[ORDER] Roland 100M VCA PCBs/panels
ringroad1
Post by ringroad1 » Mon Feb 06, 2017 8:37 am
SMonk wrote:If i replace the LF351 with a TL071 it kind of works, but "backwards", ie CV in the CV inputs reduce the (otherwise continuous) output rather than the other way around.
Total guess, check orientation of the two pairs of transistors? I guess they'd map to Q2 and Q3, and Q3 and Q4 on the original schematic. If you've subbed in a different type, they might have a different pinout from the markings shown on the board.
DJMaytag
Post by DJMaytag » Mon Feb 06, 2017 9:22 am
The build docs of the Frequency Central boards I've done have noted using TL071's, as there were some bad LF351's making the rounds, so using a TL071 should be perfectly fine. They also recommend using BC547/557's, as 2N3904/3906's would be reversed compared to the BC547/557's.
EDIT: corrected to TL071.
Instagram | Soundcloud | Wisco Wigglers
If you talk about improper grounding 3 times, Graham Hinton appears!” -djs
SMonk
Post by SMonk » Mon Feb 06, 2017 10:02 am
The build docs of the Frequency Central boards I've done have noted using TL072's, as there were some bad LF351's making the rounds, so using a TL072 should be perfectly fine. They also recommend using BC547/557's, as 2N3904/3906's would be reversed compared to the BC547/557's.
On my FC envelopes i had to replace the LF351s with TL071s to get them to work, due to the dodgy tayda 351's i and others had trouble with. It's quite possible that the 351 i'm trying to use in the amp is also suspicious, even though i bought it at a much later date (still tayda, though).
TL072 has a a completely different pinout (it contains two transistors, unlike the 351 and 071 which only has one) so they shouldn't work at all without some serious rewiring, should they?
DJMaytag
Post by DJMaytag » Mon Feb 06, 2017 12:47 pm
Oops, that was a typo to say it was the TL072. My bad, it was the TL071.
