Holy balls! There's like a million modules in there.flts wrote:Here is the relatively up-to-date object list:
Factory objects: http://www.privatepublic.de/public/fact ... tlist.html
Community objects (they come with the distribution): http://www.privatepublic.de/public/comm ... tlist.html
So you get both quite high level objects ("tape delay" emulations, simple reverbs, ready-made drum synth voices, biquad filters, panners...) and quite low level ones (delay lines, math objects, simple oscillators, analog and digital voltage i/o, etc.), and everything in between. You can mix them freely or just focus on the higher level objects if you want to.
Aside that, people obviously share their own (sub)patches. There are a couple of cool reverbs, filtered stereo delays, chorus patches etc. shared on the Axoloti forum for example, and you can combine what you want from them as long as there's enough memory and processor cycles available.
No love for the Axoloti DSP Board?
- Wiggling with Experience
- Contact:
oops, I know what I got wrong with the pitch... i'll fix it.mwvm wrote:Clds.
Not 100%. The pitch is a few semitones and the density is a bit buggy.
Easy to assign the axocontrol.
I didn't do the required extra work to get the axocontrol to do the blend options but it is doable within the software...I think
density, I checked the code, I cant see anything obviously wrong, It would be handy if you could give me some more info.
as I mentioned on the axo forum, I dont have a eurorack system (so no clouds/elements), so Im kind of 'flying blind' when testing these.
if anyone that has both an axo and also clouds/elements in eurorack, Id love to talk... it would be useful if we could run some side by side tests to fine tune a few things.
... also please bare in mind, Im not trying to do a perfect 'emulation', in some ways, I like being able to push the parameters past what the module allows, to just 'see what happens'
- secretkillerofnames
- Veteran Wiggler
- Veteran Wiggler
- Contact:
secretkillerofnames wrote:Just ordered one of these.![]()
Filling out my collection of virtual modular hardware (Aira FX, System-1m, Nord Modular).
Can't wait!
@thetechnobear are you the developer?
Your posts on Madrona Labs forum about MPE were very helpful.
Im not THE developer, that would be Johannes... but I am an active developer for it.
(and specifically, did put the axo objects/fw together for clouds/elements)
Yep,and that's the biggest problem that I have finding my way around it!jupiter8 wrote:Holy balls! There's like a million modules in there.
There are so many variants of everything that it is difficult to find the appropriate one to use. The documentation in the editor is next to non-existent, so that won't help you.
Some of the variants look to be attempts to shave a few cpu cycles at the expense of some other limitation which will cripple you further down the patching process.
I loved my Nord Modular because it just worked.
I like Patchblocks as, despite being much more limited, I can focus on trying to perform the task that is in my mind.
I know what you mean, but I guess it's just a consequence of making it such an open platform. Anyone (once verified) can put their own modules into the community library, which will appear in everyone's patch browser. If you stick to the 'official' modules you might find it less overwhelming. The community involvement is also what makes it pretty great though, so it's a trade off. Pure data, for example, is at a mature stage where there is good documentation for mosut stuff, but that has taken a LOOOOONG time!Marizu wrote:Yep,and that's the biggest problem that I have finding my way around it!jupiter8 wrote:Holy balls! There's like a million modules in there.
- Contact:
Id echo @greecen
a) initially stick to the factory objects, these are basically fundamental building blocks, and most have help patches associated with them, which demonstrate how they can be used.
b) go thru the tutorial and demo patches, these highlights many of the most important objects.
then experiment, be playful, if something doesn't work, post it on the forum and ask why... we have all been new to axoloti, so know what its like starting out.
patches can be uploaded to the forum, and with a simple cut n paste other users can run your patches to help diagnose issues, or make suggestions.
(this is why we called it a 'community')
tip: posts that show where your current attempt is, get better/more detailed response, than posts that just say, "how do I ...? " - this is partly because these general questions have all been asked many times before, so a simple forum search will yield something to get you started
of course there is still lots of room for improvement, in all areas - axoloti is still under active development.
