec 14, 2010 10:28 pm
Holy shit.
Humanity has doomed itself.
HeWhoWantsJeans
Post by HeWhoWantsJeans » Tue Dec 14, 2010 10:28 pm
After reading the Guv'nor post in the thread about this in the EuroRack section, I have to ask:
Is the ENV a CV output of the entire cycle (AR, AHR, LFO)?
I've archived over 400 answering machines, and the best of which is constantly updated on Tumblr. Public domain! Enjoy! Donate, too!
http://answerphone.tumblr.com/
Johnisfaster
Post by Johnisfaster » Tue Dec 14, 2010 10:44 pm
The backwards wording on the left side does my head in.
JensenJohn.bandcamp.com
Entrainer
Post by Entrainer » Tue Dec 14, 2010 10:46 pm
I AM TEH WAJ!
5,159 custom drum samples for electronic music
made from 4 modular systems, drum modules, and some nice analog outboard processing
202 Instruments for Ableton Live/Push (128s), NI Kontakt, and Logic EXS24
41 Kits for NI Maschine, FXPansion Geist, Ableton Drum Racks, and Octatrack Sample Chains
http://www.drivenmachinedrums.com
HeWhoWantsJeans
Post by HeWhoWantsJeans » Tue Dec 14, 2010 10:49 pm
Johnisfaster wrote:The backwards wording on the left side does my head in.
If the knobs are reversed too (CCW, with the right side being CW), it might force my interest out the door, sadly.
Kakihara
Post by Kakihara » Tue Dec 14, 2010 11:14 pm
Personally the mirrored side makes it seems easier to work with!
Post by ignatius » Tue Dec 14, 2010 11:29 pm
Kakihara wrote:Personally the mirrored side makes it seems easier to work with!
i think my brain likes it as well. for some reason the muscle memory for my hands probably will like it as well. i think it makes more sense to turn side by side knobs in opposite directions to mirror the same result.
qu.one wrote: The VCO and DSP and pedal stuff has been up for a while - but this double EG as piqued me bloody interest.
yeah i know but i thought i'd just throw it in the thread as a reminder of future awesomeness.
i think it's because i've been falling in love again and again w/the HD. really impressed w/it. goes way beyond what i expected.
Johnisfaster
Post by Johnisfaster » Tue Dec 14, 2010 11:36 pm
aw I didnt think about that, that would be not so good.. for me anyway.
Can anyone point out to me the glaring differences between this and Maths?
reignbear
Post by reignbear » Tue Dec 14, 2010 11:51 pm
i too hope the knobs are mirrored, i think it would be really awkward if they all moved the same way on a mirrored/symmetrical design.
regarding the differences from the maths, here is some info straight from the source:
governor blacksnake wrote:Here's how it works:
Both left/right sides of the module are identical from the factory.
The top section is an AD envelope generator with EOA and EOD outputs too. There is one CV input with attenuator that can be assigned to attack time, decay time, curve shape, or any combination of the three. The freeze input holds the envelope in its current position. The Mirror input flips it upside down, keeping it in the 0-8v range.
The shape control lets you select one of 16 curves. The nearby knob selects the curve, and it can optionally do a piston-style interpolation between adjacent curves (just in one dimension).
The envelope can run in AD, AHD, and LFO mode. I'm also working on a bonus mode that lets you use the CV input to shape an incoming CV using the onboard curve tables.
The envelope output is normalled to the control input of the bottom section which is a VCA. You can select linear or log response for the CV, and also assign the VCA on the other side of the module to modulate it too.
The lower jack in the center is a mix of the two VCA channels, and the one on the top of the module is a sort of maximum circuit that lets you make more complicated envelope shapes - the knob adjusts the balance between the two sides
The envelope shapes can be written with the wave256 software, and you can have different curves for each side of the module if you write it that way.
taken from the other thread
viewtopic.php?t=26238
so basically built in VCAs, customizable morphable shape wavetables and some other tricks.
