Problems building FC Monograf
mightycoco
Post by mightycoco » Tue Jan 26, 2021 4:13 am
Hi Guys,
I'm having problems getting the Monograf DIY running. VCA/VCF/ADSR seem to work when measuring but the VCO doesn't swing.
I could track it down to pin 15 of the AS3340 doesn't get voltage. But there are a lot of mod sources and I can't trace back, where the normalized and external voltage should come from.
I couldn't find any schema to trace back pin 15 which makes debugging even more complicated.
The AS3340 does get power, and if I connect a DC source of some volts directly to pin 15 I get audio.
Does anyone has a schema or knows, which pins going from controller board to the core board I should check?
thanks,
MC
Agawell
Re: Problems building FC Monograf
Post by Agawell » Tue Jan 26, 2021 11:21 am
have you considered sending FC an email? - they are quite helpful - maybe they have a schematic
Modular Audio and Video Synthesis on Instagram
Utility modules are the inexpensive, dull polish that makes the expensive, shiny modules actually shine!!!
an oscillator is an oscillator - utilities are possibilities
choose the case to fit the modules - not the modules to fit the case!!!
nigel
Post by nigel » Tue Jan 26, 2021 3:30 pm
Pin 15 is a virtual ground pin, so it's always going to be at the same voltage (probably 0V) when it's working correctly.
DJMaytag
Post by DJMaytag » Wed Mar 03, 2021 5:43 pm
I'm about to finish building this one, and I'm curious the pad on the ground pin for the V/oct jack. It looks VERY close to the other pad, in a similar way that I had an issue with a jacked grounded/shorted on a Stasis Leak build. Have you double checked continuity on all your jacks, to be sure nothing is shorted out?
Instagram | Soundcloud | MG Main Rack 6U+6U
If you talk about improper grounding 3 times, Graham Hinton appears!” -djs
DJMaytag
Post by DJMaytag » Wed Mar 03, 2021 10:11 pm
I got mine up and running, and everything seems to be fine so far. Have you noticed anything else odd about it yet?
