Buchla 208 Build
we_squirm
Buchla 208 Build
Post by we_squirm » Tue Jun 20, 2017 4:56 pm
Hey all! I'm starting to source parts for my Buchla 208 build. Excuse me if this is the wrong spot for this, but on this BOM for the motherboard: https://cdn.shopify.com/s/files/1/0388/ ... 4855035085
I'm trying to play my order for things from Small Bear, and apparently I need a bunch of pots, which the BOM states:
10K-100K LIN
10K-100K LOG
10K-100K LIN
And when I try and order them from the Small Bear website http://smallbear-electronics.mybigcomme ... -pc-mount/
It tells me to state the value. I have an option for 10k or 100k, but what exactly does 10k-100k LIN mean? which pot should I be ordering? Sorry but I'm a little confused.
Drillionaire
Post by Drillionaire » Tue Jun 20, 2017 5:57 pm
10K-100K just means that any value between 10K ohms and 100K ohms will work fine.
meatcliff
Post by meatcliff » Tue Jun 20, 2017 6:08 pm
You can use my BOM as reference, which should be mostly accurate for the current 2.1 PCBs, just double check things. I made some substitutions for discontinued parts.
http://idmclassics.net/docs/208r_rev2_bom.xls
Here are the 208 v2 and v2.1 build threads in the DIY forum:
viewtopic.php?t=174863
viewtopic.php?t=127084
muncky
Post by muncky » Wed Jun 21, 2017 2:42 am
I used MeatCliff's BOM for my 2.1 build - it was really helpful!! Only point to note is I think Roman has changed the recommended caps to easier to find variants (I used MeatCliff's tho as I'd shopped early...!)
That's a long way of saying - THANKS Meatcliff :guinness:
we_squirm
Post by we_squirm » Wed Jun 21, 2017 11:13 am
meatcliff wrote:You can use my BOM as reference, which should be mostly accurate for the current 2.1 PCBs, just double check things. I made some substitutions for discontinued parts.
thanks - do you remember which value you used for those pots?
muncky
Post by muncky » Wed Jun 21, 2017 12:08 pm
I went with 100k
we_squirm
Post by we_squirm » Wed Jun 21, 2017 12:24 pm
muncky wrote:I went with 100k
great. and last question, the 10k-100k LOG pot, does that mean audio pot?
on the small bear website there is no option for log.
you can buy linear, audio, or reverse audio
jaidee
Post by jaidee » Wed Jun 21, 2017 12:38 pm
Log, Audio, and A are all the same thing.
jaidee
Post by jaidee » Wed Jun 21, 2017 12:42 pm
.... and, just so you are aware, Lin and B are the same thing (i.e. a linear taper as opposed to a logarithmic taper)
