PROGUE - Analog mono synth - AUDIO DEMO
JanneI
Post by JanneI » Fri Jun 19, 2020 4:41 pm
Hello, my SDIY friends!
My latest project has advanced to "a working proto" -phase, so I thought I'd share some pictures of it. It's basically a mixture of Moog Rogue and Prodigy with some extra features, all in a single 4-layer 230mm x 130mm PCB with (mostly) SMD components. And since it's SMD, I haven't decided in which form this project could be available for builders, but maybe most of us are already moved to the SMD side of things?
Anyways, the next step is to do a small number of modifications to the proto PCB and add a couple of features. I will post some audio demos when I get time to do them properly.
Cheers!
Update 080820:
KSS
Re: PROGUE - Analog mono synth
Post by KSS » Sat Jun 20, 2020 5:38 am
Well done! Look forward to the updates.
tioJim
Post by tioJim » Sat Jun 20, 2020 5:47 am
Nice!
I did a repair on a Moog Rogue. I couldn't believe how simple the board was. Really liked the sound of it as well.
Isaiah
Post by Isaiah » Sat Jun 20, 2020 6:45 am
This look interesting!
There are some elements that are perhaps more easily identifiable as Rogue or Prodigy features from the front panel,
but it’d be good if you could detail where each functional block of your synth originated from.
Is “Beat” a linear detune control for one of the VCOs?
search64
Post by search64 » Sat Jun 20, 2020 11:28 am
I would have no problem with the SMD but then again if the SMD parts came presoldered for the right price I’d be game as well.
JanneI
Post by JanneI » Sun Jun 21, 2020 2:48 am
So, here are some details of PROGUE. It's heavily Rogue based with modifications and add-ons.
Oscillators are from the Rogue, with add-ons like independent waveform switches, PW pot, PWM with a dedicated triangle LFO, Fine-tune for OSC2 (Beat), and the option to use Gate signal as a sync source for the oscillators (ie. for those in-phase bass sounds!). AS3046 is available now and so are those 100ohm PTC's in 0603 SMD. The PCB has both 0603 pads and THT pins for mounting it on top of the 3046 with wires.
Since Rogue has only one envelope, the whole gate/envelope section is from Prodigy, adjusted for +5V Gate signals. Also, the LFO can auto-trigger the envelopes as in Rogue.
VCF-VCA is pretty similar on both synths, but Rogue has a op-amp mixer with hard-clipping that IMHO doesn't really sound that good. So, values were modified in order to sound more similar to Prodigy. A passive HPF filter (ie. Juno series) was added to cut the low end when needed.
Phones amp is TPA152 -based solution.
All trimmers are accessible from the panel holes so calibration needs no unmounting.
For this proto-model, I simply added a header for the Roman Sowa's Midi Implant, which outputs are wired through those back panel jack switches. A dedicated midi section is in works. The enclosure is just a Hammond 1441 and the panel is obviously a PCB board, so a custom enclosure would be a nice addition for this project as well. From the design viewpoint, I wanted to keep this thing as easy+cheap to build as possible and leave these things for the DIYer to decide.
If you have questions, fire away! I try to get some demos recorded next week.
-Janne
Spliffgroen
Post by Spliffgroen » Sun Jun 21, 2020 6:21 am
Nice project! I read some interesting design decisions made. well done JanneI.
I would be interested in a keyboard player kind of view. With no experience in smd, pre soldered would be a pre for me personally.
Maybe its also a keyboard version? with pitch and mod wheel if that lay in your interests?
Goodjob! looking forward to the audio demo
JanneI
Post by JanneI » Sun Jun 21, 2020 2:35 pm
Thanks! The Keyboard version would be lovely, but at the same time, it would require a quality enclosure (like Devin's "WestonPRO2021" Pro-1 clone project) and at the moment I'm not the one that can properly accomplish that. Maybe this could be done as a collaborative effort some day?
KSS
Post by KSS » Sun Jun 21, 2020 6:00 pm
Hi Janne, Did not find these in a quick search. Do you have a part number or link?
Nice to hear some of your design choices. Looking forward to following this project as it develops. Agree a KBd version could come ater,. After this version has been builder field tested.
JanneI
Post by JanneI » Mon Jun 22, 2020 2:26 am
https://www.digikey.com/product-detail/ ... -ND/527076
KSS
Post by KSS » Mon Jun 22, 2020 2:32 am
Ah, ok. Thank you.
Thought you'd found some still in production.
SphericalSound
Post by SphericalSound » Mon Jun 22, 2020 2:52 am
Such a love letter to the Rogue. Any idea on price ballparks?
Spliffgroen
Post by Spliffgroen » Mon Jun 22, 2020 4:22 am
Nice, yes maybe its a step ahead. But when the sounds en build come tru nicely is something i see a lot of use in. As in collaboration, I may can help with that for later, and sure a lot of other people will.
JanneI
Post by JanneI » Mon Jun 22, 2020 4:59 am
Not yet, but there isn't anything expensive NOS parts, etc, so it should be decent in price to build. I'm also thinking about doing a small run of "SMD pre-soldered" version, so people with no SMD experience can join too. Through-hole PCB is not something that I'm planning, because there are no added benefits besides "the beginner builder's point of view".
However, I might offer a chance for a few SMD experienced builders to get in to "alpha team of testers" and build this for themselves relative cheaply once the initial testing is completely done. Send me a message if this is something that you'd be interested in.
devinw1
Post by devinw1 » Mon Jun 22, 2020 11:58 am
Oh Sweet!! I Was JUST thinking of messaging you yesterday to see how this was going. Looks awesome, nice job!
Please, consider me as a test builder!
kbithecrowing
Post by kbithecrowing » Mon Jun 22, 2020 2:56 pm
This looks cool! Where is the external audio input in the signal path? Would be great if there was an input gain pot was in the signal path for feedback sounds, or even a separate headphone output level; though it seems the panel is pretty full.
diophantine
Post by diophantine » Tue Jun 23, 2020 1:11 am
Looks neat! Depending on price, I'd be interested in a PCB with SMT parts pre-soldered.
The panel + enclosure looks way nicer than what I'd expect for a PCB panel + Hammond enclosure. So, while a custom one would be awesome, I'd also be totally happy with what you're doing now.
rosch
roadkill
Post by rosch » Tue Jun 23, 2020 3:07 am
I'd volunteer to test-build
ashleym
Post by ashleym » Tue Jun 23, 2020 3:08 pm
This is a great looking synth based on a brilliant fun synth. You can’t fail with these ingredients!!
Bjarne
Post by Bjarne » Tue Jun 23, 2020 3:13 pm
+1
southphillysynths
Post by southphillysynths » Wed Jun 24, 2020 3:15 pm
+1
all this, would be more interested in pre soldered SMT
Dcramer wrote:"Not all who wiggle are lost" :boat:
WHO IS BOZO TEXINO?!?!
jaidee
Post by jaidee » Wed Jun 24, 2020 5:27 pm
I'm interested in a PCB, preferably with pre-soldered SMD
Paradigm X
Post by Paradigm X » Thu Jun 25, 2020 3:58 am
+1 pre soldered smt awesome project.
mlw123
Post by mlw123 » Sat Jul 04, 2020 3:31 pm
Im in for self source with pcb and case!! mint design excellent work thanks for the share :)
ps is that midi in on the rear? oh yes it is im well in for this
Purveyor2
Post by Purveyor2 » Sat Jul 04, 2020 4:47 pm
I’d been down as an early builder.
