Bananafied Pressure Points
Moderators: Kent, lisa, luketeaford, Joe.
animalman
Post by animalman » Tue Oct 23, 2018 2:13 pm
As I've never seen a Make Noise Pressure Points in person, I'm not sure how much space there is between the jacks. Any opinion on if it would be doable to put banana jacks in place of the mini jacks?
Or is there space enough behind the panel?
:help: :help: :banana:
Reese P. Dubin
Post by Reese P. Dubin » Tue Oct 23, 2018 2:49 pm
from my investigations ALL make noise modules use the minijacks to attach the PCBs to the panel. all pots are cheapies that float and dont have nuts.
batchas
Re: Bananafied Pressure Points
Post by batchas » Wed Oct 24, 2018 12:01 pm
animalman wrote:As I've never seen a Make Noise Pressure Points in person, I'm not sure how much space there is between the jacks. Any opinion on if it would be doable to put banana jacks in place of the mini jacks?
I made it a while ago. All banana touch each other then.
Space behind the panel: I don't remember having problems.
You'll need to add switches cause normalization will be lost.
I remember posting in the forum a couple of years back, I'll check and link to a photo if I find it.
EDIT:
oops. please forgive me. Normalization + switches: I had Maths in mind :doh:
FS: KESAKO Player & Reverb for Serge and Buchla
batchas
Post by batchas » Wed Oct 24, 2018 12:07 pm
I made a quick photo (in the dark), it's faster than searching.
You see why I had also Maths in mind!
I can check behind the panel if you want to see how it looks with space. Just let me know.
animalman
Post by animalman » Wed Oct 24, 2018 12:40 pm
Batchas, wow that looks tight. Must be almost impossible to have the top row fully patched?
Would love to see a photo between the panel! Thanks.
How would you rate the pressure "feel" compared to a TKB?
Gaah need to make up my mind
animalman
Post by animalman » Wed Oct 24, 2018 12:43 pm
and I guess I would need to drill the panel to fit the bananas :zombie: :waah:
