4ms RCD breakout wiring?
vmgas
Post by vmgas » Sun Nov 04, 2012 2:31 pm
wiring up my breakout for the rcd but the image from 4ms for the wiring is blurry as fuck..cant really see..anybody with a clear image of the breakout wiring?
pulse_divider
Post by pulse_divider » Sun Nov 04, 2012 3:05 pm
From memory, wires 1+2 go to switch one, wires 3+4 to switch two, etc.
Each switch should only have 2 solder lugs and it doesn't really matter which of each pair goes to which lug since it's just opening/closing the header pin continuity.
vmgas
Post by vmgas » Sun Nov 04, 2012 3:20 pm
thanks
when i looked at the image it looked sort of mixed up with the light wire on a white background. i couldnt tell if there was something weird going on for some reason
Hemmerlinj
Post by Hemmerlinj » Sun Nov 04, 2012 7:08 pm
The picture was tough to see. I just built mine yesterday and just soldered the left wire to the left lug and right wire wire to the right lug for each set of 2 wires. Works fine. just make your switches are oriented properly so your actually doing what you think you're doing when you flip a switch.
