spotta
- Needs more wigglin' time
Post
by spotta » Wed Nov 02, 2011 3:33 pm
just for the record
I'ld be down for one if another run happens
Spotta
Naturebot
- Learning to Wiggle
Post
by Naturebot » Wed Nov 02, 2011 9:51 pm
Yeh yeh, another run
I'm in
mig27
Post
by mig27 » Thu Nov 03, 2011 4:19 am
Me too, me too!
Cat-A-Tonic
- Lobsters love Muff
Post
by Cat-A-Tonic » Fri Dec 09, 2011 9:09 am
I notice some people are using 5% resistors.
Is it ok to use a 3.9k instead of the less common 3.8k for R21?
It appears to be in line with the output so I'm guessing it should be alright.
If it was related to 1v/oct tracking I would want to stick with the prescribed value.
Cat-A-Tonic
Post
by Cat-A-Tonic » Mon Dec 12, 2011 8:22 pm
Can you swap SD cards with the power on?
How often do you swap SD cards?
I'm deliberating over parallel mounting (with something extra on the panel)
vs.
a smaller panel with perpendicular mounting (with dremeled card-slot on panel).
I'm planning on building this one in Euro due to its native power requirements.
It doesn't require a ton of panel space for the controls,
but it is a fairly deep PCB if done perpendicular;
which limits its placement in cabinets designed mostly for skinny modules.
decaying.sine
- Broken <--> Fixed
Post
by decaying.sine » Mon Dec 12, 2011 8:37 pm
Cat-A-Tonic wrote:I notice some people are using 5% resistors.
If 5% resistors are prescribed for R21, you could get away with one that measured 3.9k on a DMM. Just remember that if you use a 1% 3.9k that there will be some range in those as well (obviously). 3.90k will be about 2.6% different than 3.8k.
"Vactrols ringing, Dude." "Thank you Donny"
gwaidan
Post
by gwaidan » Mon Dec 12, 2011 8:58 pm
Cat-A-Tonic wrote:Can you swap SD cards with the power on?
vs.
The SD Cards load wave data on powerup or reset-you can swap them with power on but will need to push the reset switch to load the new data.
Perpendicular mounting will require a support bracket-the insertion force of the card is pretty strong. A case like a Doepfer P6 should be fine to accommodate it.
frozenkore
Post
by frozenkore » Thu Dec 22, 2011 11:52 am
Is there anyone who I can paypal $2 to stick a (1x) 3.8k resister in an envelope and mail it to me? If so, could you send me a PM? Thanks!
Cheers!
mono-poly
- Le Cheff
Post
by mono-poly » Thu Dec 22, 2011 12:18 pm
Yeah another run please!
reve
Post
by reve » Fri Dec 23, 2011 2:40 am
Me too on the whole "another run" thing.
surgesg
Post
by surgesg » Fri Dec 23, 2011 12:30 pm
Planning another run early in the new year... thinking another run of 12 pcb / ic combinations, depending on demand.
nangu
Post
by nangu » Fri Dec 23, 2011 1:02 pm
Awesome! I think you could sell a lot more than 12, though. I'm in for at least 3, plus at least 5 euro panels if Clarke makes some..
“They finally sent it back to me... in the exact same condition. So I shot myself in the other foot with it” - ranix
mono-poly
- Le Cheff
Post
by mono-poly » Sat Dec 24, 2011 9:21 am
I want 2
appliancide
Post
by appliancide » Sat Dec 24, 2011 9:34 am
I would like one set.
falafelbiels
- still learning to wiggle
Post
by falafelbiels » Sat Dec 24, 2011 12:09 pm
Oh I want to be in this time. I'll start saving!
gwaidan
Post
by gwaidan » Sat Dec 24, 2011 4:51 pm
frozenkore wrote:Is there anyone who I can paypal $2 to stick a (1x) 3.8k resister in an envelope and mail it to me? If so, could you send me a PM? Thanks!
Just use a standard 3.9k instead-it's within the 5% tolerance range plus the capacitor it forms a filter with is going to be 5% tolerance anyway, so no need to be too critical with the value
gwaidan
Post
jaidee
Post
by jaidee » Sat Dec 24, 2011 8:26 pm
I'm in for one if another run happens.
mig27
Post
by mig27 » Sun Dec 25, 2011 12:09 pm
surgesg wrote:Planning another run early in the new year... thinking another run of 12 pcb / ic combinations, depending on demand.
There's probably going to be way more interest than for 12 boards.
I for instance have just decided that I'd like two sets and not just one
Maybe you could have people officially sign up for their orders here in this thread to gauge the interest?
In any case thanks so much for doing this!
Michael
surgesg
Post
by surgesg » Sun Dec 25, 2011 12:38 pm
Yes, I would like to gauge interest... if you'd like one or more, pls send me a PM and I'll keep a tally.
- Greg
keninverse
Post
by keninverse » Sun Dec 25, 2011 12:54 pm
Any idea of the cost? Same as the prior run?
Funky40
Post
by Funky40 » Sun Dec 25, 2011 1:32 pm
how much is or was the cost for one set ?
is there a partlist somewhere ?
i´m interested aswell. but not interested to hunt for parts.
the 3,8k res is not a problem.
thanks
For SALE: Switzerland, which is NOT EU (prices in CHF):
Rossum Evolution Filter: 280.- / Modcan VCDO (rare): 250.-
keninverse
Post
by keninverse » Sun Dec 25, 2011 2:12 pm
For the second run I paid around 60 for a preprogrammed chip and pcb.
mig27
Post
by mig27 » Sun Dec 25, 2011 5:57 pm
surgesg wrote:Yes, I would like to gauge interest... if you'd like one or more, pls send me a PM and I'll keep a tally.
- Greg
PMed!
