pcb panel - keep cooper layer or not?
dlavila
Post by dlavila » Sat Sep 12, 2020 3:49 pm
I'm making most of my panels from FR4 PCBs, at the moment I'm not using the cooper layer for any graphics (only the silkscreen), so I'm usually removing the entire layer. Is there a difference if I keep the layer, in terms of the quality of the soldermask or scratch resistance of the panel? thanks!
MikeDB
Re: pcb panel - keep cooper layer or not?
Post by MikeDB » Sat Sep 12, 2020 4:32 pm
Yes. The copper layer acts as a ground plane and reduces EMI coming out of the module. Keep it on, at least on the backside if you don't like the look on the front.
Personally I hate cats ! Set a VCO to about 25kHz with a fairly fast +/- 5kHz frequency modulation into a piezo tweeter and cats will hate you too !
Bartimaeus
Post by Bartimaeus » Sat Sep 12, 2020 6:08 pm
note that this only works if your drill holes are pads that the jacks sleeves can make contact with to ground the panel (or if you connect it to ground some other way). otherwise it's just a big chunk of copper.
Flounderguts
Post by Flounderguts » Sat Sep 12, 2020 6:19 pm
If you're ordering from chinese pcb manufacturers, it is cheaper to do a 2 layer pcb than a single or no layer pcb. They are also more opaque, because you get soldermask on both sides.
Consider putting the layer in as a pattern that is under the solder mask...it can make a very nice embossed look.
I find the quality of the exposed copper/ENIG text is far better than the silkscreen, and always perfectly aligned. But sometimes making the right shapes as pads can be a task.
Flounderguts
revtor
Dialing it in..
Post by revtor » Sat Sep 12, 2020 6:35 pm
The copper makes the solder mask colors much brighter too.
I think it makes the panels more rigid as well.
Fellow North Jersey Synthaholic
MikeDB
Post by MikeDB » Sat Sep 12, 2020 7:52 pm
Agreed. I always expose copper around the mounting holes and have a silkscreened message on the back of my panels saying "Ensure Ground Continuity By Using Metal Bolts to Rack". Not 100% accurate statement but makes sure people do it.
KSS
Post by KSS » Sun Sep 13, 2020 5:30 am
^ This.
And leaving copper on both sides is stiffer. Putting it on only one side invites bowing. Thermal gradient in most synths interior-exterior ensures this will be worth payng attention to. Use at least 2mm thick PCBs.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Sun Sep 13, 2020 7:04 am
:agree:
