Every SYNTHI needs a Korg SQ-1 step sequencer
papz
Post by papz » Thu Apr 16, 2020 8:50 am
Hi
I'm happy to introduce this new Portabellabz expansion card for the Synthi A and AKS.
The SQ-1 Card adapts the great small Korg SQ-1 sequencer for use with the Synthi.
The card simply plugs directly into the 8 pins Jones "keyboard" socket and is powered by the Synthi, no cables no connector, it's plug and play, easy and hassle free.
For use with a VCS3, the Jones plug can be mounted onto the top side of the PCB but an adapted umbilical cable with swapped connections is requested, the standard cable won't work.
Warning : the card's power consumption is 155mA on the Synthi's +12V power rail, which is too much load for a MK1 PSU.
It should never be plugged into a MK1 unit, this would fry its PSU. I assume no liability in case of problem (anyway, it can be repaired, no worries).
In several MKI units (including my own one) I added an extra PSU to power a KS, it is ok for the SQ-1 Card : http://www.portabellabz.be/images/sq1/M ... pgrade.pdf
Another solution is to power the SQ-1 via its USB port and omit the power circuitry on the card.
Features
All the nice features of the SQ-1 are working with the Synthi : https://www.korg.com/us/products/dj/sq_1/
Scaled CV
The SQ-1's CV outputs A and B are routed respectively to the Synthi's input channel 1 and 2. Thanks to a multiturn trimmer, the CV can be scaled to get equal temperament when the Synthi's input level pot is set to 10, therefore no more tricky adjustment is needed to control the Synthi 1V/oct.
A good working and properly calibrated Synthi tracks in tune over 5 octaves with the SQ-1 Card.
Gate
The Synthi's envelope can be fired by either the SQ-1's A or B gate, a 3-position switch replaces the SQ-1's former "littlebits OUT" :
left is gate A, center is no gate, right is gate B.
CV/Gate interface
When the SQ-1 is turned off, its CV/gate output jack sockets can be used as inputs to control the Synthi with another controller enjoying its equal temperament 1V/oct scaling.
Handle support
Small plates can be mounted to the back to lock the Spartanite case's handle for better stability.
The SQ-1 mounting to the SQ-1 Card is not difficult and can be performed by any person with basic soldering skills and tools.
Control other synths
The SQ1's ins and outs minijack sockets are still working.
The SQ-1 can control other synths together with the Synthi via CV/gate or MIDI and sync with other gear as a slave or as a master via its sync in and out sockets.
DIY PCB + alu panel set : €95 shipped
Pre-built card (waiting list) : €350 + shipping
http://www.portabellabz.be/sq1.html
Finest EMS gear service and Music Easel/208 goodies
I'm not a synths dealer and I'm not aware of an inexpensive Synthi secret market, please don't ask me if I know one for sale.
I don't offer support of any kind to people attempting to build clones of EMS equipment.
Neovintage
Re: Every SYNTHI needs a Korg SQ-1 step sequencer
Post by Neovintage » Thu Apr 16, 2020 9:27 am
You are on fire. Great feature. Congratulations
thehordijkmodular.blogspot.fr
blw
Post by blw » Thu Apr 16, 2020 11:20 am
That's a really cool. I'd love to see a video of the scaling process. Even if 1v/oct response proved to not be as easy and stable as I'd hope, this would be a very fun tool. What a cheap/simple way to dampen my KS lust.
papz
Post by papz » Thu Apr 16, 2020 11:35 am
Thanks !
The scaling process is really straightforward :
1. set the sequencer CV output A to have the first step outputing 0V, the second 1V, the third 2V etc up to 5V, thanks to the SQ-1's integrated quantizer, it's very easy.
2. turn the input level ch. 1 pot fully CW to 10.
3. patch a pin into row 8 to an oscillator frequency with the vernier dial set to about 4.5 (2k7 1% precision pins should be used for the calibration and play).
4. play the sequence step by step and adjust the trimmer to get 1 octave intervals between each step (the trimmers are accessible on top of the card between the panel and PCB).
