What is a midi interface
vqlk
Post by vqlk » Sat Jun 13, 2020 8:12 pm
Especially, would any of them record sequences from a PC, and if so can the sequence be cv triggered?
i'm out, go circle someone else's corpse.
GuyaGuy
Re: What is a midi interface
Post by GuyaGuy » Sat Jun 13, 2020 8:26 pm
An interface is just a way to get MIDI information into and out of your computer. Since it often has multiple ins and outs it can route to more devices and avoid some latency issues that come with linking devices using MIDI thru. It does not record but can feed MIDI information into your DAW which can record it.
oranginafiend
Post by oranginafiend » Sat Jun 13, 2020 8:29 pm
it got da midi ports
Licudi
Post by Licudi » Sun Jun 14, 2020 3:11 am
A modest yet alluring skirt hiding the knees but displaying the calves and ankles to full effect.
vqlk
Post by vqlk » Sun Jun 14, 2020 5:10 am
i remember that catalogue :D
Rex Coil 7
Post by Rex Coil 7 » Sun Jun 14, 2020 6:52 am
.. given the choice between conformity and self respect, I choose the latter.
.. dominion - noun: control or the exercise of control . power . possessed and controlled domain . sovereignty . having dominion over the world . supreme authority . absolute ownership . power . authority . jurisdiction . control . command ... power ....... power .......... power.
tigersi
Post by tigersi » Sun Jun 14, 2020 6:58 am
Are you asking if you can send a sequence from your computer to your modular? Or the opposite way round?
If you wanted to send a sequence from your PC to your modular then an interface would assist this However, you would still need a module to assist this.
Doepfer do a relatively cheap one. A-190-2. There’s tons of others out there
Expert sleepers also enhanced versions of it. I don’t own one but I believe the ES8 audio interface is good. This would then allow for the sequence on your PC to be triggered in your Modular land.
Anyone chime in if I’m incorrect.
Education is the kindling of a flame, not the filling of a vessel.
We don't make mistakes, we just have happy accidents.
vqlk
Post by vqlk » Sun Jun 14, 2020 7:02 am
i was hoping to send midi to my modular, but clock the midi sequence with CV. i do not know why that would be at all impossible... even if you need two cables :D
i also wondered if any midi interfaces would record from a pc, so that i don't need to run a computer while converting its midi out to cv.
tigersi
Post by tigersi » Sun Jun 14, 2020 7:17 am
I’m not aware of any interfaces that record without a PC.
vqlk
Post by vqlk » Sun Jun 14, 2020 7:42 am
tigersi
Post by tigersi » Sun Jun 14, 2020 7:53 am
Just to try and clear things. This is a midi interface (the one I use)
This is also a midi interface
This connects to the interface above to talk to the computer, whist at the same time also talks to the modular setup. Does this make sense?
vqlk
Post by vqlk » Sun Jun 14, 2020 7:54 am
yes, ofc.
do i come off dimwitted??
Muzone
Post by Muzone » Sun Jun 14, 2020 8:04 am
I'm not sure if it's what you mean, but Arturia beatstep pro can save (short) MIDI sequences from a PC, send them over CV or MIDI in standalone mode, and is also clockable via CV.
vqlk
Post by vqlk » Sun Jun 14, 2020 8:08 am
cool, thanks... i tried googling this for like an hour or two and nothing
how short?
tigersi
Post by tigersi » Sun Jun 14, 2020 8:09 am
yes, ofc.
No, I was trying to answer your question or at least help
vqlk
Post by vqlk » Sun Jun 14, 2020 8:11 am
yes, ofc.
ok yeah, sorry the tone was cool -- just the content seemed really simple ha... thanks :party:
mritenburg
Post by mritenburg » Sun Jun 14, 2020 8:38 am
You may want to consider a CV to MIDI interface, or a DC coupled audio interface, used in conjunction with a DAW like Ableton Live. You can trigger clips and sequences in Ableton Live In real time using CV and gate/trigger produced by your modular.
Disappointment with any module is usually a failure of imagination.
a loose reference
Muzone
Post by Muzone » Sun Jun 14, 2020 8:39 am
how short?
A pattern may be up to 64 steps and you can have 16 projects that contain up to 16 scenes each allowing you to chain up to 16 patterns for each of the 3 sequencer tracks.
So a scene can be a chain of up to 1024 steps, and your project can have 16 of them - not a 'song mode' as such, but plenty of patterns to jam around with within a single project
vqlk
Post by vqlk » Sun Jun 14, 2020 8:53 am
cool.
3 sequencer tracks
does each track have gate cv and velocity? the lpwz tram 8 would then combine with the beatstep pro for for an 8 midi to cv sequence of up to 1024 steps? i mean, sorry i'm new to this :guinness:
Muzone
Post by Muzone » Sun Jun 14, 2020 9:27 am
1 sequencer track is a drum track so just has 8 gate outs, the other two are monophonic with gate, velocity and pitch
flashheart
Post by flashheart » Sun Jun 14, 2020 9:37 am
So, if you want to record MIDI then play it back clocked this may do the trick - if you can understand it. It'll probably make coffee too...
I think your thread title is somewhat misleading, hence some of the replies.
I'm not buying a maths though, not my idea of fun...
vqlk
Post by vqlk » Sun Jun 14, 2020 11:29 am
yea
hageir
Post by hageir » Sun Jun 14, 2020 11:42 am
Why “transfer” MIDI from a computer to some gear to have that play it back?
Why not go straight to a hardware MIDI Sequencer and work from there?
Gus Gus used to write songs in Logic, then export the MIDI files, import them onto an Akai MPC 2000XL which was then used to play the MIDI/Sequences live (yielding a tighter master clock)
It was more frequent in the 80s; using a sequencer to capture a performance, then bouncing it over to another sequencer (the keyboard player from Toto used to do that a lot)
If you want to use a PC as a MIDI sequencer, that’s a whole other thing.
I would really recommend against using USB for MIDI, FireWire and PCI (older Serial is best) are all far better and more stable+accurate.
vqlk
Post by vqlk » Sun Jun 14, 2020 12:04 pm
it's not a eurorack fetish; i like the idea -- all in one
3hands
Post by 3hands » Sun Jun 14, 2020 11:05 pm
MPC is the answer.
Gum is fun, but not on a cat.
My minds an art gallery.
