Serge Midi
cyberdine
Serge Midi
Post by cyberdine » Sun Feb 23, 2020 9:23 pm
I'm wondering if there's an easy midi > Serge converter. Something pretty simple, all I want to do is sync an Elektron Digitakt to an R*S Serge Mantra panel. Does anyone have any simple suggestions?
deltaphoenix
Re: Serge Midi
Post by deltaphoenix » Sun Feb 23, 2020 9:25 pm
Just get a Kenton midi to CV converter. It outputs CV via 3.5mm so you just need a format jumbler box.
bitone
Re: Serge Midi
Post by bitone » Mon Feb 24, 2020 8:33 am
same as the post above. kenton works like a charm with standard 1v/oct cv output and a reg 5v gate/pulse. format jumbler = 1/8 jack to banana jack format converter, connect the format jumbler box to the common ground of the serge PSU, and yr good to go.
I know in kenton as well as other things like 'cv.ocd' midi->cv interfaces you can select gate/clock division etc from the midi input, so if only syncing for the mantras sequencer i guess you only need the clock-> gate pulse.
wavecircle
Big Audio Sodomite
Re: Serge Midi
Post by wavecircle » Mon Feb 24, 2020 12:36 pm
I'd go for the muc 800 series. Really awesome spec and comes as a kit. It's overkill for what you want but serge with full midi would be amazing.
Instagram: https://www.instagram.com/thezyg/ (lots of Serge)
[s]http://bit.ly/2Mekran[/s]
Ciat Lonbarde stuff from many moons ago: http://soundcloud.com/polska-kliknij-muzyka
FatRocky
Re: Serge Midi
Post by FatRocky » Mon Feb 24, 2020 3:10 pm
I don´t know if i go Kenton or Yarns for Serge?
i see Kenton more solid, but Yarns more multifunctional, the thing is i´m not sure i´m going to be using all the Yarns functions in a Serge enviorment.
Is there something special about Yarns that has to be considered for the Serge users?
Thanks in advance
:tu:
cyberdine
Re: Serge Midi
Post by cyberdine » Tue Feb 25, 2020 8:19 pm
I didn't realise Yarns was available for Serge.. or do I misunderstand?
FatRocky
Re: Serge Midi
Post by FatRocky » Tue Feb 25, 2020 9:28 pm
I´ve seen pictures of DIY builds around . PCBs are available.
In case of Kenton, it can be used with adaptor cables or maybe converted to 4U.
cyberdine
Re: Serge Midi
Post by cyberdine » Wed Feb 26, 2020 5:48 pm
Intriguing. Thank you for the pointers!
FatRocky
Re: Serge Midi
Post by FatRocky » Wed Feb 26, 2020 6:45 pm
this one (2x1 panel combo, but i´ve also seen the single one yarns):