(hint: we do have plans for improving the current library organisation)
so my #1 tip, dive in, experiment, have fun .. then ask questions.
getting your feet wet / immersed is really the only way to learn axoloti.
(actually this is basically true of all programming)
- ersatzplanet
- Synthwerks Design
I know this is a minor thing, but do you know if there are any plans to make the UI a little "prettier"? Some modules are a bit ungainly and the "PD look" cn sometime make it harder to differentiate on module from another in a complex patch. I would love a method to at least color modules or something.thetechnobear wrote:of course there is still lots of room for improvement, in all areas - axoloti is still under active development.
I have a Nord G1 and G2 and love their editor. The pull down module selection is much faster than the Axo's menu driven one (I understand the Axo is designed for expansion). I know you are not the developer, but you seem to be involved in the forum much more than I am (which is VERY minimal right now), but have you heard of any GUI developing going on?
-James
- Contact:
Im not THE developer, but I do contribute to the main code base of axoloti (e.g. I wrote the user library code) , so I work/talk with Johannes regularlyersatzplanet wrote: I have a Nord G1 and G2 and love their editor. The pull down module selection is much faster than the Axo's menu driven one (I understand the Axo is designed for expansion). I know you are not the developer, but you seem to be involved in the forum much more than I am (which is VERY minimal right now), but have you heard of any GUI developing going on?
the scaling changes @mongrol referred too, this was done by another developer (its great when others get involved), originally it caused performance issues for the UI,so was pulled - since then he has completely rewritten this and has made some other cool framework changes - we now have this in the new dev branch, so assuming we encounter no issues, this will be in the next release. - If we are lucky, perhaps he may come back to do some more UI updates.
Johannes and I are currently focusing on some fundamental changes (things that we have talked about even before Axoloti was released) - they will make the platform growth more sustainable, and also make it easier to use.
Its early days for this dev cycle (which we plan to be a little longer/ambitious) so I cant really say what will be included, there are so many things we want to do... but they cannot all be in one release. but of course, we want to improve usability with every release.
I will say though, the next release will be worth the wait
as for user interface,
G2 I dont have one, but Johannes does, so he does take inspiration from this , and we both know Max/PD/Reaktor so plenty of other sources of usability inspiration.
but yeah, Axoloti is also different in places, because there is not a fixed set of objects, and they are not all created by the same team (i.e. you cannot enforce guidelines/style) ... but I agree object selection needs to be faster/slicker. (btw, it does have a complete keyboard interface, so its not as slow as it may at first appear... you dont have to touch the mouse!)
object layout is something we have ideas for, in both short and mid term.. so I hope this help improve patch readability.
- Common Wiggler
I'm fairly new to the axoloti universe but I have to say I find the editor very easy to use. Drag&drop ala Nord is not an option, there are simply too many choices. But just typing some keywords into the object browser gives you the results so quickly, what else would you want? E.g. type "dial" or even just "di" and it will bring up the dial objects. Its not slow and you don't need to learn shortcuts to be fast with it.
For me, axoloti is a superb tool. In just a couple of hours I made a synth engine for my linnstrument, or with a few clicks a bass groove for a jam session, or a reverb for my minibrute, etc. etc. The fact that I can write my own objects is absolutely wonderful and makes the platform even more appealing to use.
- i.murray.fraser
- Common Wiggler
This and then copy+paste are your friend.TheSlowGrowth wrote:But just typing some keywords into the object browser gives you the results so quickly, what else would you want? E.g. type "dial" or even just "di" and it will bring up the dial objects. Its not slow and you don't need to learn shortcuts to be fast with it.
The issues I'm having are related to finding objects I liked and used in other patches previously.
"Did they call it a phasor? Saw? LFO? Oscillator? Sync-something-or-another?"
Hopefully they implement both a Tag system to categorize objects in a personalized way and even better a favorites list that you create yourself would be rad.
It's really a sweet sounding platform. I find it fun and fairly simple to use.
