My EMS VCS3 cometh but what mods to get?
amnesia
Post by amnesia » Mon May 04, 2015 8:35 am
I have just been informed that I am nearing the top of the VCS3 list and must get together a list of the mods I want.
What do people suggest? I intend to get Papz S/H mod but what else from EMS direct?
trax
Post by trax » Mon May 04, 2015 8:51 am
Oscillator Sync - variable via potentiometerVoltage Controlled Shape (per osc)
Hi/Lo frequency range -switchable
Portamento/glide
Attack time extension - increased to 5 seconds
Voltage Controlled Filter Response ('Q')
10-turn pots on input channels
Centre-zero trapezoid - gives inverted bipolar output
Patchable Voltage Inverter
Extra Input Channel
Switchable 18/24 db per octave filter
Filter 'unslew' switchable on filter's CV input
Main signal output mute switches (robin puts in toggles) (per channel) (this is a cool little talked about mod - but I love it for live jamming in my bedroom in front of the mirror! great for cutting in and out!
:tu:
chamomileshark
Post by chamomileshark » Mon May 04, 2015 4:37 pm
this is what I got
Oscillator stabilisation and dual transistor mod on Osc3
Hi/Lo frequency range x 3
Oscillator SyncOsc2
Voltage Controlled Shape – on Osc2 and Osc3
X10 Envelope Attack/Decay time multiplier
10-turn pot on Input Channel 1
External gate input – buffered
Key Gear: Wiard 300 Series, EMS VCS3, Frac Modular (Blacet, Wiard, Bananalogue & Synthesis Technology).
Pastoral Music: Mark Ellery Griffiths
Music: https://markgriffiths.bandcamp.com/
Website: https://markellerygriffithsmusic.blogspot.com/
Experimental & IDM: Mark Dalton Griffiths
Music https://markdaltongriffiths.bandcamp.com/
Website:https://markdaltongriffithsmusic.blogspot.com/
sinowhy
Post by sinowhy » Wed Feb 17, 2016 7:41 pm
Hi, the Cornwall Synthi VCS has been trickling out for a bit now.
I wanted to ask people what they felt about the mods they'd gotten, now that they've had time with them.
What's essential?
What turned out to be useless?
What do you wish you had gotten done instead?
Do you dislike anything?
I'm wondering about those 3.5mm mods near the matrix. That seems a bit hackish. Did anyone avoid those for that reason? or am I way off.
Thank you
chamomileshark
Post by chamomileshark » Thu Feb 18, 2016 5:22 am
hi, as above I got a number - comments under each one....
I don't have an unmodded Osc 3 to compare it to but I got this because I wanted to use Osc 3 as an audio oscillator and pair it with Osc 2 (remember Osc 1 has different waveforms)
To allow using any Osc as an audio or LFO
Oscillator SyncOsc2
recommended by others. Seems to work differently to synch on other synths I have - works with LFOs
useful for me
I often use slow sounds so I decided to get this
I find this really useful
again personally I find this useful
Recommended by EMS but I think it's one of the more marginal ones - depends on what you use it for - if you want to do bass sequences then yes.
I've found if you want to do sequencing this is essential to get the attack right.
If you are going to use with some kind of melodic controller and want to play normal scale then this is probably essential. You only need it on the one channel
again if you are going to want to use some kind of CV controller other than a EMS keyboard you need this.
These are all very much personal choices based on what I intended to use the EMS for while remaining within budget and keeping the machine interface uncluttered. (although compared to euro, frac or even the Wiard 300 series there is plenty of room of the face plate)
Acquadar
Re: My EMS VCS3 cometh but what mods to get?
Post by Acquadar » Sat May 02, 2020 5:50 am
Thanks Cham, very useful info about mod...