:deadbanana:
HeWhoWantsJeans
Post by HeWhoWantsJeans » Wed Dec 15, 2010 12:00 am
reignbear wrote:i too hope the knobs are mirrored, i think it would be really awkward if they all moved the same way on a mirrored/symmetrical design.
The MATHS is a symmetrical design and I don't have any problem understanding the correlation between motion on any of the channels. Also, since every single piece of gear I've ever put my hands on works as 'clockwise motion = increase in value', I'd say that having the left channel of the Andore to be functionally inverse would drive be wacky.
MrBiggs
I see dead people
Post by MrBiggs » Wed Dec 15, 2010 12:05 am
I like it, but it kind of makes me want to buy regular ol' Doepfer again.
:oldmanureuro::oldmanureuro::oldmanureuro::oldmanureuro::oldmanureuro::doepfer:
•Music and stuff: Dance Robot Dance.
•Current contents:Modulargrid
Post by ignatius » Wed Dec 15, 2010 12:10 am
HeWhoWantsJeans wrote: Also, since every single piece of gear I've ever put my hands on works as 'clockwise motion = increase in value'
envelators aren't.. unless you mean "increase the decrease in attack/decay time" :razz:
Johnisfaster
Post by Johnisfaster » Wed Dec 15, 2010 12:31 am
reignbear wrote: so basically built in VCAs, customizable morphable shape wavetables and some other tricks.
:deadbanana:
Oh good, another module I can live without! :) a couple of those intelijel modules are must haves, but I've seen a whole bunch of announced modules that don't strike my interest at all and that's a good thing.
rico loverde
Post by rico loverde » Wed Dec 15, 2010 12:51 am
I'm getting overwhelmed by all the new releases... Is it like this every December in the euerorack world? Time to rob a bank.
works for Darkplace Manufacturing
elsuturo
Post by elsuturo » Wed Dec 15, 2010 2:42 am
rico loverde wrote:I'm getting overwhelmed by all the new releases... Is it like this every December in the euerorack world? Time to rob a bank.
is this you? :)
- great job! -
rico loverde
Post by rico loverde » Wed Dec 15, 2010 2:52 am
is this you? :)
Shhhhhh!!! Still trying to fig out where to cash them in at.
DrOctave
Post by DrOctave » Wed Dec 15, 2010 2:54 am
fuckin awesome. god this year will make me fuckin poor. the year comeing in euro rack has made me push my buchla lust to the curb..
It's beter to have cords and not need them than to need them and not have them.
http://www.youtube.com/user/DrOctave1?feature=mhum
elsuturo
Post by elsuturo » Wed Dec 15, 2010 3:27 am
rico loverde wrote:
is this you? :)
just not all at once i'd say :tu:
- great job! -
Veqtor
Post by Veqtor » Wed Dec 15, 2010 4:01 am
Whoa, I think this will replace the maths for my enveloping duties, looks really nice! :tu:
(will keep the maths for glide and such though, don't go looking in bst just yet ) :hihi:
Carci
Post by Carci » Wed Dec 15, 2010 5:22 am
Slightly off topic but...
Where is the new Tyme sefari ?
Seeing all these great forthcoming modules from The Harvestman starts to make me feel like the good old discontinued ones will never be back =(
lionelfischer
Post by lionelfischer » Wed Dec 15, 2010 6:54 am
I think I read somewhere earlier tonight that he is going to try and get the new TS going soon now ? on his twitter or somewhere on the boards here
worker8
Post by worker8 » Wed Dec 15, 2010 7:33 am
21 HP ?
boramx
lepidopteran orgasm
Post by boramx » Wed Dec 15, 2010 10:05 am
very curious about the "shapes" as well as frequency range.
i've puts envs through bit crushers before going into VCAs used for audio. nice glitchy attacks and warbly, gargly sounds. digital envs seems like a good thing, though of course vanilla curves in addition to steppy/wonky ones would make this versatile.
i am eager for sound examples and more details when the time comes...
Return to “The Harvestman”
