[ORDER] ARP Odyssey Mk II/III VCO PCBs/Panels
i have a question, as i seriously think of building these OSCs...
basically where is the outrage towards the 49.9k resistors?!?!? rly? 88.7k? how precise do these things need to be? i get it that the guy who cloned it measured actual components in his ody, but how much wiggle room do i have for these things until everything starts falling apart????
- aL Pariah
- Common Wiggler
For the 49.9k, a 50k should be within the 1% tolerance. Finding something very close to 49.9k in a pack of 50k resistors, I don't think would take too long anyway.dogmeat wrote:i have a question, as i seriously think of building these OSCs...
I had no 88.7k, and no resistors within tolerance in stock, closest was an 82k, so just bought some 88.7s.
I don't know the tolerance of the circuit itself though.
I resisted resistor outage outrage.
- steffensen
- Veteran Wiggler
- home_listening
- Veteran Wiggler
- Contact:
I've just finished off two, one with strict 0.1% metal film 1/2watt resistors and another with loosey goosey 5% carbon 1/4watt resistors. Just to see how they compare. I'm much more into the loosey gooseysteffensen wrote:These VCO's are quite forgiving regarding Resistor values actually. I would stay within the 1% tolerance if possible tho.
- steffensen
- Veteran Wiggler
Oh, nice! I tinkered with the thought of doing that myself. Ill build some more i guess and try this out. Would love to hear some audio with'em.home_listening wrote:I've just finished off two, one with strict 0.1% metal film 1/2watt resistors and another with loosey goosey 5% carbon 1/4watt resistors. Just to see how they compare. I'm much more into the loosey gooseysteffensen wrote:These VCO's are quite forgiving regarding Resistor values actually. I would stay within the 1% tolerance if possible tho.
- home_listening
- Veteran Wiggler
- Contact:
Yeah, will definitely do at some point. Finishing off a few builds at the moment so no time to play!
steffensen wrote:Oh, nice! I tinkered with the thought of doing that myself. Ill build some more i guess and try this out. Would love to hear some audio with'em.home_listening wrote:I've just finished off two, one with strict 0.1% metal film 1/2watt resistors and another with loosey goosey 5% carbon 1/4watt resistors. Just to see how they compare. I'm much more into the loosey gooseysteffensen wrote:These VCO's are quite forgiving regarding Resistor values actually. I would stay within the 1% tolerance if possible tho.
I've already built two Odyssey VCOs, and while both work nicely, track perfectly and sound just great (I'm using a +/- 12V power supply) there is one thing I just don't understand:
The saw wave is supposed to be 0-6V, however my saw is 0,5V - 5,5V ... can any fellow wiggler confirm my readings? Any idea why that is
... circuits without opamps are still somewhat mysterious for me ...
Have you had any luck troubleshooting the oscillators? I had the exact thing going on with both of my oscillators. No sound out of either, did the same measurements and came up with roughly the same voltages that you got.reggiechacha wrote:I've been trouble shooting this project for a few hours now. I'm not getting any output, and my scope isn't showing any wave shapes. There are low voltages on the saw out put of about 0.7v and nothing from the square output. When I add a LFO in to the CV2 input you can here the pulse/click.
Andy
I just got mine both working last night. What I found was my problem was a short (or possibly etching fault) under the 2N3906 right above the 16.5K resistor. The traces are very close and both of my boards were shorted at that point. A razorblade and re-soldering fixed the problem.
Also, I confirmed that LM3046 do work in place of CA3086.
- frequencycentral
- Kicking the shit out of your speakers
- Contact:
I've managed to get a mate to etch me the pcbs from the schematics from this thread and I couldn't be happier.
Soon I will do my own!
Was wondering if anyone had any really good, detailed pics of their pcb build for reference?
It would be much appreciated as I'm relatively new at DIY with a few successful builds under my belt.
Well, dress really.
cheers
scorbie
Well, dress really.
cheers
scorbie
- cleaninglady
- Super Deluxe Wiggler
Sorry to raise the Dead...but can i ask what the orientation of a 2n3906 would be on this diagram if used to replace a 2n5910 ?
http://electro-music.com/forum/phpbb-fi ... co_126.pdf
I've had this VCO hanging around for a year or so needing just one part and i want to get it going.
- cleaninglady
