Some general knowledge:
Buchla and 5U format PCBs work only on 15V, bot has pads for Eurorack IDC-10 (Cwejman-style), mta-100 dotcom, mta-156 MOTM and MODCAN power connectors.
Eurorack format is for 12V operation, but can work on 15V as well - just do not install 12V-to-15V transformer parts and put 2 links/wires instead - i'll show it a bit later. It has Eurorack IDC-10 (Cwejman-style) power connector only.
Do not solder jacks/leds/pots before you solder voltage shifts parts.
Also do not solder jacks before you fit them into panel.
1) put jacks into pads on the PCB, but to not solder them
2) fit the panel on jacks
3) turn it all upside down and then solder the jacks
4) after that fit the pots and LEDs
Do not forget to connect 2 PCBs with 3 THRU pads
this brings power to the 2nd PCB
one more thing to say
i have also experienced an issue with ribbon-cables - a few of them look good, but do not function well, a couple had wrong key position
so:
1) take a look at your ribbon cables.
2) 5U & Buchla ones should have "keys" looking outside and EURO's "keys" are looking inside on both sides on the cable
3) check that "arrows" are located at the same side as the red line on the cable
4) ring all the connections with a multi-meter so be sure that nothing is shorting inside of the cable. holes are too small to put the test-leads inside of them, so you may put the other part of the connector and have an access to pins.
i do not think that many people would have such a problem, but anyway - please check it.
