HERTZ DONUT MARK III - shipping now!
Digital Audio Electronics - discussion & support.
Moderators: Kent, solidox, governor blacksnake
rnordac
Post by rnordac » Tue May 21, 2019 7:15 pm
sorry to be that person again but I noticed a funny behavior in fw 1.5, tune the main oscillator to 188hz or higher and set the fm ratio on either operator to x16, when you introduce fm you get an unexpectedly slow modulation, like a slow lfo instead of x16 audio rate. I rebooted the module and still get this, anyone who has updated let me know if you are noticing this.
It actually sounds pretty fun but obviously you wouldn't want this happening under normal circumstances :)
edit: the other updates are really good as someone mentioned above, fm sounds great and surprisingly clear with resonance and phase distortion
rnordac
Post by rnordac » Tue May 21, 2019 11:12 pm
Maybe I'm wrong about this being a new or unexpected behavior - this is a redundant post
Arcade Sinusoid
Post by Arcade Sinusoid » Wed May 22, 2019 2:26 pm
Yes just updated mine and I am getting this also. 187 Hz
mt3
Post by mt3 » Wed May 22, 2019 7:16 pm
rnordac wrote:sorry to be that person again but I noticed a funny behavior in fw 1.5, tune the main oscillator to 188hz or higher and set the fm ratio on either operator to x16, when you introduce fm you get an unexpectedly slow modulation, like a slow lfo instead of x16 audio rate. I rebooted the module and still get this, anyone who has updated let me know if you are noticing this.
I sent in a bug report for you.
rnordac
Post by rnordac » Wed May 22, 2019 10:24 pm
cool, thanks! wasn’t sure if it was a bug or if i was missing something
rnordac
Post by rnordac » Thu May 23, 2019 10:33 am
Voggg
Post by Voggg » Mon Jun 03, 2019 3:47 pm
I spent a long time on a complex "noise" patch yesterday and then broke it down to something much simpler with better results. The sound is just Hertz Donut and Morphagene.
https://soundcloud.com/timelovr/june-3rd-noise-part-3
dysonant
Post by dysonant » Tue Jun 04, 2019 7:18 am
dysonant wrote:Hello all, an update to my earlier post about fast envelopes.
I wrote to IME about the issue I am experiencing with the HD MKIII. I am paraphrasing the response to please forgive me if it is not entirely accurate. They have confirmed that this behavior is expected an intentional. There is somewhat heavy filtering on the CV inputs. The throughput is kept low to ensure good operation on bad power supplies. This seems to impact the sampling rate for CV inputs.
It is my personal hope that a future firmware update will find a way increase the sampling rate on the CV inputs to accommodate for very fast envelopes.
I am sure most of you know by now that a new firmware was released to address this behavior. I have tested a little bit to see if transients are improved and they certainly are. I still need to test it a bit more, but the lag is most certainly improved.
Ras Thavas
Post by Ras Thavas » Wed Jun 05, 2019 6:17 pm
Wow, quite liked that! Would enjoy hearing more about the patch and how you manipulated it.
Voggg wrote:I spent a long time on a complex "noise" patch yesterday and then broke it down to something much simpler with better results. The sound is just Hertz Donut and Morphagene.
Voggg
Post by Voggg » Thu Jun 06, 2019 8:44 am
Ras Thavas wrote:Wow, quite liked that! Would enjoy hearing more about the patch and how you manipulated it.
Thanks! I started with a bigger patch that included some drum modules being manipulated (possibly Malgorithm) and fed to Morphagene. The next day there were maybe 4 seconds of stereo audio from that left in the buffer. I put the main and aux XOR out from HD into a switch controlled by the Planar button and put the out from that into Optomix. CV out from Morphagene to CV in on HD, EOS trigger out from MG to strike on Optomix, so that the sampled audio was "playing" the HD. Then I just used Planar and tweaked. I think I opened & closed the Optomix manually and then mixed the audio MG L & R with HD center.
Voggg
Post by Voggg » Sat Jun 08, 2019 2:12 pm
HD3 featuring Zuckerberg:
temaniak
Post by temaniak » Thu Jun 13, 2019 7:38 am
Russian overview.
yeatsvisitslincoln
Post by yeatsvisitslincoln » Sat Jun 15, 2019 4:25 pm
I finally got a chance to measure the current draw on this since the power specs have never officially been released. That Joranalogue tester is super convenient, for the record...
Power:
+12: 150 mA
-12: 50 mA
+5: 0 mA
I also updated specs on ModularGrid.
synonymist
Post by synonymist » Sun Jun 16, 2019 7:34 pm
synonymist
Post by synonymist » Mon Jun 17, 2019 6:51 pm
Sinamsis
Post by Sinamsis » Mon Jun 17, 2019 8:20 pm
Slowly learning to dial in more nuanced sounds with HD mk III. Here it's doing the droning chords.
synonymist
Post by synonymist » Mon Jun 17, 2019 8:42 pm
Sinamsis
Post by Sinamsis » Mon Jun 17, 2019 8:49 pm
synonymist wrote:
Sinamsis wrote:Slowly learning to dial in more nuanced sounds with HD mk III. Here it's doing the droning chords.
Very nice. Is that the HD audio alone or processed? I ask because it sounds spatial to me.
Oh no, ha it's got some Magneto on it too.
synonymist
Post by synonymist » Mon Jun 17, 2019 9:12 pm
Crimesofthecrown
Post by Crimesofthecrown » Thu Jun 20, 2019 10:22 am
I recently got it and I have already fallen in love with it big time. Here is a track that I used the Hertz Donut as a lead on. The lead drops in at the 1:06 mark. The percussion is a Piston Honda MKIII (run through clouds) trading off with a nebulae and its samples.
GOD IS WAR - Curator of Hyper-Violent Industrial and Heavy Electronics
synonymist
Post by synonymist » Sat Jun 29, 2019 4:09 pm
synonymist
Post by synonymist » Sun Jun 30, 2019 6:07 am
synonymist
Post by synonymist » Sat Jul 06, 2019 10:15 pm
synonymist
Post by synonymist » Sat Jul 13, 2019 12:54 am
Return to “The Harvestman”