5. proceed the same for CV output B with input level ch. 2 pot set fully CW to 10 and the pin in row 9.
The pre-built cards will come calibrated, a slight adjustment may be needed to match the actual Synthi it will be used with.
I don't think a video is needed, do you ? ;)
papz
Post by papz » Fri Apr 17, 2020 9:45 am
pelican
Post by pelican » Fri Apr 17, 2020 4:05 pm
Very cool
WTB: Yamaha dx-11 manual
papz
Post by papz » Sat Apr 18, 2020 8:02 am
I think so :party:
Thanks !
search64
Post by search64 » Sat Apr 18, 2020 11:44 am
A little disappointing you haven’t done On the run yet.
papz
Post by papz » Sat Apr 18, 2020 1:25 pm
I'm not exactly the greatest Pink Floyd fan but here is it just for you. :party:
You owe me a beer. :drinking:
search64
Post by search64 » Sat Apr 18, 2020 2:12 pm
:nana:
Henfield
Better Chemistry through Sound
Post by Henfield » Sat Apr 18, 2020 9:05 pm
Sounds great! Now I don't need to find a Synthi AKS, I just need to find a Synthi!
For Sale/Trade: 14U 84 hp Euro case . Willing to trade towards MU Modules, Moogerfooger pedals, Minifooger pedals, and other interesting effects boxes that work well with modular, try me!
search64
Post by search64 » Sun Apr 19, 2020 6:19 am
Look who owes who a beer NOW :razz:
papz
Post by papz » Sun Apr 19, 2020 8:14 am
:chug:
freakynorth
Post by freakynorth » Sun Apr 19, 2020 9:57 pm
This is cool as hell!
I’ll be looking into it when I score an Synthi 😉
papz
Post by papz » Sun Apr 26, 2020 8:12 am
:zen:
deltaphoenix
Post by deltaphoenix » Sun Apr 26, 2020 3:59 pm
Cool little jam
jondent
Post by jondent » Sun Apr 26, 2020 7:40 pm
very cool papz
papz
Post by papz » Mon Apr 27, 2020 5:53 am
Cheers !
Lewis#
Post by Lewis# » Tue Apr 28, 2020 12:38 pm
Ingenious as your other cool modifications! :yay:
AllDiamondsForSale
Post by AllDiamondsForSale » Tue Apr 28, 2020 1:55 pm
majestic... !
wow...
would it not also make sense to build that as a card for the easel ?
papz
Post by papz » Tue Apr 28, 2020 2:19 pm
I'm thinking to a similar SQ-1 adapter card for the Easel/208 but would it be really useful ?
Unlike the Synthi, the 208 already features a nice step sequencer, a pseudo-random with 4 different outputs and an arpeggiator if paired with a 218e.
Auxren explains how to bananify the SQ-1 on http://www.auxren.com/2017/12/how-to-ba ... -sq-1.html
AllDiamondsForSale
Post by AllDiamondsForSale » Wed Apr 29, 2020 1:40 am
Yes...
right...
i thought on the length of the step´s
a typical 8 is easier / more common to use as the easel fiver...
thanks for the link !!!
i´ll bananafy me one this week
papz
Post by papz » Wed Apr 29, 2020 6:07 am
A concern with the Easel is the PSU load, the SQ-1 Card is hungry, it takes 155mA on the Synthi's +12V rail via a 7805 to power the SQ-1, which would be heavy even for a recent BEMI/BUSA easel PSU, both +15v and +5V are present on the card slot but +15V is rated 500mA max for the whole Easel + what's plugged in the card slot, I don't know for +5V.
Powering it from the +15V rail via a 7805 with a powered Hub or PSU upgrade as detailed in the VCS3 Card's build notes sounds like the safest solution.
papz
Post by papz » Thu Jun 11, 2020 9:48 am
The SQ-1 Card is available http://www.portabellabz.be/sq1.html
supersounddesign
Post by supersounddesign » Thu Jun 11, 2020 8:47 pm
Yes! Can't wait to get mine!
