Power Supply for Pedals
lukebarber
Post by lukebarber » Mon Mar 27, 2017 9:55 am
I have a first year HT Dual. I am looking for a back-up power supply for my unit. Has anyone found anything that will replace these? I'm assuming BLACKSTAR doesn't sell power supplies separately.
I hope someone steps up & makes something that can run 2 or 3 pedals at once. We're seeing some companies offering this for EVENTIDE pedals, but it's a slow go for other juice hungry pedals. Someone needs to specifically address juice requirements for BLACKSTAR pedals & multiple pedals at that. I found a power supply that would work but it is ridiculously expensive. http://www.clrwtr.com/PDF/IDEC/IDEC-PS3X-Series.pdf
mrcharles
Post by mrcharles » Mon Mar 27, 2017 10:44 am
You don't mention what kind of power you need... Or what you have in mind to spend...
There are a number of manuf. that make power that deliver a range of voltages and current levels.
I have the goliath and chameleon to power pedals and Ciat Lonbarde instruments made by...
http://www.t-rex-effects.com/power-supplies/
No complaints... Built like a "tank".
shamann
_
Post by shamann » Mon Mar 27, 2017 10:48 am
This could handle one HT Dual plus other non-Blackstar pedals:
http://yankee.com.pl/hs-m12-power-supply/?lang=en
But I don't think it can handle two pedals at 22V DC and 1.1A.
kreiff
Post by kreiff » Mon Mar 27, 2017 12:01 pm
If you don't want to buy a big power supply and you just want a back-up wall wort / AC Adapter you could try buying a Universal Laptop adapter.
They sell them with switches that change the output voltage. This one provides up to 4A at 22V DC:
http://www.ebay.com/itm/90W-Multi-Brand ... 1798974297
That one comes with a 2.1mm and 2.5mm tip, so you should have one that fits.
[Edit]
Scratch that - looks like they *are* center positive:
http://static.musicroom.com/img/c/lb/HT ... l_lb02.jpg
Jason Brock
just visiting
Post by Jason Brock » Mon Mar 27, 2017 1:24 pm
I just got a Strymon Ojai which I really like. It's tiny and provides 500mA on each of the five outputs. Comes with a "lump in the middle" type power cord, sort of like a laptop.
http://www.strymon.net/products/ojai/
EDIT: btw they are all 9V, didn't realize your HT pedal needed higher voltage.
DubRules
Post by DubRules » Mon Mar 27, 2017 8:47 pm
durwin
Post by durwin » Thu Jun 01, 2017 12:20 am
those black stars are brutal - 16VAC yeah?
ben jah men
Post by ben jah men » Sat Jul 15, 2017 9:06 pm
I'm saving for a Ciokolate.
Post by JohnLRice » Sat Jul 15, 2017 10:22 pm
I did a quick search and found this image of a power supply
And a quick search of the model number (ktec KA12A160080045D) found this replacement on Amazon:
:hmm:
And then I found this site:
http://www.diystompboxes.com/smfforum/i ... c=117328.0
where member vinnygalbo made a single post that is identical to lukebarber's post here . . and in response member Ice-9 recommended the same supply on Amazon I suggested. :confused:
Just me
Has enough VCA's
Post by Just me » Sun Jul 16, 2017 10:59 am
I have dozens of 16.5VAC 25 and 40 VA WALL WARTS. Not hard to find, not expensive.
If I have water in my ear, is it safe for me to listen to electronic music?
smetak
Post by smetak » Sun Jul 16, 2017 6:29 pm
I have a Peavey wall wart 12 VAC with 1000ma for a quirky Eowave pedal (Sci Fi Bug) - incredibly cheap. No big deal to get - and I dwell in the darkest corner of Africa.......
