Easel program card and MO range
misa
Post by misa » Mon Mar 09, 2020 10:01 am
Hi,
At one point I want to have the Easel Toolbox by Papz .
But for a short term project, I am wondering if I couldn’t use a program card, a switch and two resistors to be able to switch the MO between Lo and High range.
Is this possible?
kainiggemann.bandcamp.com
anterasa.bandcamp.com
gratofficial.bandcamp.com
thedorf.net
MechaSeb
Re: Easel program card and MO range
Post by MechaSeb » Mon Mar 09, 2020 10:16 am
Should work yes.
Personnaly i wanted to get the looping function so i installed the Dunnington mod board on the program card. Recommended.
papz
Post by papz » Mon Mar 09, 2020 12:22 pm
Hi Kai
To transpose to higher range, simply connect contact 1 of the front/bottom row (+15V) to contact 11 of the rear/top row (MO frequency) via a 240k resistor and a multiturn trimpot (votage divider, any value between 10k and 100k is ok, it is not critical,) to scale the transposition range and a switch.
To transpose to both higher and lower ranges like on the ToolBox, use a 3 position on/off/on switch and add the same wiring via resistor and multiturn trimpot to the contact 1 of the rear/top row (-15V).
Finest EMS gear service and Music Easel/208 goodies
I'm not a synths dealer and I'm not aware of an inexpensive Synthi secret market, please don't ask me if I know one for sale.
I don't offer support of any kind to people attempting to build clones of EMS equipment.
misa
Post by misa » Mon Mar 09, 2020 3:52 pm
Thank you very much!
Are we talking about this card then?
thedorf.net
papz
Post by papz » Mon Mar 09, 2020 7:02 pm
Yes, you can use the top rows of holes to install the switches. The +/-15V rails are also present there.
I did it on the ToolBox'a ancestor. :zombie:
davebr
Post by davebr » Tue Mar 10, 2020 1:37 am
Is this possible?
This is exactly what I did although I used trimmers so I could trim them exactly The switch is 3 position so +1 oct, 0, +2 oct. It's at the bottom of my 208 V2 page.
Dave
