No love for the Axoloti DSP Board?
https://github.com/vormplus/AxolotiEnclosuresizone wrote:any one know of a u.s. source for cases?
think I'm getting too old for a dremel cut enclosure.
https://store.believotron.com/sizone wrote:any one know of a u.s. source for cases?
- windspirit
- Super Deluxe Wiggler
I think its about time to get one of these. Curious if there is an easy way to communicate through serial with an arduino just to have the best of both worlds? Especially if I am looking to have pages of controls or do some other clever stuff with the interface writing it in code may be the easiest option.
Mine's paired with a Teensy controller over UART (throwing midi at it). Easy to do.
http://community.axoloti.com/t/mongiloti-synth/1839
I finally got around to finishing my first 'real' patch. Nothing too fancy, a stereo LP/BP filter with midi synced LFO rates and some saturation. Using the beatstep as a controller.
I can see that my patch is pretty inefficient , but I guess that won't matter until I'm attempting bigger and better things. Still only just getting to know the environment....
Sounds great though. Perfect for the volca FM
This is such an underrated thing! The communitiy is amazing, almost unbelievable. I've built a synth for my BA work at the university with couple of sensors and interface elements.
I used couple of distance sensors, light dependant resistors and a 10-turn pot. Outer case is laser engraved from 2-layer acrylic.
Read more on my web http://www.filipruisl.com/work/chlorophyll
I also have 2 of them, but I'm still waiting for some convenient eurorack 'converter shield' if there's gonna be any. I was stoked about Euxoloti but the project died sometime ago.
Is anyone here working on an Eurorack version / application of Axoloti?
- cannonball swandive
- Veteran Wiggler
nice work, bacha.
honestly im more interested in finally getting the axo control going, than getting axoloti into eurorack (far too powerful hardware + well developed platform to screw behind a cheap euro faceplate
would love to be able to use it as a power standalone unit (display ! presets!) for some custom made applications.
Awesome project, bacha!!!!
I also don't really care about a connection to Eurorack. Same regarding AxoControl or other premade interfaces. It is so easy to make your own custom interfaces or use any kind of MIDI controller, that I never yearned for another solution. Making a more powerful Axoloti Core with more audio inputs and outputs would be nice, but I'm also still scratching the current version's surface.
The beauty of it, in my opinion, is its ease of use. You can whip up a lot of cool stuff in no time at all and experiment with new ideas without hassle. I've built two complete custom instruments in cases and lots of small stuff and between the initial idea to a working prototype were only a few hours at most.
- ersatzplanet
- Synthwerks Design
To me, this is one of the overlooked powers of the Axoloti. It is nice that you can program it like a Nord to be lots of different things, but it excels at being a DEDICATED synth module. It is cheap enough that you can pick a function and build a box and put the controls need for it to do that and then after programming it, not ever program it again.
If there was an easy way to read a pin matrix (probably scanning it sequentially) it would be great to make a Semi-Modular on it. Something like a Synthi A. Someday somebody probably will do that.
-James
Exactly! I've got five Axoloti Cores by now. Three are built into cases (two instruments and one Midi/FX sequencer), oen was programmed to be an Octatrack controller which really should get its own case too and one is a spare for trying out new stuffersatzplanet wrote:It is cheap enough that you can pick a function and build a box and put the controls need for it to do that and then after programming it, not ever program it again.
Oh yes, that would also be great! More analog and digital pins!!!ersatzplanet wrote:If there was an easy way to read a pin matrix (probably scanning it sequentially) it would be great to make a Semi-Modular on it. Something like a Synthi A. Someday somebody probably will do that.
- SirSickSik
- Learning to Wiggle
Anyone wants to sell one?
Anyone here who is tired of his axoloti? (Don't think so, but can at least ask..)
I want more of 'm XD
anyways, here are some audio example of modules/patches that I've made as contributor "sss".
https://soundcloud.com/sirsicksik/random-happy-feelings
random controlled tonnetz pattern generator (could also be done manually of course)
https://soundcloud.com/sirsicksik/broke ... i-sampling
a sample-bank generator and accompanying sampleplayers and granulator, controlled by a 16 channel module loosely based on the wogglebug with a bunch of extra's.
https://soundcloud.com/sirsicksik/crashtest
5-board tekno demo, trying out a setup
https://soundcloud.com/sirsicksik/types-of-delay
several modules based on delays (reverb, delay, chorus, etc)
https://soundcloud.com/sirsicksik/axoltek
2 axoloti boards generating some tekno
https://soundcloud.com/sirsicksik/wavetraining
demo of an wavetable oscillator with multiple ways of scanning through the wavetables
oh, and btw, the module shown in my profile picture has also been realised for the axoloti
An 8-channel anything-2-anything morpher. Morphs through the 8 inputs for all the 8 outputs independently to be able to route any audio/control input to any output or a mix between any two inputs (order of the morph can be manually entered, just like the mutable instrument "frames").
Axoloti down?
How long has the forum been down? Is this a temporary hiccup or a bad sign?
- Wiggling with Experience
- Contact:
You made a really good decisionelectricanada wrote:What have I done?
Pretty sure, yes. Coding not really needed, patching knowledge will be essential though. There are tons of community patches so if you're not really into the 'how do I do this' aspect, and more into the 'I want a tool that does such-and-such' you'll be fine.electricanada wrote:Can it be made to play in just intonation without being a coding genius?
There's thousands of things I'll never even get to, and I'm okay with that.electricanada wrote:What will I use this thing for?
I think I'll make an fx box first. How hard would it be to get some CV from my Eurorack into the Axoloti?blaerg wrote:You made a really good decisionelectricanada wrote:What have I done?
- ersatzplanet
- Synthwerks Design
Unfortunately to drive the Axo with CV you will have to add some external circuitry to limit and polarize the incoming CV to something the Axo understands. Basically it wants to see only 0 to +5V and you can damage it by exceeding that range too much. There are some projects out there adding the circuitry needed (the Eurolotti and others). I myself went the more expensive, but for me more flexible direction, of buying a CV>MIDI CC converter module (I got the Doepfer A-192) and that gives me 16 CV ins to the Axo (or any other MIDI synth). Wiring pots and switches to the Axo is VERY easy and the chances of damaging the unit are much lower this way so I am making a module with 16 pots connected. The Pots and MIDI can both work at the same time so 32 inputs ought to be more than enough.electricanada wrote:I think I'll make an fx box first. How hard would it be to get some CV from my Eurorack into the Axoloti?
-James
