Serge WAD feedback voltage control
jamb
Post by jamb » Tue Feb 24, 2015 8:16 pm
Just wondering why feedback does not have a voltage control input? Anyone ever modded their WAD to have this? It's one of the best parts of the Time Machine delay.
bartlebooth
Post by bartlebooth » Tue Feb 24, 2015 8:28 pm
no need to mod it - just run either the A or B output through a VCA and then back into the AUX-input, making sure the feedback toggle is set to AUX... there's your voltage controlled feedback.
jamb
Post by jamb » Tue Feb 24, 2015 10:15 pm
:roll:
hongaars
Post by hongaars » Wed Feb 25, 2015 8:39 am
sound clips please! :razz:
jamb
Post by jamb » Wed Feb 25, 2015 1:36 pm
bartlebooth wrote:no need to mod it - just run either the A or B output through a VCA and then back into the AUX-input, making sure the feedback toggle is set to AUX... there's your voltage controlled feedback.
Too bad it requires a whole VCA, you also can't get longer delay times, but it works... thanks for the tip :cheers:
bartlebooth
Post by bartlebooth » Thu Feb 26, 2015 10:27 am
sure thing..you can make the WAD's delay time quite a bit longer by putting 5v (like from a mix pro or dual processor) into the delay time CV in jack and turning the knob up (longest delays will be from the B output which uses both BBD chips).
Vsyevolod
Post by Vsyevolod » Thu Feb 26, 2015 5:21 pm
Yes it requires a whole VCA. Alternately, you could use the top section of the Wave Multiplier, or a black input on the DTG/DSG, or an Active Processor, or a Xfader, or a simple mixer, or a DCSM, or the top half of the SSG, or a Ring Modulator, or... or... or...
That's the beauty of a Serge system. All these sub components working together in harmony. Yes, you need a plethora of patchcords, and a good head on your shoulders. And the rewards are many.
Stephen
