Dumb question regarding Elekton Model:Samples
Slabwax
Post by Slabwax » Tue May 05, 2020 4:06 pm
I just made my first lock down gear purchase. The surprising thing about it was I was not not drunk or high (not a drop or a hit in me at the time.) As the subject states I picked up a Model:Sample. My first bit of Elektron kit. My question is can the 3.5mm midi i/o work as a sync i/o? If not is there some sort of work around? I'd like to sync to to a Liquid Foam. The L/F does not have any midi only sync in and out.
Slabwax
PeterHanes
Re: Dumb question regarding Elekton Model:Samples
Post by PeterHanes » Sat May 09, 2020 3:28 pm
It cannot.
Slabwax
Post by Slabwax » Thu May 14, 2020 7:00 pm
Thank you for reply
anselmi
Post by anselmi » Thu May 14, 2020 9:08 pm
the D in MIDI is for "digital"
the clock you are talking about is analog
MIDI signals are information coded in a (very specific) digital way...at electrical level it´s very different from what you get as an analog clock, that is a much simpler, even hackable, set of pulses at a certain frequency...not far away from a metronome
you need a "decoder" to bring the MIDI clock information to the analog world, ussualy called a MIDI to CV interface, that should have an analog clock output
you can perform some interesting tricks at this level, usin the trigger out (short pulse generated when play a note) as a clock signal, and send it to the clock input of another device. Then program your "clock" (train of notes) in the way you want. It can be a division or muliplication of the real clock, or even be irregular in time, swinged or anything...sky`s the limit
Tofupancho
Post by Tofupancho » Thu May 14, 2020 9:34 pm
Not a dumb question at all. Sync outputs can be as hot as 5v, enough to damage most MIDI inputs if you hooked them up with an adapter. Something like the Korg SQ-1 can clock both or bridge analog sync to MIDI.
Slabwax
Post by Slabwax » Sat May 16, 2020 9:56 pm
Thanks for the replies. I just picked up the Model:Samples and I have a Liquid Foam on the way. I'm looking for a way to sync the two together. The Samples only has midi and the L.F. only has clock I/O . Is the SQ 1 my best cheap option? Anything in euro that does not take up much space?
