WANTED: TTSH case .dxf
Bamboombaps
Post by Bamboombaps » Sat May 11, 2019 8:18 am
Does anyone have a cad file of a TTSH case?
jimfowler
Post by jimfowler » Sat May 11, 2019 4:15 pm
Have you tried contacting Jon directly? If you do get the files (and permission to use them) I’d love a case.
Bamboombaps
Post by Bamboombaps » Thu May 16, 2019 4:02 pm
jimfowler wrote:Have you tried contacting Jon directly? If you do get the files (and permission to use them) I’d love a case.
can anyone advise on the email to use to contact him?
jimfowler
Post by jimfowler » Thu May 16, 2019 10:59 pm
ttsh@thehumancomparator.net is the last address I used to contact him.
Bamboombaps
Post by Bamboombaps » Fri May 17, 2019 2:53 am
Yeah same but no reply
danielanez
Post by danielanez » Tue Sep 10, 2019 8:23 pm
I've been trying to make my own case for mine. I learned OnShape to do it, and I still got to keep on working to finish it. My idea is to make the thinnest possible case, because I like to play not in my studio but live, and I'd like to be able to bring it in my bicycle. This is what I've got until now:
https://cad.onshape.com/documents/9a5d7 ... a8b9ef8dd0
Bamboombaps
Post by Bamboombaps » Wed Sep 11, 2019 4:02 am
Awesome!
ScottMcCandliss
How would you be fabricating that case?
Post by ScottMcCandliss » Wed Sep 11, 2019 6:59 am
Will you be using a CNC of some sort, or power tools?
I see the side panels as problematic. A taper cut terminating in an L shape seems difficult to do correctly. It could be done with a saber saw, but difficult to get long straight cuts with that tool. A table saw would not afford vertical cuts and overshoot would be tricky.
Have you considered getting closer to the ARP 2600 design, using three parts? There is an outer box that encloses everything. The synthesizer is mounted to an inner frame, which protrudes from the box. The lid portion fits over the protruding part of the frame.Image
Zifor
Post by Zifor » Fri Sep 13, 2019 5:05 am
I also would be very intersted. I recently got access to a laser cutter and would like to build a wooden case for my TTSH. I would just need the file and i could make one. :75:
Maggots Gnawing Leppers Toes
