chiavere wrote:Hi -
Are the grooves narrow enough to support smaller-barreled cables like those made by control, black market, etc.?
HEX-01 eurorack cable hanger
I haven’t used those so I’m not sure - but I would say it’s well worth your while to pick up sample cables from control, black market, and lmntl to test with it, because if you can make a “rack to rule them all” that can handle standard euro, small barrel euro, tiptop stackables and Pomona banana cables, I think they will sell like gangbusters - I would buy two!jjmcclear wrote:The Pittsburgh noodles hang fine. I have a lot of those. Are the smaller than that?
chiavere wrote:Hi -
Looking forward to seeing this develop, and to supporting your work!
- jjmcclear
- Wiggling with Experience
- Contact:
Thank you for your input!
All slots are approximately 4.788 mm wide. Many eurorack cables run about 3.5mm, but can vary slightly depending on the casing. I would suggest visiting your manufacturer's website, to confirm the width of your cables.
There will be plenty of rewards available that won't include a limited edition t-shirt. No worries!
Thanks again!
Kind Regards
Jesse
Kind Regards
Jesse
chiavere wrote:I haven’t used those so I’m not sure - but I would say it’s well worth your while to pick up sample cables from control, black market, and lmntl to test with it, because if you can make a “rack to rule them all” that can handle standard euro, small barrel euro, tiptop stackables and Pomona banana cables, I think they will sell like gangbusters - I would buy two!jjmcclear wrote:The Pittsburgh noodles hang fine. I have a lot of those. Are the smaller than that?
chiavere wrote:Hi -
Hi - ok, great - 4.788mm should cover all the smaller barreled cables - my Koma kablehanger works with them, and in my unscientific measurement of its slots, it is a little wider than that.jjmcclear wrote:Thank you for your input!
- jjmcclear
- Contact:
It's hard to make something that would cover every option, but... if things take off, I might consider a couple versions for larger cables. Including one for the 1/4 inch modular users.
Thanks again for your feedback.
Regards,
Jesse
Regards,
Jesse
chiavere wrote:Hi - ok, great - 4.788mm should cover all the smaller barreled cables - my Koma kablehanger works with them, and in my unscientific measurement of its slots, it is a little wider than that.jjmcclear wrote:Thank you for your input!
- Plugler
- Common Wiggler
Great idea! I want at least one of these nice pieces too!
Waiting on your Kickstarter campaign...
I will mount it from top, maybe from the ceiling or from the wall or my workshop shelf.
Just yesterday I ordered two of these: https://www.conrad.de/de/voltcraft-ml-1 ... 00821.html
They seem to be identical to the Pomona 1508, which are hard to get in Germany.
But your design is much better for my needs.
I wonder why it's so hard to get good cable holders? But soon there will be yours!
- jjmcclear
- Contact:
Thanks for writing!
You should be able to hang the HEX-01 from the six outer holes. I’d recommend that over hanging it from the center. Unless you’re mounting it with something fixed. At least then it wouldn’t swing, or go off balance when taking cables off of it.
Hoping to have the kickstarter page up very soon!
Kind Regards
Jesse
Kind Regards
Jesse
Plugler wrote:Great idea! I want at least one of these nice pieces too!
- Plugler
- Common Wiggler
Back in the 80's the Macramé plant hanging design was modern. That would fit well with the vintage synthesizers that some wigglers have around.JohnLRice wrote:Also, 4 or 6 eye-bolts could be attached to the outer holes so that it could be hung from the ceiling? Either attaching to two individual ceiling points for stability or I suppose all going to a single point for simplicity? Maybe using "swag hooks" typically used for hanging plants and light fixtures?![]()
- jjmcclear
- Contact:
latest
I just received the final CAD file, for the hanger. I made some minor adjustments, to make it a bit sturdier. I'll be having four laser-cut steel prototypes made this week. I'll be shipping one off to DivKid Ben for fun little video review. I'll also be creating a proper demonstration video for the Kickstarter page. Other than that, the KS page is pretty much set to go.
- soon_come
- Contact:
I want this even more now. Cool CAD drawing, thanks for sharing.
https://soonco.me
(dub and dancehall gone modular)
FS (US / NYC): CV.OCD, MIDI thru / splitter box, MIDI interface, more...
- jjmcclear
- Contact:
prototypes
After a bit of going back and forth on the CAD file... they were finally able to cut some prototypes, today. I'll be cleaning these up and giving them a coat of paint. They don't have the raised center bevel just yet, as the tool and die bit is costly. That will be on the final version if all goes well.
I did bring the slot out just a tad for stability's sake. The 3D resin print was so flimsy, it concerned me. So it may fit a few less cable than before, like 312 vs 360. OF course that will also depend on your cable brand, and their end housings.
The shop sent me this photo
Re: prototypes
Any chance the end product could be powder-coated instead of painted? Just thinking for long-term durability powder-coating tends to be better; but don't know how much that would affect the cost.jjmcclear wrote:After a bit of going back and forth on the CAD file... they were finally able to cut some prototypes, today. I'll be cleaning these up and giving them a coat of paint.
- jjmcclear
- Contact:
Re: prototypes
"The final product will be made out of steel, with a black textured powder coat."
Yes, the final product will have a textured black powder-coat. I'm just painting the test prototypes, so that they look nice for the demonstration videos. The final product will be much nicer looking. I just had these four made for testing, before a final production run.
luchog wrote:Any chance the end product could be powder-coated instead of painted? Just thinking for long-term durability powder-coating tends to be better; but don't know how much that would affect the cost.jjmcclear wrote:After a bit of going back and forth on the CAD file... they were finally able to cut some prototypes, today. I'll be cleaning these up and giving them a coat of paint.
- jjmcclear
- Contact:
they came!
Just received the prototypes! Please excuse the video quality.
- Common Wiggler
These look great. I had an idea of stacking two on the same stand. Top hanger holds the shorties, and a foot lower, that hanger holds the long ones. Now to source a mic stand extension.
I was also thinking of drilling 4 holes around the center mounting hole to secure a raised dish to hold mults and such.
Anyway, can’t wait to back this... the neighbor kid can get his own damn stickers.
- jjmcclear
- Contact:
Thank you, I'd really appreciate that!
The success of this hanger will help ensure the future of this startup company. I have a number of eurorack related accessories, in the hopper.
Would love to see everyone's photos, once they have their hangers. There's a few social media pages setup for eurodesk-z. Once you get your hanger.. Tag me, and I'll feature your pics!
Thanks again!
https://www.instagram.com/eurodeskz/
https://twitter.com/EurodeskZ
https://p.facebook.com/eurodeskz/
https://www.eurodesk-z.com
Thanks again!
Buyakasoundman wrote:These look great. I had an idea of stacking two on the same stand. Top hanger holds the shorties, and a foot lower, that hanger holds the long ones. Now to source a mic stand extension.
Following, as very interested in 1 or 2 of these. Like the idea of 2 levels.
Monday Night Modular - a weekly virtual meetup @ 8pm PT
