[ORDER] ARP Odyssey Mk II/III VCO PCBs/Panels
frequencycentral
Kicking the shit out of your speakers
Post by frequencycentral » Wed Aug 15, 2012 4:39 am
Ok, I'm ready to take orders for this project. Please make your payments by Paypal gift to:
rickholt22@hotmail.com
Please state your MW name, what you are ordering and your address.
I've made a bunch of PCBs already, but still have the bulk to go, so shipping might be a few weeks for tail-end-charlies!
AndyR1960 @ electro-music.com has kindly given his permission for me to do a run of PCBs based on his work for the ARP Odyssey Mk II/III VCO.
Here's the EM thread: http://electro-music.com/forum/viewtopi ... 395#367395
Each PCB will be £15 GBP including shipping. Here's my PCBs:
Here's my proposed panel layout for 2 x VCO:
...which is 21HP. Panel will be £20. It includes a sync switch as well as additional socket for ring mod. Ring mod will be on a small daughter board, and will be included free for anyone ordering 2 x VCO PCBs.
Any interest? I'm going to build one (or two) before I do a run to ensure there are no issues, but Andy has already built a number of these.
brother303: 2 x VCO
jloftin: 2 x VCO
boothnavy: 8 x VCO
sicpaul: 2 x VCO
rowman: 2 x VCO
moogah: 2 x VCO
hv0190: 4 x VCO
frozencore: 2 x VCO
Juxwl: 2 x VCO, 1 x panel
aladan 2 x VCO
monokinetic: 2 x VCO
carynrich: 2 x VCO
mckenic: 2 x VCO, 1 x panel
Barcode: 2 x VCO
spotta: 2 x VCO, 1 x panel
PF: 2 x VCO
reggiechacha: 2 x VCO, 1 x panel
nickster: 2 x VCO, 1 x panel
janvanvolt: 2 x VCO, 1 x panel
Francesco: 2 x VCO
home_listening: 2 x VCO, 1 x panel
negativspace: 2 x VCO
mOBiTh: 2 x VCO, 1 x panel
oberkorn: 2 x VCO, 1 x panel
mattrick: 2 x VCO
xonetacular: 2 x VCO
jaidee: 2 x VCO
Black = interest
Green = paid
Last edited by frequencycentral on Tue Aug 28, 2012 4:13 pm, edited 20 times in total.
brother303
Post by brother303 » Wed Aug 15, 2012 5:28 am
Hi Rick,
as stated on EM, 2x vco-pcb and 1x ringmod pcb. No panel.
Thanks lot!
Greg
Peake wrote: DIY is all about the backlog. If you don't have a huge backlog, you aren't trying hard enough.
jfloftin
Post by jfloftin » Wed Aug 15, 2012 6:10 am
Count me in!
boothnavy
Post by boothnavy » Wed Aug 15, 2012 6:25 am
How important is the 2N5910? Seems everything else is easy enough to find.
I recon i'd order eight VCO pcbs and four RM pcbs.
Any idea on time frame?
boothnavy - synthesist
www.analogcraftsman.com
frequencycentral
Post by frequencycentral » Wed Aug 15, 2012 6:30 am
I'm just waiting for parts then I'll build, making my panel today. So if all goes well maybe a week or so. I'm going to socket the trannies and see if they can be viably subbed with something more common.
brother303
Post by brother303 » Wed Aug 15, 2012 6:48 am
Hi,
frequencycentral wrote:I'm going to socket the trannies and see if they can be viably subbed with something more common.
as far as I can remember they can be substituted with 2N3906.
I found my 2N5910 on ebay some time ago...
Greg
boothnavy
Post by boothnavy » Wed Aug 15, 2012 6:52 am
Will it be hard to add a range switch like on the 2600 so they can also act as LFOs?
frequencycentral
Post by frequencycentral » Wed Aug 15, 2012 6:56 am
boothnavy wrote:Will it be hard to add a range switch like on the 2600 so they can also act as LFOs?
You should be able to just normalise one of the CV inputs to -ve, that's simpler than adding a switch.
boothnavy
A
Post by boothnavy » Wed Aug 15, 2012 7:05 am
But if I wanted to add a switch? Pretty hard?
Also, will there be a silkscreen on the pcb, or are these hand etched?
frequencycentral
Re: A
Post by frequencycentral » Wed Aug 15, 2012 7:07 am
boothnavy wrote:But if I wanted to add a switch? Pretty hard?
