hilarious 1HP modules / ideas
seismic
Post by seismic » Tue Aug 18, 2020 3:06 am
Hi all
i recently made some sketches for a 1HP powersupply, and i also had the idea of making a type-C hub in 1HP.
Apart from these two "usecases" no other function jumped into my mind to be done in hilarious 1HP.
Anybody some ideas to be done in 1HP???
vadimred13
Re: hilarious 1HP modules / ideas
Post by vadimred13 » Tue Aug 18, 2020 3:32 am
Some kind of a light source would be nice, maybe a gooseneck
helix
Post by helix » Tue Aug 18, 2020 5:23 am
Or just a really nice blinky led light panel. Will a jack fit onto a 1hp panel? If so you could make a 1HP led level meter with red leds at the top section?
A load of switches that could be linked to jumpers?
Paranormal Patroler
Post by Paranormal Patroler » Tue Aug 18, 2020 5:25 am
seismic I didn't know you had an account here, I follow your designs on IG. That was a cool one indeed!
helix
Post by helix » Tue Aug 18, 2020 5:28 am
Not hilarious in any way, but just a 1HP panel with holes drilled into it for air flow?
helix
Post by helix » Tue Aug 18, 2020 5:29 am
A nail file?
helix
Post by helix » Tue Aug 18, 2020 5:32 am
A contact mic fitted onto the back of it (which can then be connected via a cable into the front of another module... somehow.. maybe the cable comes through a hole in the module itself so it can then be connected up to anything. Then you can tap or scrape away at the module to cause vibrations like mutable ears. But in 1hp
strettara
mufferthucker
Post by strettara » Tue Aug 18, 2020 5:45 am
A pocket to hold a single cracker.
“It must be abstract. It must change. It must give pleasure."
New album: OZ
helix
Post by helix » Tue Aug 18, 2020 6:42 am
:hyper: :hyper: YES!
helix
Post by helix » Tue Aug 18, 2020 6:43 am
Tiny CV controlled circular saw/dremel wheel
Keltie
Post by Keltie » Tue Aug 18, 2020 7:05 am
Sounds like a job for the dreaded no pass filter. 1 input jack attached to a plate, nothing else. It’s passive I tells ya!
seismic
Post by seismic » Tue Aug 18, 2020 9:47 am
i think switches would be possible, they come in super tiny shapes :)
maybe for some passive module to switch things on and off.
seismic
Post by seismic » Tue Aug 18, 2020 9:48 am
mmm crackerbox :)
seismic
Post by seismic » Tue Aug 18, 2020 9:50 am
no - jacks don't fit :( smallest one i found is just about 5mm, and you'll need to attach it to a PCB. that makes more than 5mm..
seismic
Post by seismic » Tue Aug 18, 2020 9:53 am
not possible. my wife has em all
A nail file?
seismic
Post by seismic » Tue Aug 18, 2020 9:54 am
glad you like it :)
sirjpink
Post by sirjpink » Tue Aug 18, 2020 9:54 am
:hihi:
Or along those lines: business card holder? Or better: (micro) SD card holder?
Or maybe some sort of ventilation/fan thing (I honestly don't know if they make them that flat).
Or a panel with cable ties sticking out so you can stick them between modules and tidy up that noodle soup you've got going on there? :eek:
PS. I do like the idea of having a USB port that small. Great of powering portable recorders too.
flipper16
Post by flipper16 » Tue Aug 18, 2020 9:58 am
What about a 1hp blank panel to fill gaps between modules? Oh; hang on, wait, what? :hmm: Never mind :doh:
megarat
Post by megarat » Tue Aug 18, 2020 10:03 am
A magnetic paper clip holder.
Exit Chamber
Post by Exit Chamber » Tue Aug 18, 2020 10:06 am
Tiny blackboard to take patch notes on.
pugix
Post by pugix » Tue Aug 18, 2020 10:17 am
Synth voice
Richard
https://www.pugix.com
target_destroyed
Post by target_destroyed » Tue Aug 18, 2020 10:20 am
Synth voice
Yes. With 83hp expander.
seismic
Post by seismic » Tue Aug 18, 2020 10:25 am
it's pretty amusing to see people suggesting funny ideas, but for quite some time many people in eurorack land were screaming for 2HP and MI clones as micro-modules :)
synths for ants, as i call them :) but im just trying to fill the odd gaps
Fandy01242
Post by Fandy01242 » Tue Aug 18, 2020 10:32 am
How about a credit card swiper, so your eurorack can directly empty your bank account?
naturligfunktion
Post by naturligfunktion » Tue Aug 18, 2020 10:37 am
:lol:
A new track for your enjoyment