I encourage those who have enjoyed the Pure-Data, MAX, Nord-Modular platforms to grab an Axoloti and join in on the fun. I see myself learning and making instruments with mine for years to come.
- Contact:
tags would be useful, and also favourites/recently used objects.
I don't think tags will completely solve the issue, as it still comes down to classification, and for user objects, this will always be down to the author.
(similar to the existing hierarchy, it helps but is not full proof)
anyway, this is all part of a major update for the object browser, and also some things changing around the community libraries.
one small point, the search mechanism, also searches for path matches, and also objects descriptions - so searching for saw, will bring up phasors too.(because I described phasors as being 'saw like'
) - they will be lower in the list, as direct name matches are prioritized... for course broader searches will always suffer hitting too many objects, again, a revised object browser will help this, by allowing more filtering criteria.
I'm all for some sort of search expression functionality.thetechnobear wrote: a revised object browser will help this, by allowing more filtering criteria.
name="lfo" category="lfo" author="t*bear"
Wildcards like the asterisk and specific search words in quotes as a start could do lots.
Anyways. I'll take the discussion back to the community forum.
Did you share this in the forum anywhere? Would love to check it outratsnake wrote:axoloti alpha tester here o/
really love the project and learned a lot by tinkering around with it. Taking a break from it but can't wait to return - made a sq80 waveform oscillator synth with fm and weird memory allocation automation.
Also the Axoloti Control is still being worked on.
I was wondering if you were willing to share your patch with all of the effects and presets integrated so I can try and reverse engineer it.
I'm still trying to get my head around it.
Thanks in advance
Thanks in advance
kausto wrote:I use it as send effect off OT cue out in studio modedrox wrote:
Awesome, This is great. I was thinking of doing something similar with a a doepfer pocket control. Do you have video or audio of it in action you can share?
GrainFreezer was made of Johannes' Grain Table module
https://clyp.it/omr0l3mh mostly noticeable at the end of snippet
Grainverb was made of Johannes' Grainverb module with added feedback path through Johannes' Bode freqshifter.
https://clyp.it/pupz1win - automated grainverb. You can hear it on background mostly
https://clyp.it/qrp1nsyy it can sound pretty wild - check noise bursts at the end ))
LushFDN is my try in reverbs creation. I made it after reading Tom Erbe's paper about ErbeVerb
https://clyp.it/fycsv0dn this reverb is pretty noticeable here
http://community.axoloti.com/t/reverbs-creation/1071/27 more examples here
There is also 8 allpass loop in style of Keith Barr with pitch shifter in feedback path.
Nothing special here.
https://clyp.it/3s3zrgw2 you can hear it on kicks at the beginning (or at the end)
BBDBode is a pseudo BBD (since it was made of regular delay modules) with Bode freq shifter in feedback path. It can sound pretty wild too but i have no examples yet.
4layergranulator was made of plain table record and table read modules with phasor
https://clyp.it/jlkmbicc
https://clyp.it/32mw4iic
It mostly produces a swarm of sound particles
Thanks in advance
Thanks in advance
I got one in the post today, and already made a few useful effects patches to process external audio.
It's fairly simple to understand, quick to work with, and a lot of fun. A couple of patch modules are eating and swamping the memory with no obvious cause. But I'm going to use it for a while and see how far I get.
Immediately less 'math-y' than Pure Data to my non-math eyes – and I've only used modules, and not code – so less intimidating, despite the 'no instructions, please yourself' approach.
I really like it.
I really like it.
Anyone in London fancy letting me pay them to build my Axo Control kit? Just haven't got time to do it. PM me please
Edit: read instructions, it's easy.
- ersatzplanet
- Synthwerks Design
My new Doepfer A-193 arrived yesterday. It is no longer in production but AH had some in stock. It is a CV to MIDI CC converter and I will be making a Eurorack panel with it and an Axoloti behind it wired together with a bunch of pots also wired directly to the Axo. Should be fun. It will have 16 CV ins and as many analog knobs/switches as I can fit.
-James