Easy. Just hook up a switch between the CV input bus and -ve.
boothnavy wrote:Also, will there be a silkscreen on the pcb, or are these hand etched?
Hand etched as in the photo above.
sicpaul
Post by sicpaul » Wed Aug 15, 2012 9:58 am
Hi Rick,
I'm interested in 2 VCO PCBs and 1 Ringmod PCB.
Paul
rowman
birds are dinosaurs
Post by rowman » Wed Aug 15, 2012 11:04 am
I might get a set if it happens before the Hearn Morley VCO, I really just need a couple of VCOs.
frequencycentral
Post by frequencycentral » Wed Aug 15, 2012 11:05 am
rowman wrote:I might get a set if it happens before the Hearn Morley VCO, I really just need a couple of VCOs.
Yeah, this will happen before the HMVCO1c. It's basically ready to go right now.
rowman
birds are dinosaurs
Post by rowman » Wed Aug 15, 2012 11:49 am
Hmm, do you think the HMVCO1c is far off? I wish I could do both but I can't atm, and the HMVCO1c seems to be more of an all-rounder workhorse.
moogah
Post by moogah » Wed Aug 15, 2012 2:04 pm
Duuuuuuuuuuuude I'm trying not to spend any more money!
I'm in for 2. Maybe more, been wanting some Odyssey VCO's for a long time now.
Also, while I can appreciate the rough and ready etched boards I can't help but wish you'd start getting them made with at least a silkscreen, it makes the build process easier imo :)
.. I'm still going to build most of your stuff anyway tho :tu:
hv0190
Post by hv0190 » Wed Aug 15, 2012 3:06 pm
Great :tu:
I'm in for two VCO pcbs and one rm pcb
Thanks a lot :bananaguitar:
frozenkore
Post by frozenkore » Wed Aug 15, 2012 3:11 pm
2 x VCO, 1 x RM for me please.
Cheers!
diablojoy
Post by diablojoy » Wed Aug 15, 2012 4:56 pm
you could try doing what i do in these cases
simply print the component layout with a bubble jet printer on normal paper [ note: do not use a laser printer the laquer will make it run ]
and apply it using circuit board laquer, spray the board apply paper
line it up as best you can with the aid of a very bright light shining through the board and spray again over the top then let dry for a few hours
punch through all the holes with a needle or a sharp scriber from the component side and then populate the board
works quite well.
I might take a couple of boards have to see how bad my finances are first though
It probably wont happen today but if it does it definitely wont go smoothly.
Juxwl
Come for our...uhhh...corn?
Post by Juxwl » Wed Aug 15, 2012 6:41 pm
I'm in for 2 vco and one ring mod pcb as well as a panel.
aladan
Desperately Seeking Sondra
Post by aladan » Wed Aug 15, 2012 6:44 pm
Count me in, 2xVCO + 1xRM. Thank you!
frequencycentral
Post by frequencycentral » Fri Aug 17, 2012 3:38 am
Actually, I had another look at the build docs and spoke to Andy, there are pads on the PCB to add a VCO/LFO switch and a 270K resistor to -ve to provide the -ve reference. So it's all there, though I'm still going to go the normalised socket route.
Here's my panel:
monokinetic
Post by monokinetic » Fri Aug 17, 2012 7:46 am
I would be interested in 2x VCO and 1x RM PCBs. No panel thanks. Oh and I'd group them with the VCDCO from electric Druid when that's ready to save some shipping :)
frequencycentral
Post by frequencycentral » Fri Aug 17, 2012 8:39 am
^^^ Gotcha.
I just finished a revised layout for the RM, based on Andy's layout but shrunked down a bit. It's so small that I'm throwing it in free for anyone ordering 2 x VCO PCBs
hv0190
Post by hv0190 » Fri Aug 17, 2012 10:14 am
frequencycentral wrote:^^^ Gotcha.
Wow - fantastic, Rick :tu:
I'd like to change my order from 2 x VCO + 1 x RM
to
4 x VCO + 2 x RM
Thanks a lot!
brother303
Post by brother303 » Fri Aug 17, 2012 10:16 am
Hi,
frequencycentral wrote:It's so small that I'm throwing it in free for anyone ordering 2 x VCO PCBs
Wow,that´s absolutely awesome!
BIG THANKS!!!
:hail:
